Old 06-13-2014, 04:52 PM   #1639
wootwoot
Drives: FRS
Picked up a set of Racecomp T2's with 450lb springs. The car is mostly a daily driver that will be seeing the track this season. Lowered under an inch.
1. Was going to run PSS for tires. What size would be good? I was thinking 225...
2. Would I be better suited to buy 400lb springs given my application?
3. Was planning to go with -2 front and -1.5 rear with 0 toe. Does that sound acceptable?
Old 06-13-2014, 04:58 PM   #1640
Racecomp Engineering
1. We ran 245s with good results.
2. Try the 450s first.
3. A little more camber will make you happier on the track but you start seeing a little more uneven wear past -2. I'd be happy with -2.25 front and -1.8 rear for a mostly daily driver some track.
Enjoy!
- Andy
Old 06-13-2014, 05:09 PM   #1641
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
Originally Posted by Marchy View Post
Thanks Andy! and by a little bit of toe, are we talking positive? (like 0.01 or 0.02)
toe out in the rear is generally a very bad thing, it makes the car unpredictable and perhaps dangerous. you usually always want a little bit of toe in in the rear to add stability.
a textbook exception is old porsches with trailing arm rear suspensions... the rubber bushings would flex and allow the outer rear wheel to toe out under braking... an experienced driver could use this to help get the car to rotate on corner entry.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
The Following User Says Thank You to SomeoneWhoIsntMe For This Useful Post:
Marchy (06-13-2014)
Old 06-13-2014, 05:20 PM   #1642
PoWn3d_0704
PoWn3d_0704's Avatar
Drives: 1990 BNR32 GTR
Originally Posted by was385 View Post
Depends what your goals are with the car. Are you just looking to have fun or be competitive? What kind of competition are you going to see in your events? I run a small local club so the RCE Yellows were not only very fun to drive with but pretty competitive (all three of the competitive STX twins have them). If I went to a more competitive event, the car would be totally outclassed (as would the driver ). Personally, I'm moving from yellows to Bilstein B8s/Tarmacs but the yellows were a huge improvement over stock and I would absolutely recommend them to anyone.
And just as a side note, if you're already going 9 inch wide wheels, just go with 255.
I seriously apprecaite the input. I'm looking to be competitve, but I have a lot of buddies in different cars that all 'compete' even though we are all very different. My main competition is a Turbo MR2 on Racing Slicks.
I'm just looking to get the car somewhere where I, as a driver, can continue to improve for a long time coming.
On the subject of 17x9 with 255's, what am I going to need to make those fit? All I know is that there is a set of RCE yellows that come with camber bolts, but I dont even know what those do. (Other than give me camber adjustment? I heard that -2.5 is good for AutoX?)
Long story short is that I know a little bit about a lot of things, but suspension is NOT one of those things.
Picked up my BRZ on 6/11/13.
Build Album:
PoWn3d's BRZ Pictures
Build Thread: PoWn3d's BRZ
PoWn3d_0704 is offline   Reply With Quote
Old 06-13-2014, 05:27 PM   #1643
gramicci101
Off Topic
As far as wheels go, check out this thread to see what offsets fit. You can also look at known good 17x9's (Mach V's Awesome wheel is a good example) and base your offsets off those. Assume the RCE Yellows will lower the car around .75-1 inch.
Camber bolts will not give you -2.5 degrees camber. You'll need strut top mounts for that. A camber bolt replaces one of the two bolts attaching the strut to the wheel hub. It works by being a little smaller than the OEM bolt (Subaru crash bolt) or having an offset lobe (SPC/Whiteline camber bolt), which allows you to push the top of the wheel hub further in towards the engine, increasing the camber. A strut top mount/camber plate achieves a similar result of increasing camber, but it accomplishes this by moving the top mounting bolt of the strut inwards, effectively tilting the entire strut, spring, and wheel hub. For examples, look at RaceSeng or HVT camber plates on RCE's site.
Keep in mind that adjustable camber plates will change your auto-x class. If you want to be competitive, research the rules for the specific class you want and build your car with that in mind. Some classes might not allow 255's, for instance.
Old 06-13-2014, 05:41 PM   #1644
wootwoot
Drives: FRS
Enjoy!
- Andy
Thank you!
Last time I brought up tire size on the forum the consensus seemed to be that the 225 was typically faster. It seemed, at least at the time, that track guys ran 225's and the autox guys were running the wider sizes. Is this no longer believed to be the case? Are the T2's just that stiff that they will over tax the smaller tire? Just trying to understand
Old 06-13-2014, 05:45 PM   #1645
Thank you!
With a stickier compound I might have recommended the 225. The MPSS are sticky but not quite on the level as a stickier RS3 or ZII starspec or whatever and definitely not an R-comp.
The 245 MPSS will be consistent as hell, last a long time, and be damn fun. A 225 or 235 would be just fine too, but if you have the wheels for the 245 I say go for it.
- Andy
Old 06-13-2014, 05:49 PM   #1646
To be competitive nationally, you'd need coilovers. To beat your friends...that's a different story.
I do like the RCE springs as a first step to learn to drive fast and learn the car.
-2.5 (or more) would be good, but camber bolts won't get you there as gramicci said. you would need front camber plates instead (though I would still recommend the RCE Yellow package with the cheap front OEM camber bolts so you could fine tune with the bolts).
255's would be pushing it but would probably be okay depending on offset...more important than width is compound so make you get a quality tire.
- Andy
Old 06-13-2014, 05:56 PM   #1647
juliog
juliog's Avatar
Drives: 86
I'm running 225/45/17 RS3 on 17x9 #becauseracecar... the stretch is not too bad.
juliog is offline   Reply With Quote
Old 06-13-2014, 06:11 PM   #1648
PoWn3d_0704
- Andy
Thanks, I'm going to get 245 or 255 Hankook RS3's. Just need to see if they will fit on the car.
Build Album:
Old 06-13-2014, 06:32 PM   #1649
was385
Drives: MT WRB BRZ Limited, 2007 911s
Is this going to be an STX car? If so you shouldn't be directly competing with anyone on slicks. I want to say that 17x9 +45 with 255 and bolts rubs only at full lock but don't quote me on that. I would look at the figment guide in the wheels and tires section. And you'll need plates to get anywhere near -2.5.
was385 is offline   Reply With Quote
Old 06-13-2014, 06:40 PM   #1650
andrew20195
Originally Posted by SomeoneWhoIsntMe View Post
old porsches... experienced driver
These are the key words to that exception.
andrew20195 is offline   Reply With Quote
Old 06-13-2014, 07:47 PM   #1651
PoWn3d_0704
STX, yes. Very informally competing with guys on slicks.
In my Actual STX class we have a WRX, Two more 86's and a 300zx.
So far i'm just a tenth or two behind the WRX and beat the rest.
Build Album:
Old 06-13-2014, 08:22 PM   #1652
gramicci101
Off Topic
17x9 and 245's are a pretty common pairing. As long as you get the right offset you shouldn't have any problems at all.
The Following User Says Thank You to gramicci101 For This Useful Post:
PoWn3d_0704 (06-13-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
