Sam Strano
Old 06-16-2014, 05:20 PM   #1191
qoncept
qoncept's Avatar
I finally put my crash bolts in after all this time and was very surprised at the difference. I think I'm more or less past overdriving now and just about spun each of my first few runs last weekend. I haven't had an alignment yet - I may just turn the tie rods out a thread on each side to get rid of the toe in I added and see how it feels. Or maybe just leave it.
qoncept is offline   Reply With Quote
Old 06-18-2014, 09:35 PM   #1192
ponyboy643
Drives: Subaru BRZ
Are the TRD performance parts allowed for Street Category?
Since you could ordered your FRS to come this way from the dealer could you retro-fit those parts? Would that also work if you have a BRZ instead?
ponyboy643 is offline   Reply With Quote
Old 06-19-2014, 09:25 AM   #1193
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Nope, oem performance catalog parts are not allowed. Explicitly denied in the rulebook.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 06-19-2014, 11:53 AM   #1194
vroom4
FYI: If you are at 0 toe in front. 3 turns of the 'flats' on the tie rods on both sides gets you to 1/4" total toe out. So 1 and 1/2 turns would be ~ 1/8" total toe out.
This is helpful you all worried about crash bolts install, you can do maybe 1 turn of the flat of the tie rod ends to get back to 0 toe or slight toe out.
vroom4 is offline   Reply With Quote
Old 06-19-2014, 12:29 PM   #1195
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
What did you use to find these values?
G_Ride is offline   Reply With Quote
Old 06-19-2014, 01:36 PM   #1196
markw
Drives: 2014 FR-S
You can always buy a set of toe plates, companies like longacre sell them. Not hard to get an alignment. There is also the string/jackstand method. Just ordered some bolts for mine. Going to try my hand at CS in San Diego region.
markw is offline   Reply With Quote
Old 06-19-2014, 03:30 PM   #1197
G_Ride
G_Ride's Avatar
I know about toe plates and the string method. However, you're measurements are only as good as your tools. If he's doing his own measurements, what is he using? A measuring tape? Calipers? Did an actual shop do the measurements? I'm just curious to know what he used.
Old 06-19-2014, 03:51 PM   #1198
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
My string is as good as any other shop's string! :P
The Following User Says Thank You to tahdizzle For This Useful Post:
G_Ride (06-19-2014)
Old 06-19-2014, 04:34 PM   #1199
markw
Drives: 2014 FR-S
Quite a bit depends on the shop too. There's maybe 2 shops in my area I'd trust. You can get a pretty good alignment with some basic tools. Plenty of national championship cars have string/toeplate/pvc toe gauge alignments.
Old 06-19-2014, 06:34 PM   #1200
vroom4
Toe plates and tape measures. Seriously, toe measurements are not rocket science. There might be a margin of error of less than 1/16". If you dont think that is close enough, feel free to spend 60 dollars to do what I did in less than 20 minutes.
Old 06-19-2014, 07:30 PM   #1201
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I agree. I was within 0.1 degrees of what the laser alignment machine said on my VW using toe plates and some easy Excel calculations. Some of that may just be that I drove the car between my garage and the alignment shop, so I'd say I am dead-nuts especially because of weight transfer, air pressure changes, and all the other variables that can contribute to microscopic changes in toe.
bimmer635csi is offline   Reply With Quote
Old 06-19-2014, 07:31 PM   #1202
vroom4
Yea..0.1 is the change from torquing down the nut haha.
Old 06-19-2014, 09:35 PM   #1203
G_Ride
G_Ride's Avatar
My brother uses the string method, and he's gotten pretty good with it. I haven't had the chance to use his setup. Like I said, I was just curious about what you were using.
Old 06-19-2014, 11:22 PM   #1204
powertoweight
Drives: whiteout FRS
Just got my FRS.
Been auto x-ing Miatas for several years.
Must subscribe to this thread and get reading all 55 pages!
Great info
My first post here.
powertoweight is offline   Reply With Quote
The Following 2 Users Say Thank You to powertoweight For This Useful Post:
DylanFRS (06-24-2014), Kido1986 (06-20-2014)
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 06:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 01:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 09:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 02:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 11:03 AM
