Old 05-08-2014, 10:26 PM   #113
J_kennington
Drives: 2013 asphalt scion FRS
I finally got it to work. Pretty cool software.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 05-30-2014, 05:19 PM   #114
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
Ok got the cable, software, what exactly do I write in the env folder?
NeedsmoreCowbell is offline   Reply With Quote
The Following User Says Thank You to NeedsmoreCowbell For This Useful Post:
Rio (06-15-2014)
Old 06-02-2014, 01:42 PM   #115
MarcusM117
So my car is flashed with OFT... Has anyone had any issues connecting? Or do I have to flash to stock.
It connects but no parameters are found.
Using Techstream 9.00.025
~2013 Scion FR-S~
~2004 Honda CBR600RR~
~Skip Barber Grad~
MarcusM117 is offline   Reply With Quote
Old 06-15-2014, 11:21 PM   #116
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
What is it with this edit the VerApp.ini that NO ONE provides the mysterious "edit" for? This is what mine reads:
[Version]
Version=9.10.017
Date=2014/03/18
And the file is in the C:\Program Files (x86)\Toyota Diagnostics\Techstream\bin directory.
Any help on EXACTLY where to enter that mysterious serial # would be great.
Rio is offline   Reply With Quote
Old 06-16-2014, 10:47 AM   #117
J_kennington
[Version]
Version=9.10.017
Date=2014/03/18
You don't have to edit it if I remember correctly. What OS are you running on the laptop? When I get off in 6 hours I can walk you through exactly what I did. Including bypassing the drivers for windows 7-8 if you got xp drivers with yours.
2005 Yamaha yz250f
The Following User Says Thank You to J_kennington For This Useful Post:
Rio (06-16-2014)
Old 06-16-2014, 09:12 PM   #118
Rio
Rio's Avatar
Windows 7. My problem is the serial number I think. The driver's I'm 90% sure I installed correctly.
Old 07-10-2014, 02:25 PM   #119
boomslang
Drives: Toyota
Can you add new TPMS sensor IDs using this cable and Techstream?
boomslang is offline   Reply With Quote
Old 07-17-2014, 08:53 AM   #120
unlimited86
Drives: s2000
Does anyone know if you can use this with a Bluetooth adapter instead of cable?
unlimited86 is offline   Reply With Quote
Old 07-17-2014, 09:19 AM   #121
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
The bluetooth adapters you're thinking of are ELM327 and this requires capabilities that those adapters don't provide.
A Tactrix OpenPort 2.0 is the best option and you can use it for standalone logging and flashing as well.
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
unlimited86 (07-18-2014)
Old 08-11-2014, 08:39 AM   #122
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Been running v9.00.025 since release with no problems, any reason to update to latest version?
Any kind of added features or enhancements?
FyeaFRS is offline   Reply With Quote
Old 08-11-2014, 08:40 AM   #123
FyeaFRS
Yes you can
Old 08-27-2014, 09:23 AM   #124
FyeaFRS
Has anyone successfully used Techstream to program TPMS sensors on a BRZ?
I tried and got an error which I have a screenshot saved somewhere..
It found the ECU, it just came up as a Scion/FR-S/2013/FA20 and VIN. But after entering the 4th code it gave some error about initialization something or the other..
Old 08-27-2014, 09:45 AM   #125
Foobar
SLO NO MO
Foobar's Avatar
I have not found any way to get the sensor ID's to save to the car using techstream using a mini-VCI cable from Taiwan. Maybe it works with a legit Toyota cable, I don't know. I eventually just got a TPMS tool for $150 to do my winter/summer swaps.
Old 08-27-2014, 11:13 AM   #126
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Which tool did you get?
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 01:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
