Old 06-15-2014, 02:58 PM   #6217
jflogerzi
jflogerzi's Avatar
@fenton Is the July batch sold out? Tried getting a hold of Rob via PM without a response.
Old 06-15-2014, 04:30 PM   #6218
DAEMANO
Time Traveller
Originally Posted by Sojhinn View Post
Maybe. Ride is fantastic. Can't wait to see your coilover setup.
@Sojhinn & @jflogerzi
Had the coils installed yesterday @F-T in Gardena, CA (thx much Alex!). He was quick, thorough, knew both the car and the product, had great communication and flexibility. This is a no frills old school shop but for new school cars that delivers. Also recommended an amazing joint to eat at while I waited (The Pan in Gardena).
Initial ride height was about .5" front to back higher than expected. Drove around quite a bit yesterday. They settled overnight and now I'm dropped at 1.4" front and 1.6" rear. New wheels coming after extended stud install. Will post pics after that.
My initial impressions are here, re-posted for convenience.
Originally Posted by DAEMANO View Post
@ultra and @Moto-P
Thanks both of your generous detailed posts and insights, yesterday I finally upgraded my RS-R SuperDown Springs to RS-R Sports-i Moto Spec Coilovers. Impression? So far, so great. Will add camber or crash bolts and wait 1 week before an alignment. Initial ride height was about .5" above spec, now is almost dead on Moto-spec. Will measure again soon.
For touring
The road comfort is very nice. They do make the car feel like it has a suspension from a more expensive car. Low speed comfort is good, however high speed comfort is greatly improved. Almost no oscillation over infamous L.A. area expansion joints. Planted, assured, and comfortable.
Spirited driving
The stroke improvement is incredible. I live in Southern California where the roads are pretty bad (even on the highways). Long sweeping turns full of bumps and broken pavement that used to unsettle the rear end now feel like they have full traction and I haven't felt the bump stops at all. At speed nothing but firm and in control. I also have noticed a slight handling bias from the previous FR-S oversteer, to the mild BRZ understeer. I'm sure this keeps street drivers quite safe. Will see if it's for me and adjust if necessary using @ultra 's recommend minor front toe out setting.
Track
Impressions after the alignment. @Moto-P When is the next '86 academy?
Old 06-15-2014, 04:30 PM   #6219
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
Originally Posted by fenton View Post
Looks like that shell gas is holding you back a bit on your multiplier. Your logs are showing .91 once loaded up.
Damn good boost you are getting with the 1.5 pack you are trying
Ill Fil up with the 94 for a few tanks and try another log, see if that helps
If you have to suffer with 91 pump (like both myself and @WRB5titch in Califonia have), dropping your IAM below 1.0, Torco Accelerator has been a godsend. About 10 oz will get you from 91 octane to 93 octane. More can bump you up as high as 105. Costs are roughly + $7-$10 per tank that can be felt. Search around the net (here's one result fromNASIOC), results are generally very positive.
Canada distributors
http://torcoracefuel.net/dealers.html#Canada
Good to know, I will look into getting some of this to play with.
Bu-Tang is offline   Reply With Quote
The Following User Says Thank You to Bu-Tang For This Useful Post:
DAEMANO (06-15-2014)
Old 06-15-2014, 04:52 PM   #6220
DAEMANO
Time Traveller
You won't be dissapointed. Also, don't know if this matters in Canada but it kills the crickets in my car we get in California caused by the ethanol in CA91 pump gas (which is roughly e10)
Old 06-15-2014, 05:22 PM   #6221
fenton
Not that I know of. There is at least 5 people on the waiting list.... maybe even more I haven't dropped by Rob's shop for a bit.
I'll see if I can find out and let you know this week.
fenton is offline   Reply With Quote
Old 06-15-2014, 07:49 PM   #6222
radroach
Drives: car
wow your autox course is beautiful!
Old 06-15-2014, 11:01 PM   #6223
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Question - does our MaP sensor top out at 4.5 lbs of boost? Looking at some older logs right after I installed the 1.5x battery kit it looks like it is peaking at a solid 4.5 lbs which tells me thats the max the sensor reads. Is this true?
nlowell is offline   Reply With Quote
Old 06-15-2014, 11:16 PM   #6224
WRB5titch
Drives: WRBrz
I've gotten 4.9 lbs at around 2-3k rpm on one of my logs, so I don't think so
Sent from my Nexus 7 using Tapatalk
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 06-16-2014, 12:39 AM   #6225
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Nice! Ive been enjoying my suspension as well. Its funny I feel the same way about how the ST suspension feels on the big bumps, and the reason why I switched away from the lowering springs.
Im going to vegas this week, so Im getting my alignment done tomorrow.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
DAEMANO (06-16-2014)
Old 06-16-2014, 12:44 AM   #6226
DC2R
Drives: 2014 Scion FR-S
Funny in in las Vegas right now from Miami
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 06-16-2014, 01:00 AM   #6227
Sojhinn
Sojhinn's Avatar
Be there on Tuesday with my car. Looking forward to the drive.
Installed Mods:
Old 06-16-2014, 01:14 AM   #6228
fenton
stock is a 1.5 bar map sensor. this means it should be able to read .5 bar worth of boost.
most I have hit is 4.8 or so.
4.5 with the 1.5 dunno it's very good. The to end is where the 1.5 really helps though.
The Following User Says Thank You to fenton For This Useful Post:
nlowell (06-16-2014)
Old 06-16-2014, 01:23 AM   #6229
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
The OEM Map sensor only reads to about 5 pounds of boost, that equates to about a 1.37 bar map sensor. So it is not truely a 1.5 bar map sensor.
Cheers,
William Knose
The Following 5 Users Say Thank You to DeliciousTuning For This Useful Post:
fenton (06-16-2014), nlowell (06-16-2014), raven1231 (06-16-2014), Sojhinn (06-16-2014), VR46 (06-16-2014)
Old 06-16-2014, 01:31 AM   #6230
nlowell
nlowell's Avatar
Thanks...looking at some logs from tonight, I actually recorded a 4.79 at 2,835 RPM. The only problem is my AFR at that RPM was 18.03:1...
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
