Old 06-11-2014, 03:20 AM   #57
steve99
Drives: FT86
Originally Posted by Boofneenee View Post
Before I updated my manager flkc was not reading any numbers correctly. I recently updated the manager and the numbers appeared to read normal. After running an additional log I noticed the new log is showing me +.5. I agree with an IAM of 1 it should only be reporting a negative which is the result of the ecu pulling timing. Someone in this forum mentioned earlier today that Shiv made mention of this issue and that its being resolved. I can't imagine at this point the error is something I did with updates.
E85 is almost to good to be true. The engine is more sensitive and snappy. Puts a smile on my face and my logs look legit therefore it may be good to be true. Question, I noticed that my timing is holding higher numbers to redline than with petrol. As high as ignition advance 35! This is normal correct? With this higher octane fuel the additional power is available because one can run a more aggressive map I.e. more timing. Am I learning here?
agree it looks like a bug in oft code nothing you did sure shiv will fix it soon
Old 06-11-2014, 11:14 PM   #58
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Originally Posted by Malt View Post
You need to goto Data logging, click read and then export to CSV instead of clicking Download LOG within OpenFlash Manager. That log file is for something completely different.
When I go to 'data logging' click 'read', I get an error that states 'File RTIME not found'. The button for 'Export' is grayed out. What is 'File RTIME'?
355rockit is offline   Reply With Quote
Old 06-12-2014, 08:52 AM   #59
Malt
Drives: 2015 WRX
While I havn't experienced that error before, maybe @shiv@vishnu can lend a hand here. If you can't wait for a response from him email sales@vishnutuning.com and I'm sure someone there can help out.
If you'd like an educated guess I'd say try installing the windows 8 patch off shiv's download section. Another guess is are you sure you actually data logged anything? You have to click start and stop on the OFT to get the log file to generate in my experience. Let us know if either of these worked for you, if not send an email and they'll get you fixed up in a jiffy.
Malt is offline   Reply With Quote
Old 06-12-2014, 10:37 AM   #60
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by shiv@vishnu View Post
Another update for you FLKC lovers, OFT should now support FLKC logging all non-USDM ROMs. Hard for me to confirm this on this end but please email me (shiv@vishnutuning.com) if you are having any problems logging
Cheers,
Shiv
I've logged today morning with A01E rom.
The log shows that FLKC as -0.5 and IAM as 1 not like as before.
Thanks.
makinen is offline   Reply With Quote
Old 06-12-2014, 01:18 PM   #61
355rockit
As Far as I remember, I start/stopped logging. The Win 8 patch was installed. I am going to try logging a run again in case I messed up somewhere the first time. Thanks for the info.
Old 06-12-2014, 02:10 PM   #62
wparsons
wparsons's Avatar
AFAIK, the windows 8 patch is ONLY needed if you're modifying the tune file before uploading it to the OFT. If you're using the OTS maps untouched or logging it's not needed.
I would bet that a library needed by OFM to read from the OFT is missing somehow. I would try re-installing OFM.
flickr
Old 06-12-2014, 03:22 PM   #63
Vmax911
Drives: WRB BRZ
Sounds like a scaling offset problem
if you iam is one flkc should be zero or negitive value on knock
if your iam is less than one then flkc can be positive
so if your seeing iam is one and flkc positive it some kind of scaling error
try updating your oft via ofm and ofm should be latest ver 1.08.3
Sorry, reads .5 on the tablet but is actually -.5 in the log file.
Vmax911 is offline   Reply With Quote
Old 06-12-2014, 03:32 PM   #64
Malt
Drives: 2015 WRX
Rounding error, Shiv said it will be fixed soon.
Sent from my SCH-R970C using Tapatalk
Old 06-13-2014, 12:37 AM   #65
355rockit
I was able to log a run with the OFT for the v1.59 B01C Stage 2 UEL tune. I have FT86SF catted UEL headers and TRD intake. I attached the log if anyone is interested in viewing it.
Old 06-13-2014, 08:11 AM   #66
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
You should upload to datazap to make it easy for viewing.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
Luckrider (06-13-2014)
Old 06-13-2014, 08:33 AM   #67
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I agree with @Boofneenee. It makes viewing the data much easier, keeps logs organized, and is free.
Luckrider is offline   Reply With Quote
Old 06-13-2014, 11:36 AM   #68
355rockit
I've never heard of datazap. I'll check it out. Sounds cool.
Old 06-13-2014, 11:47 AM   #69
Luckrider
Luckrider's Avatar
Check it out at datazap.me
Old 06-13-2014, 01:18 PM   #70
355rockit
Here you go...
http://datazap.me/u/355rockit/2014-s...log=0&data=1-2
Openflash manager data display problem. mid_life_crisis Software Tuning 6 05-14-2014 10:22 AM
OpenFlash Tablet: Multi-Gauge Function and FLKC logging Shiv@Openflash Software Tuning 52 05-08-2014 09:30 PM
OpenFlash Manager 1.07.1 Mad_Hatter Software Tuning 24 04-24-2014 07:46 AM
Now Available: OpenFlash Manager 1.04 Shiv@Openflash Software Tuning 37 12-14-2013 11:02 PM
