Drives: 4-Runner Sport - 13' BRZ SportTech
Small subwoofer in rear side panel?
Has anyone attempted to put a small subwoofer behind one of the rear side panels next to the rear seats? I've seen pictures of the panels off and it looks like there's a lot of space back there.
Top Tier Imports - Check out my build journal HERE
#2 |
ProCrastinationConsultant
not yet.. my 2001 eclipse also suffered from the same condition, and in all the years that car existed, no one did it to that one either..
edit-- i take that back. http://www.ft86club.com/forums/showthread.php?t=66561
#3 |
Just a dude
Drives: Scion FR-S 2013
Problem is the depth. I had my entire interior apart last year looking at expanding my existing system. Even at 6" the depth of most mid to top tier subs just are (too deep) for those cavities, obviously 8" and up te magnets get (more depth) needed..
As fellow above mentioned you can customize some small enclosures, I seen that thread however it comes down to enough airspace for the enclosure to work within it's optimum range, the back trunk area is so much easier to work with and obtain te room for .50-1.0 cubic feet enclosures.. Thus resort to back corners and run subs/enclosures there. The best balance comes from that distance anyhow so all good.
#4 |
Drives: 2014 Pearl White BRZ
I saw this picture on here:
What do you think about mounting subs and amps in a top box for easy disconnect? I pulled out my OEM sound tube - I was thinking about hooking it back up and feeding it in from the top box through the antenna hole... ok - it's bed time
#5 |
Drives: FR-S 2013 Asphalt
If you place a 3/4" baffle against the metal behind the rear plastic bits you can fit a sub with 6" depth, 6 1/2" if its a 10" sub and you center it a bit lower as the outside sheet metal curves out toward the bottom.
I fit a 12" sub with 5 3/4" mounting depth. |
#6 | |
Drives: 86 GTS Auto in Pegasus White
Pics pls
#7 | |
I'm sure that you could fit the JL 13" in there also, but it might be not enough air space. My recommendation if you do this project is to cut out all the metal you can, relocate electronics and grounds, and make a solid box out of fiberglass. I used the marine grade foam and fiberglass combination and it took countless hours to finally make it fully air tight. Very messy and not fun at all. Definitely not for the faint of heart, you must have balls to do this. Or be stupid and stubborn, like me! |
| Side marker small metal clips | blackfireball5 | Want-To-Buy Requests | 13 | 01-04-2017 06:46 PM |
| Dented rear wheel side panel/rocker panel. | Autocon | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 19 | 12-22-2014 11:18 PM |
| scrapped lower side panel =( | brandonblt2 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 15 | 11-07-2014 03:31 PM |
| Painted 86 emblems (side panel) | eddieEndo | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-07-2013 05:39 PM |
| How to remove small instrument panel? | boredom.is.me | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 03-02-2013 04:07 PM |
