Old 06-12-2014, 06:53 PM   #1527
FR-S Matt
Originally Posted by MAPerformance View Post
I love my Mishi to be honest. The quality is quite nice for the price. Have had mine for a little over 7k miles now. They do offer a lifetime warranty. I can get a pretty good deal on them as well.
PM'd.
Old 06-12-2014, 06:54 PM   #1528
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by post_break View Post
I guess I don't understand why the needed bump in viscosity. Are your temps really that insane? With the forester oil cooler my temps never touch 220F when I beat on it on the street. For the track it might be a different story and even then I'd just run Amsoil 0w20 that is rated for 300F+
simply because 0w-20 is for fuel efficiency hence the word "Advanced fuel economy"
and designed for NA engine (near stock power levels) and adding about 60-65% more power to the engine will/should require better lubricating ...even the manual says that you can use 5w-30 so why not use it when you add FI ..ever compared the flash points and kinematic viscocities at certain temps? It's still your engine though, do whatever floats your boat
and lastly, with the same oil cooler and koyoRad with 0w-40 Mobil 1 engine oil I've seen my temps reached to 260-270F after a few laps, and that's with 70-75 F ambient temps here in Pacific Northwest where the climate is always a bit cooler than the rest of the nation... since you guys live in Texas without an adequate oil results may be catastrophic IMO
Originally Posted by zoth View Post
Spirited driving in afternoons, woot on 3rd gong up a ramp. I hit 236+ easily. I have no oil cooler yet. Waiting for @KraftWerks to release it.
in a warmer climate I wouldn't put anything less than 5w-30 and guess what if you decide to go to a track event you don't have to change your oil
Originally Posted by FR-S Matt View Post
I may just stick with 0w-20 then. I won't be a track junkie, but the occasional spirited drive will be there.
Also waiting for @KraftWerks to release the oil cooler.
please see above
glamcem is offline   Reply With Quote
The Following 2 Users Say Thank You to glamcem For This Useful Post:
FR-S Matt (06-12-2014), zoth (06-12-2014)
Old 06-12-2014, 07:39 PM   #1529
TmP
TmP's Avatar
Drives: A bunch of 'em...
Well, I'll run the 0w20 I just bought and change it after the next track day or something...
TmP is offline   Reply With Quote
Old 06-12-2014, 08:01 PM   #1530
CSG Mike
CSG Mike's Avatar
Just because Amsoil won't start breaking down until 300F+ doesn't mean that the engine can survive with the viscosity of Amsoil at that temperature.
CSG Mike is online now   Reply With Quote
glamcem (06-12-2014)
Old 06-12-2014, 08:13 PM   #1531
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I guess for me, on the street, the oil doesn't care if it's 160HP or 260HP. If it's operating at the specified temperature then the viscosity will remain the same. The redline isn't any higher than stock either. The forester oil cooler keeps it below 230F on the street and I've never seen it higher. I have yet to track the car with the oil cooler. Last time it hit 250F NA with no oil cooler when I would pit.
I don't want to argue about what weight oil you should run on the street, I just feel that for the street, 0w20 works for me. The track will be a completely different story.
post_break is offline   Reply With Quote
Old 06-12-2014, 09:10 PM   #1532
glamcem
glamcem's Avatar
do it yourself a favor and take a few more logs during some "spirited" driving I am willing to bet you in Texas heat in summer your temps should pass 250F even on the street if you're really on it..
Old 06-12-2014, 09:55 PM   #1533
post_break
post_break's Avatar
I have a scan gauge that is hooked up 24/7 that shows oil and coolant temps. even driving like a total asshole with multiple uturns to get on and off the highway I can't break 230f. once you start to build speed the radiator really does a good job of keeping the oil in check with the coolant. and there is no run away either with one affecting the other.
Sent from my SGH-M919 using Tapatalk
Old 06-12-2014, 11:33 PM   #1534
captain_jack
captain_jack's Avatar
Here in AZ i wasnt getting more then 246ish in feb-April with temp around 80
sent from your mom
Old 06-14-2014, 03:31 AM   #1535
zERoTu
Drives: 1st RBv2 10 Series FRS
Kraftwerks Supercharger Owners Thread
Installed and loving it. Power band is awesome and linear.
Question, when not going full throttle, I hear a whirring noise similar to air being blown into a plastic coke bottle. Can't seem to pin point it. Never heard it before the SC. Anyone else encounter this?
zERoTu is offline   Reply With Quote
Old 06-14-2014, 11:24 AM   #1536
SPCorBUST
SPCorBUST's Avatar
It's probably a boost leak. Did you clamp or zip tie the hoses?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Kojiro (05-18-2015)
Old 06-14-2014, 11:58 AM   #1537
zERoTu
Yup took off the ITM and clamp downed 4 ends of the hoses.
Old 06-16-2014, 03:23 PM   #1538
captain_jack
Well looks like the kit is no longer for sale. In the next month or so out will be going back on with the engine oil cooler as well as a new header from jdl and a flex fuel kit. should be in the 330 to 350 range when it's done and tuned. I will also be clamping down the hoses and maybe that will fix the boat leak around 7k i was having.
may the schwartz be with you....
The Following 2 Users Say Thank You to captain_jack For This Useful Post:
Freeman (06-16-2014), glamcem (06-16-2014)
Old 06-16-2014, 07:35 PM   #1539
NCItaly
Drives: 2013 BRZ Limited
Installed my mishimoto oil cooler with the kraftwerks/skunk2 sandwich plate. Clearance is just close enough.
Size:  80.4 KBName:  uploadfromtaptalk1402961519241.jpg
Size:  70.9 KBName:  uploadfromtaptalk1402961535088.jpg
Size:  82.5 KBName:  uploadfromtaptalk1402961546440.jpg
Size:  76.4 KBName:  uploadfromtaptalk1402961554700.jpg
I was going to put two more brackets on the bottom of the cooler, but I literally burned out my Dewalt drill putting holes in that beam. It's still very secure though.
Next stop is a shop that can cut out my grill and mustache and replace it with a custom grill so I can get some air flow to the oil cooler.
NCItaly is offline   Reply With Quote
Old 06-16-2014, 07:46 PM   #1540
TmP
TmP's Avatar
LOL, mine is going to look similar, although not... that... high.
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
