Old 06-13-2014, 02:20 PM   #71
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Originally Posted by 355rockit View Post
That log looks crazy as hell... I'd be interested in seeing another.
Try doing a third gear pull with 100% throttle and start/stop logging as soon as you can before/after the pull.
Alternatively you can just trim anything before and after the pull by editing the .csv in excel.
alexand3r is offline   Reply With Quote
Old 06-13-2014, 02:23 PM   #72
s2d4
s2d4's Avatar
A full range would be much better, not just WOT in third.
Old 06-13-2014, 02:42 PM   #73
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
@355rockit
How long was it, after the tune, before you captured this log?
Also, did you let the car idle for a minute or so after tuning?
Old 06-13-2014, 03:26 PM   #74
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Originally Posted by alexand3r View Post
@355rockit
Car idled 5 minutes after a completing flash. Logging was started not long after that. Pulls strong.
355rockit is offline   Reply With Quote
The Following User Says Thank You to 355rockit For This Useful Post:
alexand3r (06-13-2014)
Old 06-13-2014, 05:04 PM   #75
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Cool, it's probably still learning. Maybe try pulling another log after a few more drive cycles.
Old 06-13-2014, 05:39 PM   #76
phrosty
Since flashing to B01, i have not noticed a that initial pedal lag after flashing with OFT. Anyone else have a similar experience?
phrosty is offline   Reply With Quote
Old 06-13-2014, 09:59 PM   #77
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
I don't know what to say. It appears your AFR is running dangerously lean or so it appears to be.
Like some others have mentioned run another log now that you have given it more time to learn. Make sure your foot is all the way down at full throttle and you need to take it all the way to red line 7200k rpms. Don't stop at 6k. Post the new log for another review.
I cant imagine your TRD intake is leaning the car out that much. If he is running stg 2 I can't imagine the header is contributing. If anything it would be more rich with that cat I suspect.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 06-14-2014, 01:38 AM   #78
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Why wont my manger connect to my oft shiv?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 06-14-2014, 01:40 AM   #79
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I would suggest trying another USB port. Or if that doesn't work, another computer. It definitely should connect as long as there are no port conflicts with your computer. The OFT is pretty communication friendly.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
sosick (06-14-2014)
Old 06-14-2014, 02:16 AM   #80
sosick
fastest frs in sbg
sosick's Avatar
Got it
2014 firestorm frs
Old 06-14-2014, 02:18 AM   #81
steve99
Drives: FT86
Yep that log is rearly strange
AFR up to -20 or more under load
Advance multiper 0 to -5
VVT exhaust cam hardly changing
Something is way wrong maybe OFT firmware not matching OFM, does not seem to be a credible log
Old 06-14-2014, 02:41 AM   #82
s2d4
s2d4's Avatar
he didn't get a proper log and just copied the column label from someone else expecting to be the same.
the problem is that what he copied from isn't the same as what he actually logged.
Old 06-14-2014, 03:11 AM   #83
steve99
Drives: FT86
Thanks,
That makes more saense
Thought I had one to many Rum's last night
Old 06-14-2014, 03:28 AM   #84
355rockit
I had asked you how to get the labels and you said 'it is in the same place as the oft software...'. Wasn't so... didn't have time to f* with it so I copied headers from another log that appeared default OFT log. I am out... got too much other things to work on. If you have more time to give me proper instruction on how to get the headers to show up, I can provide another log when I have time.
Openflash manager data display problem. mid_life_crisis Software Tuning 6 05-14-2014 10:22 AM
OpenFlash Tablet: Multi-Gauge Function and FLKC logging Shiv@Openflash Software Tuning 52 05-08-2014 09:30 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 07:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 11:02 PM
