Old 06-07-2014, 10:08 AM   #57
steve99
Drives: FT86
Originally Posted by BuBlake View Post
Thank you everyone for your input, even the ramblers. lol The problem all along was that the tablet had no maps, or at least no compatible maps, for my car to write. I downloaded the off the shelf maps and uploaded a few I wanted to the tablet, then plugged it into my car, it actually allowed me to select "write", and it worked great. I would have tried this from the beginning had there been the correct 1.08(not 1.06) OFM download on their website. So the question now is, why were there no compatible maps on my OFT when it was delivered to me both times?
With new oft they come with database format .dev file tunes, these are just the changes for a series of stock roms.
To build a complete rom the oft reads your stock rom and then need to build a tune from the .dev database and your stock rom. The .dev database does not cater for all roms ie some of the older ones and some rearly new ones. It also needs to see the checksum in the stock rom match its databse so if you have had ecutek tune the licence info changes checksum so oft wont load tune for database .dev format.
If you erase those and load up the individual tune files for your rom type ie C or D for usa then oft no longer cares about if its 700 900 A01 ect it just loads a C or D tune and your in bussiness.
Old 06-07-2014, 02:14 PM   #58
Tromatic
Are you saying that I can install ANY cal? I have an A00D, but I would love to install the latest factory flash. If possible, can you please explain how to do that?
Old 06-07-2014, 02:55 PM   #59
steve99
Drives: FT86
you will be able to load the oft D series tunes, as I understand it they will be based on the A01D tune regardless if labeled 700D 900D ect, as shiv has not yet produced the file for B01D.
you could probably make your own by starting with the B01D stock rom and copying across all the changed tables then manipulating the calid with a hex editor if your really keen , or you could sit back relax and have a beer while shiv get's around to it. The B01D only has minor idle fix's as I understand it, over the current oft tunes based on the A01D maps (even though it says A00D)
I would think the new 1.6 version tunes will be based on B01D
Old 06-07-2014, 03:14 PM   #60
Tromatic
Yes, he said in another thread that 1.6 will probably be the B01D. I'm not brave enough to roll my own!
Old 06-08-2014, 12:46 PM   #61
fredfromnh
Drives: 2013 scion frs
It came off boat on November 2012
fredfromnh is offline   Reply With Quote
Old 06-08-2014, 12:47 PM   #62
fredfromnh
I picked it up 2 days after. Wanted red with mt.
Old 06-08-2014, 12:51 PM   #63
fredfromnh
Anyone running cpb with stock exhaust and proper of tune? I've yet to download cpb tune. Am running stage 1 tune. Doesn't really like it.
Old 06-08-2014, 12:54 PM   #64
fredfromnh
My friend works at dealer. He told me 1st cars to arrive were missing parts, had wires exposed etc.
Old 06-08-2014, 01:00 PM   #65
fredfromnh
Original motor had lots of valve train noise. New motor much quieter.
Old 06-08-2014, 01:11 PM   #66
fredfromnh
Originally Posted by gramicci101 View Post
It comes with off-the-shelf maps loaded in it, and you can download other maps through the OF Manager. Unless you're running E85 or some exotic FI setup, then the 91/93 stage 1 and stage 2 maps that are preloaded are sufficient.
I do notice that you have a 2013, do you know when it was manufactured?
Sorry for not quoting ur post. Arrived in new jersey November 2012. I had it 2 days later. Friend does finance at dealership and snagged it for me.
Old 06-08-2014, 01:13 PM   #67
fredfromnh
Car felt stronger with no power blocks and stage 1 tune. Maybe ass dyno wrong.
Old 06-08-2014, 02:40 PM   #68
Tromatic
Try E85.
Old 06-09-2014, 06:30 PM   #69
fredfromnh
Fwiw, I retorqued intake manifold 2 days after installing power blocks and feel a major difference.
Old 06-10-2014, 06:59 AM   #70
fredfromnh
Still don't get why these cars come alive when the needle shows 1/4 tank.
Clear Coat is totally F****d up. FRiSson Issues | Warranty | Recalls / TSB 48 11-16-2013 10:54 AM
I think I bricked my ECU with EcuTek help iketiak Engine, Exhaust, Transmission 4 07-03-2013 11:19 PM
Not mine, but now it is (aka, another "got mine" thread) brianbot5000 Northwest 2 07-01-2012 01:50 PM
This BRZ commercial totally depicts my relationship with my dad. YukiHachiRoku BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-07-2012 12:13 AM
