| Member's Car Journals Car journals by our members. |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
My 2JZ Build - Last post w/ dyno (565whp/435wtq) updated 14 Apr 16
Decided to move the most up to date stuff to the front so you guys can have instant gratification.
Video link: [ame="https://www.youtube.com/watch?v=T5TlX4h4p5o"]2JZ FRS - Start Up +mod list - YouTube[/ame] https://www.facebook.com/trustautomo...type=2&theater Mod list - Updated 18 Feb 15 2JZ-GTE / V160 Swap - 2JZ FRS All custom fabrication, wiring and tuning done by Trust-Automotive in Chesapeake, VA Engine - Built by Magnum Machine in Chesapeake, VA
Turbo & Intercooler
Fuel System
Cooling System
Drivetrain
Engine Management & Wiring
Wheels, Tires & Suspension
Interior
Exterior
Parts Unused Currently: PHR Oil Filter Relocation Kit Current state
![]() ![]() ![]() ![]() The Following was my first post Hi. Not new to the forum, but lurked for a while. Was originally in the market for a Supra but the wife liked the FRS better ***I know***. Anyways, I bought the FRS back in April 2013 and slowly learned as much as I could before purchasing anything. Haven't told many people, but, I decided to do a 2JZ swap. There's a LOT left in this build, hell the FA20 is still in the car, but it's moving faster now. I purchased my 2JZ/V160 setup almost a month ago and I've been tearing it down to put goodies on it. First brought it home ![]() First time washed ![]() Detailed and OptiCoat by Garry Dean ![]() Another shot (blacked out headlight housings were done a few days before) ![]() Side shot after detail/OC ![]() Ok, it's a new car, not much to look at, but I wanted to preserve the paint as best as I could. Moving along... Picked up some KW v3's, Raceseng CasCam plates, Raceseng shock tops, B2 20mm(f)/25mm(r) spacers and SPL LCA's, no pics of LCA's/spacers, but they're pretty billet. Friend Ross at Trust Automotive installed my suspension. Props! ![]() ![]() Also bought some interior pieces. All black from the EU GT86 spec, as well as Raceseng slammer knob and reverse lockout. ![]() I think that does it for looks for now. Suspension handles very well, but not extremely noticeable compared to stock. Stock works great in this car! So, then I bought my 2JZ/V160. Buddy Ryan from Mike Balf racing helped source and even helped me pick up the motor! Four hour drive! ![]() At this point, I was taking the manifolds off just to clean the head better. I took off the exhaust manifold to see the valves: ![]() I wanted to just clean/replace the seals, but ultimately I decided to do some more. Who knows what else will change in this setup, but it's happening and all I can do is move forward now! Thanks! Last edited by slicktop; 04-20-2016 at 01:21 PM. Reason: Updated Last Post 07 Apr 16 |
#2 |
Couple of these are starting! LOVE it!
#3 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Sexy. ID2000s are pretty beefy, I was using 1000's and still had room for play at 600WHP, what are your goals with this?
#4 |
Drives: FRS, M3
This is something I need to see
#5 |
Drives: 2013 Fr-S
I hope someone actually finishes one of these. All the swapped 86s are shop cars. I really can't believe no one has made conversion parts yet. The market will be huge.
#6 |
Drives: AE86
frs 2jz
Portland speed industries can handle all your conversion needs.
tunedbypsi.com |
#7 |
Deep 9s. I chose the 6466 because I got a good deal on it and I'm holding out on the rear end for a little bit because of the cost. I'll be working on this in stages. First stage is getting it all in, second stage is build rear end, cage, bigger turbo, nitrous.
#8 |
Drives: 2013 WRB BRZ
This is going to be epic.
#9 |
Drives: 2014 Scion FRS
more pics! more pics!!
#10 |
Drives: 2013 Whiteout Scion FR-S 6MT
Sub'd
#11 |
Drives: 2013 Subaru BRZ
subscribed for cool jz stuff
#12 |
EndlessClouds
Drives: 2013 Scion FRS
subd. looking forward to when you are done!
Take your dreams and smash it!
#13 |
New plates came in
![]() I suppose I have to finish it now... |
#14 |
Drives: 2013 Raven FRS MT
You've caught my attention.
| Tags |
| 2jz, 2jz brz gt86 frs swap, 2jz frs, 2jz frs swap, 2jz swap |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
| Mr and Mrs FR-S Build | jaydee_do_work | Member's Car Journals | 2 | 12-04-2013 09:51 AM |
| 86 BUILD, AUS | JS86JS | Member's Car Journals | 9 | 05-31-2013 08:59 AM |
| My build... well some of it | cruzinbill | Electronics | Audio | NAV | Infotainment | 41 | 04-01-2013 04:02 PM |
| STX build | Evil86 | Tracking / Autocross / HPDE / Drifting | 2 | 01-08-2013 03:40 PM |
