Old 06-17-2014, 12:29 PM   #925
xDanger_208x
xDanger_208x's Avatar
Drives:
Originally Posted by RiskyTrousers View Post
I'm running the Ground Control top hats which allow for a lot more bump travel.
Any installed pictures?
xDanger_208x is offline   Reply With Quote
Old 06-17-2014, 12:35 PM   #926
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by mrazny View Post
SM to get that. More reason to turbo up and go there
Yes yes but no no no no no!
The Following User Says Thank You to BlaineWasHere For This Useful Post:
whataboutbob (06-18-2014)
Old 06-17-2014, 12:38 PM   #927
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by xDanger_208x View Post
Sorry for the change of topic...
What are you all using for camber plates? I currently have MSI, but they have a rather tall stack height forcing me to run the spring perches almost all the way down my Tarmac 2's.. and I'm not even very low at all.
25.675 fender heights all around.
I was choosing between the HVT and Raceseng and ended up with HVT. They may not have the sex appeal but they do exactly what I need to for a bit less.
was385 is offline   Reply With Quote
Old 06-17-2014, 12:45 PM   #928
xDanger_208x
Drives:
I really like the HVT but I'm a bit concerned about them maxing out at 1.8 deg camber.
Old 06-17-2014, 12:49 PM   #929
was385
I get about 3.2 deg with maxed out $8 OEM bolts. It's more than I need, still quite a bit cheaper.
Old 06-17-2014, 12:50 PM   #930
xDanger_208x
Drives:
Oh that's perfect! I may have to go that route.
Old 06-17-2014, 12:50 PM   #931
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Currently running WRX camber plates.. set at -3.3 ... I have ALOT of range that I could go like to -5.5 if needed. but isn't necessary for obvious reasons.
Bill
Scooby South is offline   Reply With Quote
Old 06-17-2014, 12:51 PM   #932
xDanger_208x
Drives:
Bill
Pictures? Links?
Old 06-17-2014, 12:53 PM   #933
was385
There's a number of high quality options and I can't see you going wrong with any of them. Just comes down to comparing price with what you actually need from the product. Glad I could help though.
Old 06-17-2014, 12:55 PM   #934
xDanger_208x
Drives:
I've been debating between those and the Ground Control option. Mostly something high quality that won't raise the car.
Old 06-17-2014, 12:56 PM   #935
Wepeel
Drives: '13 BRZ Ltd
Just wondering if any of you guys that are running the KW and have swapped springs are looking to offload the originals. Looking for the stiffer 400/343 rates (obviously).
Wepeel is offline   Reply With Quote
Old 06-17-2014, 03:27 PM   #936
Scooby South
Conedancer
Pictures? Links?
this is a pic of -3.3 degrees.. As you can see I have a ton of adjustment there..
Standard WRX Camber plates..nothing special
these are EBAY specials. One word of Caution if you decide to use these. They only come with a 12x1.5 nut..where as most Subaru Fitments are 12x1.25 ... so I used Cusco top nuts that I had from another application. Most Camber plate bearings are the same diameter..so fitting the Cusco Top nuts wasn't an issue.
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
MidnightRunner (06-20-2014)
Old 06-18-2014, 09:58 AM   #937
piknockout
Drives: 2014 BRZ
Looks like I'm finally going to buy some more parts an actually put them on the car. Still have half an STX build sitting in my storage room. I know, I'm lame. But with the ability to drive the SSR Vette, my motivation has been lacking. Also, quiet and comfortable has been quite nice. But I'm finally going to install all the suspension goodies soon after I order a few more things.
So real question here, what's the current thinking on rear lower arms? I know the SPC is the standard go to, but thought I had heard word of those slipping? Probably will get it anyways. Just wanted to get the consensus here.
piknockout is offline   Reply With Quote
Old 06-18-2014, 10:09 AM   #938
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
I have the SPCs and haven't had any slip since I installed them (1 lapping day and 3 auto x days so far) but I was only running 225/50/16 tires. I am throwing on 255s tonight and considering ordering Cusco arms to replace my SPCs...
BRZZZZZZZZZZ is offline   Reply With Quote
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
