Old 06-13-2014, 07:50 PM   #477
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by protpibe View Post
Avo makes a throttle input controller to speed it up if you want. It's adjustable
Sent from my HTC One using Tapatalk
Thanks, but I'd rather not add extras when I already have something that can control that.
Old 06-13-2014, 07:51 PM   #478
onzippy
Drives: 2014 FRS
Originally Posted by Calum View Post
Factory tunes idle a little higher when coasting to aid in clutch engagement. Bill tends toward a very factory feeling tune so I'm pretty sure he has kept that feature in the tune on purpose.
None of hot target idles in the base ecutek rom files are over 1K. And I was talking about at a complete stop so... just sayin' .... it isn't oem.
onzippy is offline   Reply With Quote
Old 06-13-2014, 09:45 PM   #479
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Bill, is there anyway we could have a map with more aggressive throttle mapping and little thing like the high idle turned off? I understand that its a point of pride to have all of your maps feel like an OEM map, but to be completely honest I sometimes miss the throttle response from my old Visconti tune. when I'm out having fun it made the car work with me a lot better.
Not a problem. We can setup a faster throttle response and it can be customized per map. So if you want an aggressive map on say 3 and 4 and a standard daily map on 1 and 2 like you have now we could do that.
Everyone wants there own setup and I have no problem adjusting it.
Cheers,
William Knose
Old 06-13-2014, 09:48 PM   #480
DeliciousTuning
Originally Posted by onzippy View Post
Well that's no so bad all. I think it's something in the tune and I noticed it also. With an auto it's exacerbated by the fact you have no clutch to push in so it tugs a bit more in drive. I think hot idle is supposed to be around 750 with all acc. off.
Thanks for the updated. Sounds positive.
We have seen the Auto's exhibit a little more load on the engine and in doing so have a tendency to want to drop the RPM's a little faster and die a little more easily. It is something we are working on making a little smoother.
Cheers,
William Knose
Old 06-13-2014, 11:01 PM   #481
makesdrivingfunagain
I have a stock automatic FR-S and I mean 100% stock. I would like to consider a tune for this, as it has nearly 10k miles. I run it on 91 octane in CA and need to pass smog (legally). I am not sure if this would void the warranty either. It is a daily driver so I also need reliability. I was wondering if you offer any tunes for me. And how much hp and torque I could expect to gain. This is a street car. Thanks!
makesdrivingfunagain is offline   Reply With Quote
Old 06-13-2014, 11:48 PM   #482
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
My brother has been driving my car for the past week while I was out of town on the E85 map. I only got to drive it myself tonight for the first time with E85. I'm running the Innovate supercharger, intercooled, with the 70mm pulley. On 93 octane there have been some issues that Bill is working on to staighten them out. My brother isn't too familiar with driving my car so it was hard for him to tell a difference. All I can say is my car is ridiculous with Bills E85 tune. It is such a smooth power delivery through the entire rev range. Not only that but JESUS the pull this car has now is insane. I really don't see how this tune can be improved upon but if anyone can do it, Bill is the man. I can't wait to get down to a dyno to see what kind of numbers I put down.
One question though to anyone that can answer. Maps 1 & 2 are both 93oct, Map 3 is E60, and Map 4 is E85. Every time I turn my car off, it automatically defaults back to Map 1 instead of staying on Map 4. Is this the norm or did I do something different? Thanks guys!!
Dustin is offline   Reply With Quote
Old 06-14-2014, 03:05 AM   #483
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
there's a start up trick to get it to keep maps - turn car to acc let it sweep the gauges turn off then crank the car - bill posted a video in the ecu tune section, I'm mobile otherwise I'd link it for you.
mikalem is offline   Reply With Quote
Old 06-14-2014, 03:20 AM   #484
DeliciousTuning
[ame="https://www.youtube.com/watch?v=V6wwv46hZN8"]https://www.youtube.com/watch?v=V6wwv46hZN8[/ame]
Cheers,
William Knose
Old 06-14-2014, 03:23 AM   #485
DeliciousTuning
We offer a couple options including our Stage 1 for 91 octane.
http://www.delicioustuning.com/Stage_1_PumpGas
We also offer a switchable map so you can run E85 also. The E85 on a stock setup actually makes over 200+ whp. Here is a little more info on that also.
http://www.delicioustuning.com/Stock..._Breaks_200whp
Of course with an auto, it will not make quite as much but still a vast improvement on E85. And on 91 octane you will still notice the difference.
Cheers,
William Knose
Old 06-14-2014, 08:14 AM   #486
Calum
That Guy
Cheers,
William Knose
Would you like me to submit a ticket, or email you about this? I know you were swamped before and weren't able to keep track of requests from the forum?
If this is is fine, my engine is bone stock except for a drop in filter, and I'm stuck with 91 octane gas. I'd like your standard throttle map, and traction control, on map 1 with. And map 2 to have faster throttle response, flat foot shift, and launch control.
Thanks!
Old 06-14-2014, 01:39 PM   #487
Thanks for your response!! I will definitely consider this, as tunes work...!
Old 06-14-2014, 11:52 PM   #488
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Mine does this as well
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 06-15-2014, 08:01 PM   #489
DeliciousTuning
Thanks!
Just send me an email.
As for the auto's that want to drop a little more on RPM's when they come to a stop. This is something I am working on especially for your supercharged guys as they have the most load on the engine wanting to cause a stumble at idle. Note this will be worse with the AC and lights on.
If you would like to see what is actually happening, watch your battery voltage when you turn on the AC, lights and come to a stop with an auto with or without the supercharger. You will see the battery voltage will actually drop down to ~12 (maybe even dip into the 11's) volts where it should stay around 13+ (close to 14) volts to be able provide enough power for the vehicle to run properly.
That much of a draw on the alternator causes the car to want to stumble at idle. So though it might be able to fixed through the tune the amount of amps drawn on the entire system is causing the idle drop. So trying to figure out a proper way to keep things running smoothly.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Calum (06-15-2014)
Old 06-16-2014, 10:49 AM   #490
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
What are you setting idle at?
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
