Old 06-12-2014, 08:36 PM   #4747
Powersfrs
Drives: Frs
Originally Posted by CK_Bladesmith View Post
And a new clutch lmao.
Mah no need for a new clutch this supercharger makes no power at all for that!
Powersfrs is offline   Reply With Quote
Old 06-12-2014, 11:24 PM   #4748
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hey All,
Just to show we are testing the hiccup under cruising conditions at 5000 RPM's with the 70mm pulley, here is a picture. We just finished our tank of E85 today and filling up with 91 octane tomorrow morning. Pay no attention to the other gizmos in the picture.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
CK_Bladesmith (06-12-2014), Dustin (06-12-2014), mikalem (06-13-2014)
Old 06-13-2014, 09:05 PM   #4749
DeliciousTuning
Originally Posted by mikalem View Post
I have spoken with Bill and got him some logs while the car was exhibiting the behavior - he has a hunch it has to do with the 70mm pulley and/or 100% DI so he's ordered one in. He's expecting to get that on the shop car to review and see if he can reproduce the behavior targeting early next week. Hopefully that will yield some good information and perhaps an adjustment! <crosses fingers>
OK, so I finally got most of the E85 out of my tank and I am on a ~E20 mix though on a pure 91 octane tune. So there is a chance the ethanol is still mixed in and allowing the tune to run well in this scenario (sort of like octane booster). The only reason I state this, as I can not reproduce the problem and have tried on my way in and out of work, lunch and just driving around in general.
So next it to burn through this tank of gas and then fill up with 91 octane again. This should give me a more pure 91 octane (10% ethanol) which I can hopefully reproduce the problem.
Just an update to try and reproduce the problem. Some questions for those who have this missfire issue at 5k under light load, with the 70mm pulley and 91 octane.
1. Which intercooler are you using? FA20 or Innovate?
2. Which exhaust system is on the vehicle?
3. What octane rated fuel and brand fuel (Mobil, Shell, etc..) are you using?
4. Which intake is on the car? (Stock, Perrin, Airaid)
Thanks,
William Knose
Old 06-13-2014, 09:29 PM   #4750
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Thanks,
William Knose
Innovate intercooler here
Rev works UEL header, perrin OP, perrin FP, perrin 3" CB
93 octane chevron/shell
Airaid intake/ nameless intake pipe.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 06-13-2014, 09:54 PM   #4751
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Thanks,
William Knose
1. innovate
2. p&l header/ overpipe/ midpipe Perrin 2.5 resonated cat back
3. shell 93/ Kroger E85
4. Stock
mikalem is offline   Reply With Quote
Old 06-13-2014, 09:56 PM   #4752
mikalem
mikalem's Avatar
Also, mine didn't do it at the top of heading towards 93 - I could reproduce it effectively with around 1/2 to 1/3rd tank (that's when the logs I gave you were taken)
Old 06-13-2014, 09:58 PM   #4753
CK_Bladesmith
Drives: Raven FR-S
Let's not forget that horrendous stutter while cold around the 3k range with light throttle acceleration/no boost. I'm thinking that's just the bypass valve being retarded while cold but I could be wrong.
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
Old 06-13-2014, 10:14 PM   #4754
DeliciousTuning
I will need to watch for this while I am on 91 octane. Once again didn't notice this on the 75mm pulley. But will see what it does now on the 70mm pulley.
Old 06-13-2014, 10:15 PM   #4755
CK_Bladesmith
Drives: Raven FR-S
When I switched to the 75mm pulley from the 70mm it certainly didn't do it nearly as bad, but it still did it.
Old 06-13-2014, 10:27 PM   #4756
DeliciousTuning
Really interesting. I am going to verify all this with the 70mm, but I have not really noticed any of this and I usually drive off almost after tuning my car on. I know I should let it warm up but I do not.
Is it more noticeable in lower gears, say 1st or 2nd?
Old 06-13-2014, 10:53 PM   #4757
CK_Bladesmith
Drives: Raven FR-S
1st gear not really, 2-6 is extremely noticeable if you're trying to accelerate without going into boost. I'm talking maximum fuel economy takeoffs.
I really think it's due to the fact that while not boosting, the air is channeled through such a small hole, and when you give it just enough gas, or not enough, the vacuum/throttle controlled bypass valve kinda freaks out, causing the stuttering.
It's only really severe while cold, but once normal operating temps have been reached it's waaaaay less pronounced.
If you really wanna test it take the car for a highway ride and set the cruise at 75mph. Of your engine isn't totally warmed up it's gonna stutter like crazy IF you, say, climb a slight knoll such as an overpass. While the terrain is flat it's deliciously smooth, bit small hill climbs will trigger it, I think, due to the fact that it needs to boost based on the position of the throttle.
Feather the throttle and you will see. Try not to go Into boost as long as you can and it will pop up.
DeliciousTuning (06-13-2014)
Old 06-13-2014, 11:56 PM   #4758
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
1. Innovate
2. Nameless header and full 3" exhaust
3. 93, whatever is closest, Shell, Chevron, Mobil, ect.
4. Stock
Dustin is offline   Reply With Quote
Old 06-14-2014, 03:29 AM   #4759
DeliciousTuning
Originally Posted by Dustin View Post
1. Innovate
4. Stock
1. innovate
4. Stock
Interesting, those that have posted all have headers and some sort of exhaust and I am running a stock exhaust. Thanks for those who posted. May not mean anything, but something interesting.
Cheers,
William Knose
Old 06-14-2014, 08:58 PM   #4760
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Finally!
48 weeks of waiting. Two weeks of a couple hours here and there. And one marathon session today. Finally, it's together!
And look! A left over part!
In this case, it's a good thing.
You know what's F***ING delicious after working for hours in the sun? Water.
I hope I never get hit in the front left corner. There are so many freakin' hoses and lines there now.
I still have one wire to run then it's just a matter of getting a hook-up from Delicious and I'm in business!
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
mikalem (06-14-2014), sato (06-14-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
