Old 06-18-2014, 01:25 PM   #855
DC2R
Drives: 2014 Scion FR-S
Originally Posted by enjoi23 View Post
Anybody having trouble with the sd card getting stuck in the unit?
Or with the dash piece not popping when putting the interior back together? for some reason mines isn't going in right. Is any modification needed to get it to fit right/
You need to move bracket to have unit sit flush. Instructions in thread.
Don't think anyone reports issue with sd. Hard to get finger in so i use something small to press it in and then pop it out
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 06-18-2014, 02:25 PM   #856
SPT Legacy
Drives: 2014 Lightning Red BRZ
Which spots do the bolts go into?
Took me a bit to figure it out and the mounts still don't sit flush on the sides of the HU..
SPT Legacy is offline   Reply With Quote
Old 06-18-2014, 05:12 PM   #857
DC2R
Believe it's pictured earlier in thread. You need to bend brackets and move them all the way forward
Old 06-18-2014, 08:17 PM   #858
xjohnx
Grip>Slip
xjohnx's Avatar
any recommendations for backing up apps/settings before applying the cafi firmware update? i'm assuming i'll have to re-root after applying?
Old 06-18-2014, 08:39 PM   #859
DC2R
Titanium backup pro. And yes you will need to re root
Old 06-18-2014, 09:28 PM   #860
inositle
Drives: Subaru BRZ Limited WRB
So I ordered [ame="http://www.amazon.com/Tech-Armor-Screen-Protector-mini-iPad/dp/B009QQMEEY/"]this screen protector[/ame] and got it in today. I cut a rectangle out for the size of the screen and applied it and it looks great and completely masks all the previous scratches. Unfortunately, I am getting absolutely zero touch response
Has anyone else installed a protector successfully? I feel like I can't win with this unit. I've googled for that specific protector and there are only a couple posts about reduced sensitivity in 3000+ reviews.
EDIT: Well this is weird, the unit crashed and when it rebooted everything works. I was actually navigating before by touching w/ 4 fingers and where ever the final 5th finger touched is where it registered. When I was installing the unit a few weeks ago the first time it booted up it also wasn't registering touches... strange.
inositle is offline   Reply With Quote
Old 06-18-2014, 10:26 PM   #861
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by inositle View Post
So I ordered this screen protector and got it in today. I cut a rectangle out for the size of the screen and applied it and it looks great and completely masks all the previous scratches. Unfortunately, I am getting absolutely zero touch response
Did you give it adequate time after installation? If not (assuming you used the wet technique) that can cause all sorts of trouble in a capacitive display.
Otherwise, no idea. Keep an eye on it, it could be hardware that's finicky.
Old 06-18-2014, 10:36 PM   #862
Orisai
Drives: Hyundai ix45
i bought the toyota universal one, but don't recall any black decoder box? what's that do? any link to info on it?
Here's an example of a wiring harness with CAN bus decoder:
If your stereo came with one of these boxes, then you have a CAN version.
Wikipedia article on what is the CAN bus and how it works:
[ame="http://en.wikipedia.org/wiki/CAN_bus"]CAN bus - Wikipedia, the free encyclopedia[/ame]
Orisai is offline   Reply With Quote
Old 06-18-2014, 10:45 PM   #863
xjohnx
Grip>Slip
xjohnx's Avatar
gotcha, no can bus on my unit. I'm familiar with the canbus and how it works, but i don't think that our car's have a factory harness for the canbus at the head unit (that i'm aware of, anyway. quite possible that i missed something earlier in this post.)
Thanks for confirming though, now i know that the update on the website should work for my unit.
Old 06-18-2014, 11:49 PM   #864
Fastbrew
Drives: 2014 Pearl White BRZ
I don't believe anyone has mentioned the brown wire hanging off the ca-fi ipod/usb harness that is labelled "brake" - I am assuming this is not used? What is it's purpose on the unit?
Fastbrew is offline   Reply With Quote
Old 06-19-2014, 12:02 AM   #865
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Probably something to determine when the e-brake is engaged, for one reason or another.
SilverlightPony is offline   Reply With Quote
Old 06-19-2014, 01:10 AM   #866
Dezoris
Dezoris's Avatar
1ghz cpu will choke using torque with high speed bt adapter in fast communications mode and multitasking like music and maps. The nexus7 can barely do it with a dual core.
This is the let down with this unit, why is it so hard to include modern cpu?
Old 06-19-2014, 01:42 AM   #867
Fastbrew
Fellow Ca-Fi owners - help a brother out!
First - I have a 2014 BRZ Limited.
I have read this thread a number of times. I am having trouble getting the dang thing installed.
The latest failed attempt was that I ordered this:
[ame="http://www.amazon.com/gp/product/B00EAYYQDO/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1"]Amazon.com : Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles : Vehicle Audio Video Power Adapters : Car Electronics[/ame] as linked earlier in the thread.
It doesn't fit the BRZ. Not mine anyway. I was assuming that I would just take the head end of the cable (with the square USB connector) and plug it into the socket on this cable - then plug the standard USB into the CA-FI usb/ipod cable. The BRZ has a squareish connector - not rectangular like this. I even popped the entire USB/Aux assembly out, disconnected the cable and tried to put the adapter onto the connecter panel. No such luck.
Can anyone point me to the correct cable for a BRZ?
I also was told earlier in the thread that I will not have to worry about the power cable for the antenna. True? I won't splice it if I don't have to.
Thanks! I am going on close to a week of having the unit and not being able to use it due to the install. The info is in this thread but there are no really clear install instructions and it appears that the twins have some variations!
Old 06-19-2014, 01:45 AM   #868
Fastbrew
lol - maybe the ca-fi flashes stuff like this when you e-brake!
The Following User Says Thank You to Fastbrew For This Useful Post:
DC2R (06-19-2014)
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
