Old 06-16-2014, 09:20 PM   #15
BadBRZ
Drives: Subaru
Fantastic area under the curve!!
I can't help but wonder with the HP curve being so flat on top that the car would feel like it stopped pulling..
As HP is a function of HP=(TQ x RPM)/5252 in order for HP to stay constant as RPM increases torque would have to drop off quickly.
I also noticed you are running more PSI over the RPM band, could this explain the gain in 18whp peak and increased area under the curve?
Are these cams intended to spool big turbos early as opposed to top end power?
BadBRZ is offline   Reply With Quote
Old 06-16-2014, 09:25 PM   #16
wootwoot
Drives: FRS
Any plans for NA cam packages or testing?
Old 06-16-2014, 09:30 PM   #17
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
So far, every post from FBM.
crazyfrenchbiker is offline   Reply With Quote
Old 06-16-2014, 09:31 PM   #18
sw20kosh
Drives: 2013 Black FR-S
Look at it in relation to stock.... The slope of the hp curve is drastically improved even though torque may be dropping off at these massive airflow levels.
Old 06-16-2014, 09:31 PM   #19
Frs300
Frs300's Avatar
Drives: Pile of junk
Originally Posted by woode View Post
Can you guys do payments of hopes and dreams?
if @FullBlown will i want them to sign me up lol
Frs300 is offline   Reply With Quote
Old 06-16-2014, 09:49 PM   #20
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
As always great results and beautiful parts! Crazy how the whole powerband kicks in sooner.
#3 on that list please.
Old 06-16-2014, 10:18 PM   #21
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
havent you taken enough of my money =) good job
xDBOYx is offline   Reply With Quote
Old 06-16-2014, 10:34 PM   #22
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes the increase is most likely from the boost level. I can see this setup working well on most turbo setups.
Not right now but we might test some NA stuff.
FullBlown is offline   Reply With Quote
Old 06-16-2014, 10:47 PM   #23
Lonewolf
Lonewolf's Avatar
Drives: Moped
I will do unspeakable things to swap this motor into an FRS for me and call it my own...feel free to pm for details, lol
Old 06-16-2014, 10:54 PM   #24
diss7
Drives: AE86, 2x GT86, TE27
Couple of questions:
1; Testing is done using a built long block. Is there any reason why this head package cannot be used on a stock block.
2: Does the increase in lift/duration make the motor an interference motor? (I'm not actually sure if stock fa20 is already an interference motor)
3: Will the sale of this product be offered on a core exhange basis, to minimise down time?
4: Is all varible valve timing and such retained with this package, so that low rpm drivability and economy is minimally effect?
Colour me interested by the way.
diss7 is offline   Reply With Quote
Old 06-16-2014, 10:59 PM   #25
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
their website says they will require a core otherwise its a $1500 charge for the core.
Edit: did a quick search if the fa20 was an interferance motor and came up with this thread;
http://www.ft86club.com/forums/showthread.php?t=10129
Old 06-16-2014, 11:05 PM   #26
FullBlown
FullBlown's Avatar
Drives: Scion FRS
There is no reason why you cannot use it on a stock motor. Stock rods are a hit or miss. It would be crappy to have an oem rod let go and destroy everything up top.
Stock pistons could have interference issues but we have not yet confirmed this. It will clear every aftermarket pistons out there. (Builder should always check)
We advise all customers to let us clearance and shim everything for them. These heads can be tricky to get right.
Yes, cores are already in the works. We have been selling this head package without cams for awhile.
Yes it is
Old 06-16-2014, 11:18 PM   #27
Boss Paco
Subaru Certified Sales
Boss Paco's Avatar
Drives: '13 BRZ Premium, '05 WRX STi
Man, y'all are makin' it hard for me not to go nuts on my BRZ. Good work!
[Subaru WRX STi] Benson Block - Kelford Cams - PTE6466 - ID2000s - AEM - E85
[Subaru BRZ] Speed by Design Turbo Kit - Invidia N1 - BC Racing BR Coilovers - Rota RT5s
[Subaru WRX] Prodrive - Subaru Tecnica International - APS - Tein - Rota Titans
"The only thing that I trust in this world is cars!" - Don 'The Goods' Ready
Boss Paco is offline   Reply With Quote
Old 06-16-2014, 11:46 PM   #28
BadBRZ
Drives: Subaru
Originally Posted by FullBlown View Post
Egnine Setup..
FBM Stage 2 Long block
More info on this Stage 2 long block please
@FullBlown
FBM Stage 1 and Stage 2 Head packages FullBlown Forced Induction 48 02-03-2015 05:13 PM
Brian Crower Stage 1 Cams DAMotorsports Engine, Exhaust, Transmission 150 10-13-2014 01:13 PM
Stock Dyno and Perrin Stage 1 Results brillo Software Tuning 4 01-24-2014 08:26 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 07:02 PM
