#1191 |
I finally put my crash bolts in after all this time and was very surprised at the difference. I think I'm more or less past overdriving now and just about spun each of my first few runs last weekend. I haven't had an alignment yet - I may just turn the tie rods out a thread on each side to get rid of the toe in I added and see how it feels. Or maybe just leave it.
#1192 |
Drives: Subaru BRZ
Are the TRD performance parts allowed for Street Category?
Since you could ordered your FRS to come this way from the dealer could you retro-fit those parts? Would that also work if you have a BRZ instead? |
#1193 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
Nope, oem performance catalog parts are not allowed. Explicitly denied in the rulebook.
#1194 |
FYI: If you are at 0 toe in front. 3 turns of the 'flats' on the tie rods on both sides gets you to 1/4" total toe out. So 1 and 1/2 turns would be ~ 1/8" total toe out.
This is helpful you all worried about crash bolts install, you can do maybe 1 turn of the flat of the tie rod ends to get back to 0 toe or slight toe out. |
#1195 | |
Drives: Some kind of Subaru
#1196 |
Drives: 2014 FR-S
You can always buy a set of toe plates, companies like longacre sell them. Not hard to get an alignment. There is also the string/jackstand method. Just ordered some bolts for mine. Going to try my hand at CS in San Diego region.
#1197 |
I know about toe plates and the string method. However, you're measurements are only as good as your tools. If he's doing his own measurements, what is he using? A measuring tape? Calipers? Did an actual shop do the measurements? I'm just curious to know what he used.
#1198 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
My string is as good as any other shop's string! :P |
| The Following User Says Thank You to tahdizzle For This Useful Post: | G_Ride (06-19-2014) |
#1199 |
Drives: 2014 FR-S
Quite a bit depends on the shop too. There's maybe 2 shops in my area I'd trust. You can get a pretty good alignment with some basic tools. Plenty of national championship cars have string/toeplate/pvc toe gauge alignments.
#1200 | |
#1201 |
Drives: 2013 Cayenne turbo
I agree. I was within 0.1 degrees of what the laser alignment machine said on my VW using toe plates and some easy Excel calculations. Some of that may just be that I drove the car between my garage and the alignment shop, so I'd say I am dead-nuts especially because of weight transfer, air pressure changes, and all the other variables that can contribute to microscopic changes in toe.
Chris
Track, Autocross & Daily Driver build thread - SOLD Another A&DD for my VW GTI - SOLD And finally, my YouTube channel |
#1202 |
Yea..0.1 is the change from torquing down the nut haha.
#1203 |
My brother uses the string method, and he's gotten pretty good with it. I haven't had the chance to use his setup. Like I said, I was just curious about what you were using.
#1204 |
Drives: whiteout FRS
Just got my FRS.
Been auto x-ing Miatas for several years. Must subscribe to this thread and get reading all 55 pages! Great info My first post here. |
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
