Old 05-06-2014, 12:20 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Winmax W2 brake pad review?
Just ordered a F/R set of W2 Winmax brake pads. Has anyone used these for Auto-X/Street yet? Do I need to bed these as well?
Just wanted to see some feedback with brake noise/dust/improvement over OEM etc.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 05-06-2014, 12:29 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Old 05-08-2014, 01:52 AM   #3
whataboutbob
AutoX-10/10ths every run
I have been running the W3 pads all around for over 10K miles and 60+ autox runs. I bedded them on fresh front rotors and used rear rotors.
I had previously used Hawks in the front and stocks in the rear.
The Hawks made a ton of noise and dust, the W3s are very quiet and generate much less dust. I've used them with R Comps when autoxing and they are more than capable for that task.
I'd say that the Hawks had much more initial bite (even to the point where they were locking the front tires under hard braking), while the W3s are much more progressive and easy to modulate.
The W3s have easily as much braking force as the Hawks did, but you can control it much better IMO.
Build thread:Here
Old 05-08-2014, 11:51 PM   #4
BRZPDX
Boosted Member
BRZPDX's Avatar
They just arrived today, will be installing them tomorrow. Do you have any recommendation on how to bed them correctly? They are more street/auto-x pads though. Do they even need to be bedded for mainly street pads?
Old 06-09-2014, 01:26 AM   #5
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Update?
unsurety is offline   Reply With Quote
Old 06-09-2014, 12:01 PM   #6
BRZPDX
Boosted Member
BRZPDX's Avatar
Originally Posted by unsurety View Post
Update?
I did 1 auto-X event, and been driving with them for about 1.5k miles.
Initial thought:
They definitely bite harder than OEM, and it has a different "brake" feel to them. Light force seems to be weaker than OEM, but as you put more force on the brakes, it bites significantly harder.
Noise:
It has a very faint squeal at high speed light application on the brakes. The squeal stops once there is more force on the brakes.
No noise with low speed stop and go. The most I hear it is about 2 seconds getting off a freeway (High speed -> mid speed). Not bothersome at all.
Dust:
There may be a slight increase in the brake dust, but nothing crazy. After about 1.5k miles, I wiped my rims off with a towel, took 5 minutes. I've seen much worse with other owners brake pads. I am pretty light on my brakes so maybe different at the track (23k miles on OEM pads, probably still had over 2/3 left.
Burnout issues:
Since I have an AT, I have trouble doing burn-outs with these new pads! With OEM, it was so easy to get the rears spinning, but with the new pads, I can't really do stand still burnouts anymore.
Overall review:
I am not a track junkie, so these pads are excellent for me. More bite than OEM, not very dusty, barely no noise and no need to replace rotors. Install was a breeze, and I highly recommend these for the occasional drift/auto-X guys that drive mainly on the street.
Cold weather bite is good as well, and its as effective first thing in the morning compared to mid-day.
The Following 3 Users Say Thank You to BRZPDX For This Useful Post:
CSG David (06-09-2014), Defpo (07-20-2015), unsurety (06-09-2014)
Old 06-10-2014, 01:24 AM   #7
FRSGeek
Drives: UltraMarine 6 Spd MT
I've been on my W2's now for a few thousand miles.. Hmm, damn, I only mounted them a month ago.
I LOVE THE BITE, they stop fantastic, right from the initial grab to max pressure to kick in the anti-locks.
Now the sad thing is they are a bit harsh on the dust factor and I am probably just hitting the break a bit more than I need to because I love that felling they will stop you with ease.
I haven't had track time on them yet. but will soon. Moto suggested getting used to these and if really need to go up to W3, do so. But with my white rims, and the small amount of metal they add to the W3 compound. We thought I'd be upset with the rust that would show.
Anyway, for now.. I really love the W2's.
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
The Following User Says Thank You to FRSGeek For This Useful Post:
CSG Mike (06-10-2014)
Old 06-10-2014, 01:48 AM   #8
CSG Mike
CSG Mike's Avatar
If you purchased from us, you should have received 2 sets of bedding instructions, one from Winmax, and one from us.
PM me your e-mail and I'll forward you a PDF version of our instructions.
Old 06-10-2014, 09:40 PM   #9
BRZPDX
Boosted Member
BRZPDX's Avatar
I came with instructions. I wrote that without opening up the package lol.
I kinda half assed the bedding procedure since it is hard to find a place to do all that listed on there. Seems to bite well so far..
The Following User Says Thank You to BRZPDX For This Useful Post:
Winmax USA Brake Pads - Street, Autocross, Track, Endurance! CSG David Suspension | Chassis | Brakes -- Sponsored by 949 Racing 65 07-04-2016 09:59 AM
Touge Factory Brake Cooling Kit Review smbstyle Tracking / Autocross / HPDE / Drifting 70 04-03-2015 02:03 PM
CounterSpace Garage - Winmax USA Brake Pads Group Buy - EXTENDED!! CounterSpace Garage Groupbuys 21 01-28-2015 06:48 PM
FS: Winmax brake pads new BeltedBiscuit Brakes, Suspension, Chassis 0 03-06-2014 02:24 AM
Brake fluid review opportunity CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 09-30-2013 06:42 PM
