#43 | |
Drives: 2013 FRS
You need to update to the new OpenFlash Manager (v1.08.3) in order to save FLKC data to .csv properly. Looks like you are still running an older version of OF Manager. |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Boofneenee (06-10-2014) |
#44 |
Senior Addict
Drives: 86 GT
@shiv@vishnu do you have an ETA on FLKC for your Aussie customers?
#45 | |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
http://www.datazap.me/u/boofneenee/s...og=0&data=1-12 thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#46 | |
Drives: '13 BRZ Ltd
| The Following User Says Thank You to Wepeel For This Useful Post: | Shiv@Openflash (06-10-2014) |
#47 | |
Go-Kart Enthusiast
Thx
FRS
#48 |
Drives: 2013 FRS
Another update for you FLKC lovers, OFT should now support FLKC logging all non-USDM ROMs. Hard for me to confirm this on this end but please email me (shiv@vishnutuning.com) if you are having any problems logging
![]() Cheers, Shiv |
#49 | |
Go-Kart Enthusiast
here is the log: http://www.datazap.me/u/boofneenee/s...og=0&data=1-12 Is this normal?
FRS
#50 | |
Drives: 2015 WRX
#51 | |
Go-Kart Enthusiast
FRS
#52 |
Drives: Sci FR-S, Fer F355, Toy Highlander
Speaking of logging... what app do people use to view the .prolog files that OFT produces. The log viewer on the OFT site only opens .csv files as far as I can tell.
#53 |
Drives: 2015 WRX
You need to goto Data logging, click read and then export to CSV instead of clicking Download LOG within OpenFlash Manager. That log file is for something completely different.
| The Following User Says Thank You to Malt For This Useful Post: | 355rockit (06-10-2014) |
#54 | |
Drives: WRB BRZ
#55 | |
Drives: FT86
if you iam is one flkc should be zero or negitive value on knock if your iam is less than one then flkc can be positive so if your seeing iam is one and flkc positive it some kind of scaling error try updating your oft via ofm and ofm should be latest ver 1.08.3 |
#56 | |
Go-Kart Enthusiast
E85 is almost to good to be true. The engine is more sensitive and snappy. Puts a smile on my face and my logs look legit therefore it may be good to be true. Question, I noticed that my timing is holding higher numbers to redline than with petrol. As high as ignition advance 35! This is normal correct? With this higher octane fuel the additional power is available because one can run a more aggressive map I.e. more timing. Am I learning here?
FRS
| Openflash manager data display problem. | mid_life_crisis | Software Tuning | 6 | 05-14-2014 09:22 AM |
| OpenFlash Tablet: Multi-Gauge Function and FLKC logging | Shiv@Openflash | Software Tuning | 52 | 05-08-2014 08:30 PM |
| OpenFlash Manager 1.07.1 | Mad_Hatter | Software Tuning | 24 | 04-24-2014 06:46 AM |
| Now Available: OpenFlash Manager 1.04 | Shiv@Openflash | Software Tuning | 37 | 12-14-2013 10:02 PM |
