Old 06-08-2014, 10:55 PM   #127
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Originally Posted by Kodename47 View Post
Delete the .jar file in the directory and re-sync to get the latest run file.
My settings are:
open loop
MAF Volts Min 3
WOT Stationary Point % 80
AFR Error 10 - Unless you have changed your intake.
Closed loop
CL/OL 2
MAF volts max 3
IAT max 25C for NA - although I look for a max of 10C range max to min
AFR max 16
AFR min 13
dv/dt max 0.7-0.75 - I will run this twice on 0.7 and 0.75 to see if much changes.
dV/dt is the change in voltage over time, its calculated from your log. This will remove trims that occur due to quick changes in throttle. The lower the number, the smaller the rate of change so the better the results, but set too low and it will lose data. I think 0.7ish is a good setting. If you check the mean/mode chart and there is a wide scatter of results then reduce the dV/dt value.
Remember you can run the log with some parameters set to see what the data looks like and then re-run with reduced parameters to get better data. It's finding the right line that makes the results reliable not useless.
I have 1.3.2 which is the latest version right?
Toyota John is offline   Reply With Quote
Old 06-09-2014, 02:41 AM   #128
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm on 1.5.0
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-09-2014, 03:03 AM   #129
Kodename47
Kodename47's Avatar
Drives: UK GT86
@solidONE did you try just blanket flattening the IAT table? Using the latest update of the tool it would be quite easy to start generating an individual IAT Compensation Table using the log stats screen.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-09-2014, 01:02 PM   #130
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I think I might have on the higher temp side of the table, but in romraider the values can only be changed by 0.4 at a time. Changing the temp values will offer finer adjustment it seems. If you have any suggestion, I'm all ears. For now I'm going to move on to logging for knock since I finally came up with a half decent MAF scale and compensation table.
Old 06-09-2014, 03:23 PM   #131
Toyota John
Calle Atun
I'm on 1.5.0
I will update to 1.5.0 but wasn't 1.3.2 working for you before? Why would this change? Any idea why my open loop fueling table won't validate in POL fueling? That is the next step in the closed loop scaling posses correct?
Old 06-09-2014, 05:20 PM   #132
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's always worked as far as I remember. Just select copy the whole map in ECUtek and paste it into the window and then click validate.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-09-2014, 06:46 PM   #133
Toyota John
Calle Atun
Yeah that's what I did. I says "Invalid data in POL fueling table. Please post Primary open loop fueling table into first cell". I have to be missing something somewhere
Old 06-10-2014, 02:40 AM   #134
Kodename47
Kodename47's Avatar
Drives: UK GT86
You are, you're doing want I thought. Don't highlight the whole table and click copy as you're not copying the x and y axis definitions, which is what you need.
Go to Edit > Copy Entire Map to Clipboard
.: Stealth 86 :.
Kodename 47 DJ:
Toyota John (06-10-2014)
Old 06-10-2014, 12:39 PM   #135
Toyota John
Calle Atun
Originally Posted by vgi View Post
@Kodename47 looks like some people should not even f.. around with these things, you should put a disclaimer to each of your posts or your signature that you're not responsible for changes people make to their own cars.
@vgi I assume you are referring to me? If so, that comment is not needed. I am fully a where that the changes I make are my own responsibility. I am here to learn. If I F up my car oh well I won't be mad at anyone but myself.
Thanks @Kodename47 that was the problem.
Old 06-10-2014, 09:39 PM   #136
Toyota John
Calle Atun
I think I got it. How does this look?
Old 06-10-2014, 10:55 PM   #137
solidONE
solidONE's Avatar
Btw, 47, can you show us how to generate a new temp compensation table using the app?
Old 06-10-2014, 10:58 PM   #138
solidONE
solidONE's Avatar
Looks like you got it to work right. Now click the total correction and current box so you can see how far off the original scale is compared to that the app generated. Might want to zoom in to get a closer look at the maf scale below 2.8V.
Old 06-11-2014, 02:59 AM   #139
Kodename47
Kodename47's Avatar
Drives: UK GT86
Sure. You could try this to see what happens:
Once you have scaled your MAF to as good as possible at the range where the multiplier is 0% (1 on ECUtek) then use the Log Stats screen.
I would add an extra 2 columns to the log file itself: dV/dt and Error %.
dV/dt formula:
=IFERROR(ABS(((V2-V1)/(t2-t1))*1000),0)
Error correction:
=IF(Fuel System Status=2,(LTFT+STFT+100),(AFR/Commanded AFR)
*I have a more advance formula to take into account the delay between cylinder and O2 sensor, but it's a bit extreme to add here easily - I will add my Calibration Data spreadsheet as a separate thread*
Click set axis and paste in your IAT table and validate it as the axis. Load in a log and set the x as IAT and y as g/s.
If you added the extra columns as above:
Set Data as Error Correction
Filters:
dV/dt < 0.6 (or whatever you use for CL MAF scaling)
AFR < 16.5
At this point I would take the mean and count and paste them into this spreadsheet.
Try that and see how it works. It's just a theory at the moment but based on what you've tried I don't see how it will be much different. Obviously check the table after. Try and ensure that the OEM axis of 0 compensation is kept. You may well get a slight change in those cells and I would then compensate the rest a little for that. I have added the option to set the % of the total correction to the tables so you can try incremental changes.
.: Stealth 86 :.
Kodename 47 DJ:
solidONE (06-11-2014)
Old 06-11-2014, 04:35 AM   #140
Kodename47
Kodename47's Avatar
Drives: UK GT86
IAT Comp Tool
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
D-VO (09-10-2014), solidONE (06-11-2014)
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
