Old 06-12-2014, 02:12 PM   #1
ZionsWrath
Thanks
ZionsWrath's Avatar
Home air tools?
Someone gifted me a craftsman 26 gal air compressor with a air ratchet and 1/2" impact gun.
I tested the 1/2" on an old control arm I had a stuck end link on. Didn't work. I couldn't fit my vice grip on it but I could fit a pair of channel locks on and use the impact at same time and nothing.
So I googled it up and I see a significant amount of reviews that the Craftsman 1/2" can't even get their 100 ft/lb lug nuts off...
I set the pressure for the impact at 90 psi, max on the 26 gal compressor is 150. So, should I increase the pressure or buy a better 1/2" impact? Or is it that rusted on? Or please provide other opinions.
Old 06-12-2014, 02:24 PM   #2
jvincent
jvincent's Avatar
I have a 1/2" Craftsman electric impact that handles our 89 ft/lb lug nuts with ease.
According to the web page it's rated for 200 ft/lb so I would expect an air gun to be able to go much higher.
Pump it up!
The Following User Says Thank You to jvincent For This Useful Post:
ZionsWrath (06-12-2014)
Old 06-12-2014, 02:28 PM   #3
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Hmm...I have the same air gun(craftsman) and I could never get it to work with my lugs, but I thought that it was because my air compressor is only 3gal.
More Info from other users?
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 06-12-2014, 02:32 PM   #4
gramicci101
Off Topic
If you're looking to replace the impact gun, then between Lowe's and Home Depot you can usually find a package deal on their store brand air tools (Kobalt, at Lowe's). That way you can get four or five tools and various bits and whatnot at one time.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 06-12-2014, 02:44 PM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
I'm not really looking for a "deal" more for a tool that is going to work. But at the same time don't want to spend a fortune. I guess best bang for buck.
Maybe I'm just not using enough PSI but I don't know what the toll is rated for or supposed to use so I don't want to just turn it up to 150...
Old 06-12-2014, 03:25 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I have a gun with 1500 ft-lbs of nut busting torque that still couldn't get an end link off an old and rusted E36 M3. I also have a 1/2" Craftsman that came with my compressor that I never use. I did research when needing to get a crank bolt off a Honda, and came to the conclusion that a Ingersol Rand 1500 ft-lb of nut busting torque gun was the way to go. I got it from Sears I believe.
Old 06-12-2014, 03:39 PM   #7
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
Crank it up to max, tell your friend to hold your beer, and see what happens.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
The Following 4 Users Say Thank You to f0rge For This Useful Post:
gramicci101 (06-12-2014), n2oinferno (11-15-2014), WhiteFRS69 (11-12-2014), ZionsWrath (06-13-2014)
Old 06-12-2014, 04:08 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
You forgot saying "Hey guys, watch this...".
Old 06-12-2014, 04:10 PM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
Pneumatics are very sensitive to restrictions and most of those compressors don't have a large enough regulator. If you can, put a gauge on the line just before it goes into the air gun and check what the pressure is there when you're using your gun. Otherwise, just go get a 5/8" filter/regulator/lubricator, and whatever fittings you'll need. Also make sure you have a decent sized hose.
That craftsman impact gun is going to be another issue though. I've had an Ingersol Rand 2135TI for over a decade. It was worth each and every penny. Like His Majesty, I got mine at sears.
The Following User Says Thank You to Calum For This Useful Post:
Sportsguy83 (11-13-2014)
Old 06-12-2014, 04:29 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yep, mine is a TI as well. Definitely upgrade to a nice long big hose. I have the red Craftsman one that I just hang on the handle of my vertical Craftsman compressor. It lets me get air/tools all the way from my garage to the end of my driveway.
Old 06-12-2014, 06:35 PM   #11
Calum
That Guy
I agree with this, I just want to add that while a coiled hose looks like it'll be convenient, they are typically a royal pain in the ass to use. A good quality flexible rubber hose is much less restrictive and easier to manoeuvre?
Old 06-13-2014, 10:01 AM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Yeah I think the Craftsman compressors normally come with one of those cheap yellow small coiled plastic hoses. I know I still have mine, but I have never used it. This is the one I am talking about:
http://www.sears.com/craftsman-3-8-i...1&blockType=G1
Old 11-12-2014, 04:28 AM   #13
kingnba6
Drives: 2015
i love air tools at home.
ill post more about my setup later
kingnba6 is offline   Reply With Quote
Old 11-12-2014, 05:41 AM   #14
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
I have a 300ft/lb impact wrench from DeWalt. It's great! Works like a charm.
thatfilipinoguy is offline   Reply With Quote
Car lifts and tools. DankNugget Southern California 6 02-28-2014 02:09 AM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
