Old 06-18-2014, 10:17 AM   #939
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by piknockout View Post
Looks like I'm finally going to buy some more parts an actually put them on the car. Still have half an STX build sitting in my storage room. I know, I'm lame. But with the ability to drive the SSR Vette, my motivation has been lacking. Also, quiet and comfortable has been quite nice. But I'm finally going to install all the suspension goodies soon after I order a few more things.
So real question here, what's the current thinking on rear lower arms? I know the SPC is the standard go to, but thought I had heard word of those slipping? Probably will get it anyways. Just wanted to get the consensus here.
They are almost a necessity to be able to control Rear Camber and toe and not have to rely on ride height to adjust. Whiteline, SPC, and others are what I have seen being used... Personally I am using Tru-hart, which conforms to the rules...as well as being easy on the budget. SPC is an inexpensive alternative as well but seems to take a bit more to get the camber right..
Bill
Scooby South is offline   Reply With Quote
Old 06-18-2014, 10:29 AM   #940
piknockout
Drives: 2014 BRZ
Thanks guys, I ordered it anyways. It's the easy button and I'm not trying to be super competitive with it any time soon. Plan is to install all the suspension goodies when they get here, but I'll likely hold off on the exhaust/tuning until I decide to seriously compete with it. I like the quietness.
piknockout is offline   Reply With Quote
Old 06-18-2014, 01:25 PM   #941
Scooby South
Conedancer
Originally Posted by BRZZZZZZZZZZ View Post
I have the SPCs and haven't had any slip since I installed them (1 lapping day and 3 auto x days so far) but I was only running 225/50/16 tires. I am throwing on 255s tonight and considering ordering Cusco arms to replace my SPCs...
Cusco's are not legal in STX.. .as they have a spherical bearing end.. Replacement arms have to have a bushing end to be legal..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
whataboutbob (06-18-2014)
Old 06-18-2014, 01:30 PM   #942
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Bill
I am aware, boost is going to put me out of STX anyway which is why I am considering the Cusco ones...
BRZZZZZZZZZZ is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post:
Scooby South (06-18-2014), whataboutbob (06-18-2014)
Old 06-18-2014, 08:28 PM   #943
brianL.
brianL.'s Avatar
Drives: BRZ/1J Supra
Originally Posted by Turkish View Post
What are you alignment settings?
Sent from my SM-G900V using Tapatalk
^^^^ this.. after we learn your alignment... What spring rates are on the car.. KW changed at some point from a 7/6 to a more conservative 6/5 ??? I think.. most of us are on Square Rates.. Theres a couple of ways to loosen it up. a bigger Rear Bar is one way.. another way is up the rear spring rate.. and finally.. crank up the rear rebound. But alignment/ride height is a good place to start...
Bill
I'm running very conservative alinement right now(almost stock settings).Next year I will be doing a more aggressive alinement.I plane to do more mods next year but as of this year I just want to dial in the coilovers better and really don't know were to start.how much should I stiffen up the front and how lose should the rear be? also Should I do 1 or 2 click increments?
brianL. is offline   Reply With Quote
Old 06-18-2014, 08:39 PM   #944
Scooby South
Conedancer
Where are they set right now?? To be able to help you.
Bill
brianL. (06-19-2014)
Old 06-19-2014, 12:06 AM   #945
brianL.
brianL.'s Avatar
Bill
I made it 2 clicks stiffer in the front and 2 clicks softer in the rear from the break in period settings that kW recomends.
Do you think tire pressure will help? That day I ran 34psi in the front and 31 in the rear.I kept checking them after every 2 runs
Old 06-19-2014, 12:08 AM   #946
xDanger_208x
xDanger_208x's Avatar
Drives:
What tires?
xDanger_208x is offline   Reply With Quote
Old 06-19-2014, 12:13 AM   #947
brianL.
brianL.'s Avatar
Originally Posted by xDanger_208x View Post
What tires?
Bridgestone re11a
Old 06-19-2014, 12:24 AM   #948
xDanger_208x
Drives:
Bridgestone re11a
I'm not familiar with the sidewalls on those, but I run 28 rear, 31 front on my Z2's.
Old 06-19-2014, 12:43 AM   #949
autoXracer
Drives: 2013 WRB BRZ
Any installed pictures?
I'm running Ground Control camber plates. Gained about 0.5 inch travel, gained 0.5 degree caster, with tons of camber adjustment left
autoXracer is offline   Reply With Quote
Old 06-19-2014, 02:32 AM   #950
barabia
barabia's Avatar
Are the Crawford BPBs legal in STX? I cant find anything that would suggest they werent but I thought Id ask in case someone has a definitive answer.
barabia is offline   Reply With Quote
Old 06-19-2014, 04:05 AM   #951
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
From what I understand you can't touch anything between the throttle body and exhaust ports, so I think they're out. I don't have the rule book on hand, maybe someone can quote the relevant section?
RiskyTrousers is offline   Reply With Quote
The Following 3 Users Say Thank You to RiskyTrousers For This Useful Post:
barabia (06-19-2014), Scooby South (06-19-2014), was385 (06-19-2014)
Old 06-19-2014, 09:56 AM   #952
was385
Drives: MT WRB BRZ Limited, 2007 911s
No, they're not legal.
C. The air intake system up to, but not including, the engine inlet may be modified or replaced. The engine inlet is the throttle body, carburetor, compressor inlet, or intake manifold, whichever comes first.
was385 is offline   Reply With Quote
The Following User Says Thank You to was385 For This Useful Post:
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
