#911 |
i'm sorry, what?
Drives: Canada
well..
if putting on a strut bar is enough to affect the feel of the front, then it is actually very functional.. perhaps you've set your car up in a way that ended up factoring in the front deflection, so when you suddenly stiffen it up the motion dynamics change at the tire level. if this was stock class, I would say that the natural spring of the chassis is a net benefit to your grip, but if you're given almost carte blanche at suspension setup then I'd suggest to aim for as stiff a chassis as possible and set up the suspension accordingly.... nay?
#912 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
To put it into perspective... The Turn-in on the twins are awesome, as designed, if you mess with the balance of that, then you must have adjust-ability to ensure the turn-in balance is maintained. ![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#913 |
Drives: BRZ/1J Supra
I have a 2014 brz with kW v3 coilovers 17X9 255/45 re11a all around and I'm getting a lot of under stee at autocross events any thought's on how I should adjust my coilovers?
#914 | |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Sent from my SM-G900V using Tapatalk
#915 |
Conedancer
^^^^ this.. after we learn your alignment... What spring rates are on the car.. KW changed at some point from a 7/6 to a more conservative 6/5 ??? I think.. most of us are on Square Rates.. Theres a couple of ways to loosen it up. a bigger Rear Bar is one way.. another way is up the rear spring rate.. and finally.. crank up the rear rebound. But alignment/ride height is a good place to start...
Bill
#916 |
A while back it was unclear whether a 245 or a 255 wide tire would be advantageous in the STX-class. Has this riddle meanwhile been solved or is there no answer (the answer is track and weather dependent)? What tire size are most STX-competitors running?
And a side question: A 15" rim could be an option, if the rim wasn't touching the tie rod end. There is no such thing as a flatter tie rod end, or is there? |
#917 |
Conedancer
Both 245/255 is what I have. I have 255's in the Feds and Z2's.. 245's in the Kooks.. I think 245's should be sufficient to run.. The Fed don't come in a 245.. sooooo only the 255's are available. Z2's are 255 as that is what I used last year with no issue. 245 Hankooks are the lightest of all 3. and they provide as much grip as the others in that size. If you aren't doing National level stuff then 245's should be fine.. I have to plan for different surfaces so thats why I have 3 sets of tires.. LOL.. each provide their own level of confidence depending on the weather, surface and how I am driving for the day..
Bill
| The Following User Says Thank You to Scooby South For This Useful Post: | rx3 (06-15-2014) |
#918 |
Grip>Drift
Drives: FRS
Where are you guys ordering axles from??? I'm about to snap my 2nd one!
#919 | |
Conedancer
Bill
#920 |
Grip>Drift
Drives: FRS
Damn, Subi dealer wants $399.
#921 |
Grip>Drift
Drives: FRS
I'm guessing upgraded axels are not STX legal?
#922 |
Drives:
Sorry for the change of topic...
What are you all using for camber plates? I currently have MSI, but they have a rather tall stack height forcing me to run the spring perches almost all the way down my Tarmac 2's.. and I'm not even very low at all. 25.675 fender heights all around.
My STX build thread
http://www.ft86club.com/forums/showthread.php?t=55616 |
#923 |
Drives: BMW 135i, soon to BRZ
| The Following User Says Thank You to mrazny For This Useful Post: | whataboutbob (06-18-2014) |
#924 | |
Drives: '87 Corolla GTS, '13 FR-S 6MT
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
