Old 06-13-2014, 11:13 PM   #1653
was385
Drives: MT WRB BRZ Limited, 2007 911s
Originally Posted by PoWn3d_0704 View Post
STX, yes. Very informally competing with guys on slicks.
In my Actual STX class we have a WRX, Two more 86's and a 300zx.
So far i'm just a tenth or two behind the WRX and beat the rest.
Just the tires should get you that amount of time and more. Yellows cut down on the body roll a lot but I realized that I wanted more, hence the switch to tarmacs/bilsteins. If you think you'll eventually want to bump up from springs, I would just do it, but yellows with stock dampers are also a heck of a lot of fun and should help you out big time.
was385 is offline   Reply With Quote
Old 06-16-2014, 11:54 PM   #1654
Malt
Drives: 2015 WRX
I've noticed since I've gotten the new tires on that on heavy steady state cornering I'm getting some "bouncing", for lack of a better word, in the rear of the car on the side that is loaded. I typically drive with all the nannies on and I'm wondering if this is a result of the stability control or traction control intervening excessively or if this is something else. Ideas?
Malt is offline   Reply With Quote
Old 06-17-2014, 12:03 AM   #1655
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
I would try it with all the nannies off. See what happens. Are you talking AutoX or just driving? Have to be more careful on the road.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 06-17-2014, 09:25 AM   #1656
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
Hey RCE,
I'm curious what to expect from your RCE swaybars. I recently picked up a set or RCE adjustable sways because I have been getting a little too much understeer on the autocross. I'm really hoping to reduce body roll a bit more as well, without going to coilovers. Also, admittedly, I haven't played with tire pressures and that might very well cure the understeer issue.
my setup:
I have RCE yellow springs, 18x8.75 wheels with 225/40 Pzero Rosso's on all 4 wheels. I've got camber bolts up front, but the best they could do at the alignment shop was -1.1*. Rear camber is about -1.6*.
What can I expect to experience from the RCE sways? Should I start at the soft setting (the outermost hole i think)?
Will the swaybars increase my overall grip and help me go faster? Or do they actually reduce grip? I think the former.. but I wanted to make sure.
Thanks!
eikond is offline   Reply With Quote
Old 06-17-2014, 09:43 AM   #1657
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by was385 View Post
Is this going to be an STX car?
the ST classes are specifically for street tires, there are no slicks there.
Old 06-17-2014, 10:10 AM   #1658
was385
Hence the clarification on my part. I guess he has an informal competition going on with someone in a slick class.
Old 06-18-2014, 07:52 PM   #1659
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Did I bed these in enough? HC+800
They squeal a bit, only at low speeds with light pedal pressure. I'll hose them off later. The dust is sorta caked on there after the bedding session.
Before
After
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 06-18-2014, 11:31 PM   #1660
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Doubt I bedded them in enough. After driving on the street some more, part of that bluish layer faded. I just hope they get quieter. I don't think telling a girl "because race car" will fly.
Old 06-18-2014, 11:59 PM   #1661
PoWn3d_0704
This was actually my explaination to my girl, about some squeal at low pressure braking.
She was like 'Your $3k brake kit sucks.'
I responded by saying 'Because Race Car' and slamming on the brakes.
When I drop in new pads I'll try to do a better job of bedding, but right now the damn things stop so well.
Build Album:
Old 06-18-2014, 11:59 PM   #1662
PoWn3d_0704
Just a friend of mine, yeah. He's on slicks and all which is why I want to put down a better time than him so bad.
Build Album:
Old 06-20-2014, 10:39 AM   #1663
oldlostcory
oldlostcory's Avatar
Drives: 2013 WRB BRZ Limited
I am a suspension noob, can anyone help me with a DD setup? I plan on lowering my car with either RCE yellows or Eibach Prokit and planning on a set of wheels that are 17x9 245/40/17. I will do some autox and trackx in the summer months. My concern is how much camber should I dial in? In the winter I'll be running stock wheels with snow tires. I understand there is probably a compromise to be made but what would be a good balance? Thanks for any help.
oldlostcory is offline   Reply With Quote
Old 06-23-2014, 02:48 PM   #1664
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
guys I'm blind
there used to be a thread that had all the swaybars listed for comparison and I can't find it now.. plz help?
Old 06-23-2014, 02:59 PM   #1665
Racecomp Engineering
What kind of tire will you be autocrossing or tracking with?
- Andy
Old 06-23-2014, 04:16 PM   #1666
oldlostcory
- Andy
Something along the lines of BFGoodrich g-Force Sport COMP-2's. Not sure which is considered the best moderately priced summer/performance tire. I had the g-forces on my integra previously and they were ok. I'll run them as my dd from like april-october and then winters from november-march.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
