#435 | |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
![]() Especially when it comes to 4 cylinder engines. But with a 6/8/12 cylinder it's a different story for me. Just look at the new 911 S, 3.8l with 400hp/325tq in a 3,200 lb body. |
#436 | |
86 Member
#437 | |
Drives: N/A
The 2012 civic has a 2.4L too though, so even though it makes the same HP at the same peak RPM, it doesn't have GDI so the output per displacement is not the same. The older K20 made 200HP at closer to 8k RPM. |
#438 | |
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
#439 |
Kuruma Otaku
^ Keep it in perspective. The best of the old is usually better than the first of the new.
The D4-S is going to scare a lot of traditional Subie 'tuners' and they may go EJ and start off with claiming the EJ is better, blah, blah... But once a couple serious guys get a hold of an FA and figure out what they're doing and what it's capable of, it'll likely surpass the EJ.
Because titanium. |
#440 | |
Rocket Bunny FRS
#441 |
Glorious BRZ Master Race
Drives: Subaru Libird
Is it speculation? I thought it's been announced that the USDM-only exhaust will yield a few more horsepower.
#442 | |||
Drives: Matte Black STI
The K20 engines make great HP with a few goodies. I have seen 220WHP from them, which is outstanding! Even a few 250 WHP cars with cams and 9000RPM. |
#443 | |
Hot Dog
Drives: quicker than arghx7
Both Scion and Subaru put "200HP" and "100HP/L" respectively in their official press releases for the USDM cars during the MSRP releases. <--click the links, they have the official press releases within them.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#444 | ||
Drives: N/A
![]() The only difference that I am aware of for the USDM exhaust is a smaller TIP(read no fartcans) due to noise restrictions. I dunno about the more HP part, that was a rumor last I heard. |
#445 |
Drives: '06 AM V8V Coupe
Er, Allch Chcar I think you got it wrong, in Japan the exhaust is quieter and more restrictive due to noise regulations, in America the tip is smaller because crash safety or something says you can't have the exhaust sticking past the bumper.
#446 |
Drives: N/A
Where'd you hear that info?
#447 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Some quick math...
HP = (TQ*RPM)5252 So here are some numbers: 150 ft lb @ 8500 rpm = 243 hp 150 ft lb @ 8000 rpm = 228 hp 150 ft lb @ 7500 rpm = 214 hp 150 ft lb @ 7000 rpm = 200 hp Same thing for 155ft lb 155 ft lb @ 8500 rpm = 251 hp 155 ft lb @ 8000 rpm = 236 hp 155 ft lb @ 7500 rpm = 221 hp 155 ft lb @ 7000 rpm = 207 hp Same thing for 160ft lb 160 ft lb @ 8500 rpm = 259 hp 160 ft lb @ 8000 rpm = 244 hp 160 ft lb @ 7500 rpm = 228 hp 160 ft lb @ 7000 rpm = 213 hp Same thing for 165ft lb 165 ft lb @ 8500 rpm = 267 hp 165 ft lb @ 8000 rpm = 251 hp 165 ft lb @ 7500 rpm = 236 hp 165 ft lb @ 7000 rpm = 220 hp 165 ft lb @ 6500 rpm = 204 hp To be be realistic about a 2.0L NA engine, consider the following: - It's not going to make much more than about 165 ft lb of torque, just looking at what's out there. A beams 3SGE makes 162 ft lb with 11.5:1 c/r with the same bore & stroke. The FA20 c/r is higher, and DI should allow for more timing advance. But essentially this is what a NA 2.0L I-4 can do (maybe 170?). - To make good power it needs to keep that torque going into the high RPM range. . So for a hypothetical modified FA20, let's say we can bring the peak torque to about 165 ft lb and being able to hold onto much of that beyond 7000: 165 lb ft (100% of peak) @ 6500 = 204 hp 160 lb ft (97% of peak) @ 7000 = 213 hp 155 lb ft (94% of peak) @ 7500 = 221 hp 150 lb ft (91% of peak) @ 8000 = 228 hp This is what I have in my mind for an NA modified FA20 (breathing mods and tuning, +500 rpm) So 225-230 hp is probably what's possible without a crazy redline. With 9000 revs, then even 145 lb ft gets you to 248 hp. With serious cams, that number can go over 250 hp. IMHO, if the parts come out to get the NA FA20 to 230+ hp that would be a very tempting option ![]() Although I am still thinking that the Rotrex kit will be my preferred poison. something like 190-200 lb ft at around redline, still with that crisp NA-like transient response ![]() That said, I myself am happy it's NA. I can do bolt-on NA mods, or do a Rotrex, or whatever I want. I am just glad they didn't stick us with a turbo It sounds like the "character" of this engine is just right, and a few mods will help erk out some more.
#448 |
Techmology.
Drives: Scrapped project EH2
^Agreed %100.
Perhaps they (subaru or toyota) will come out with a turbo'd version at some point, but I, personally, am very glad it was designed as NA from the get go. Makes the options a little more exciting for the tuning community, IMHO. I've stated it before and I'll state it again, I'm really REALLY hoping that variable lift gets added in later on - it could make for a very streetable powerband with even more room for high rpm breathing. |
| Happy Thanksgiving!!! | S2KtoFT86 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 11-27-2010 06:01 AM |
| Happy Holidays, all | White Comet | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 02-12-2010 07:45 AM |
