Old 06-13-2014, 10:56 AM   #1
radroach
Drives: car
A/C question
So I've noticed when I have the A/C off that I only get cold air out of the vents when it's on the windshield defogger.
Any other setting with the A/C off blows hot air out the vents. So is it running the A/C compressor on that setting?
Old 06-13-2014, 12:24 PM   #2
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Yes, running on "windshield defog" turns on the AC compressor, even if you have the AC turned off. Has worked this way on all my cars (ones that had AC anyway). AC dehumidifies the air and gets rid of the moisture on the inside of the glass.
cfordart is offline   Reply With Quote
The Following User Says Thank You to cfordart For This Useful Post:
8R6 (06-13-2014)
Old 06-13-2014, 12:35 PM   #3
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Wait, I always leave mine dialed to windshield, but with everything else off. Are you saying that it's still running the compressor even if the everything is in the off positions? I usually leave it on windshield so the vents aren't blowing their hot air at me, but if it's running the compressor pointlessly I'll suffer the vents.
Nevermore is offline   Reply With Quote
Old 06-13-2014, 01:08 PM   #4
Harvey
Drives: Celica 5th Gen, Tiburon 04, GT86
The defrost setting is different than the windshield position... Defrost turns AC On, while windishield position should not...
Harvey is offline   Reply With Quote
The Following User Says Thank You to Harvey For This Useful Post:
kiichiro (06-13-2014)
Old 06-13-2014, 01:15 PM   #5
cfordart
cfordart's Avatar
Drives: 2014 FR-S
Watch your compressor. Compressor clutch cuts in on both those windshield settings...the one with just the windshield AND the one that includes the heat setting.
Think it does that so that you get defogging anytime you have air directed on the windshield.
Old 06-13-2014, 05:16 PM   #6
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
It'll for sure run the AC if you have the switch to windshield or windshield and feet. But only if you have the fan turned on. When it's foggy for me, I normally just put it one click before the feet and windshield if I don't want the AC go on, and it works OK.
PERRIN_Chris is offline   Reply With Quote
The Following 2 Users Say Thank You to PERRIN_Chris For This Useful Post:
kiichiro (06-13-2014), radroach (06-13-2014)
Old 06-13-2014, 06:17 PM   #7
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
billwot is offline   Reply With Quote
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 12:41 PM
FRS To BRZ Question BadMoon BRZ First-Gen (2012+) — General Topics 33 12-31-2013 10:24 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 03:11 PM
Question? Plxdjake89 Scion FR-S / Toyota 86 GT86 General Forum 7 07-28-2012 04:31 PM
mpg question jarviz Scion FR-S / Toyota 86 GT86 General Forum 1 07-10-2012 02:40 PM
