#127 |
Drives: 2013 Scion FRS Premium
Alright so, one thing I notice is that in the "logcfg" file there is MAF Voltage in there. However, in the log itself, I don't see any MAF Voltage being logged. Any ideas? Do I have to make any changes to the "logcfg" file, or perhaps need to use another "logcfg" file? Thanks.
#128 | |
Drives: FT86
otherwise try the other C series logcfg.txt or just copy the MAF_V parameters and scaling from that file to yours. |
#129 |
Can't find nothing that helps me there. I already tried two different logcfg files that log but none show MAF Voltage.
#130 |
Drives: FT86
#131 | |
#132 |
Drives: FT86
#133 |
Drives: Whiteout FR-S, Evo 8 RS
Does anyone have the IDC logging on the B01C ROM? I tried using the params from post #1 but its not working for me. By the way, IPW does not log when using the defogger start stop param.
#134 | |
Drives: FT86
Triggers have proved unreliable Also try making your own B01C parameter file start with one of the A01C files and just substitute in the addresses for BO1C from the ram address list. clean out any non used parameters as well, should work then |
#135 |
I don't have any issues logging. I want to log IDC. The A01C doesn't have IDC. I tried using what was written on page 1:
type = calc paramname = IDC scalingrpn = RPM,IPW,*,0.0008333333,* This particular param doesn't log correctly. |
#136 | |
Drives: FT86
those are just examples, and for wrx ecu from memory so not sure if scaling would be correct as long as RPM and IPW are defined prior to that it should work if the ram address is not in the list on that page then you only hope is to talk to @Td-d Last edited by steve99; 06-10-2014 at 06:41 AM. |
#137 |
Drives: Black 2013 FRS
I've successfully used this guide to update my 2013 FRS from 700c to b01c, and then flash the stage 1 OFT tune. I did a bit of logging with techstream and it seems like everything is in order. Thanks! If I could only get the romraider logger working I'd be set.
#138 |
Drives: FT86
The romraider logging is not all sorted out yet, but you can use the standalone logging with an sd card in the tactrix using the logcfg file as in the first post
#139 | |
#140 |
Drives: FT86
Td-d supplied me with some more RAM addresses for G series ROM just add them to your G series (A01G) logcfg file, look in the G series Romraider or ecuflash definition files for scalings.
I suspect not all have been tested added them to original post as well G Series ROM (A01G) RAM addresses supplied by @Td-d E_AF_Correction_1_4byteExt_E81 FFF8A550 E_AF_Learning_1_4byteExt_E48 FFF8A6D4 E_AF_Sensor_1_4byteExt_E91 FFF8932C E_Closed_Loop_Fueling_Target_4byteExt_E121 FFF8A634 E_Engine_Load_4ByteExt_E32 FFF89148 E_Engine_Speed_Delta_E157 FFF893FC E_Feedback_Knock_Correction_4byteExt_E39 FFF8AFAC E_Final_Fueling_Base_4byteExt_E123 FFF89F84 E_Fine_Learning_Knock_Correction_4byteExt_E41 FFF8B048 E_Fuel_Injector_1_Latency_4byteExt_E50 FFF89FC4 E_Fuel_Injector_1_Pulse_Width_4byteExt_E60 FFF887C8 E_IAM_4byteExt_E31 FFF8119C E_Idle_Speed_Map_SelectionExt_E49 FFF8B630 E_Knock_Correction_Advance_4byteExt_E43 FFF8AFA8 E_Knock_Correction_Advance_Max_PrimaryExt_E118 FFF8B014 E_Manifold_Relative_Pressure_4byteExt_E113 FFF88F78 E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E5 2 FFF88F74 E_Throttle_Plate_Opening_Angle_4byteExt_E38 FFF89030 E_Tipin_ThrottleExt_E54 FFF89038 RAM_EngineSpeed FFF893EC Ram_AFR_Sensor_Heater_Protection_Result FFF88480 Ram_AFR_Sensor_Heating_Limit_Result FFF88478 Ram_AF_Correction_3_32bit_ECU FFF8A860 Ram_AF_Sensor_1_Current FFF89328 Ram_AF_Sensor_1_Resistance FFF89340 Ram_Accelerator_Pedal_Angle FFF8922C Ram_Accelerator_Pedal_Angle_0 FFF8D2D0 Ram_Accelerator_Pedal_D FFF8D2C4 Ram_Accelerator_Pedal_E FFF8D2C8 Ram_Alternator_Duty FFF884A4 Ram_Ambient_Air_Temperature FFF8D2BC Ram_Atmospheric_Pressure FFF8D290 Ram_Atmospheric_Pressure_1 FFF89B84 Ram_Base_Pulse_Width_times_100_0.84 FFF89CAC Ram_Battery_Voltage FFF87C6C Ram_Battery_Voltage_0 FFF8D29C Ram_CFP_Delta FFF89048 Ram_CPC_Valve_Duty_Ratio FFF89CBC Ram_Calculated_Base_Pulse_Width_ FFF89FC0 Ram_Catalyst_Temperature_Bank_1_Sensor_1 FFF8D298 Ram_Commanded_Secondary_Air_Status FFF8D2E5 Ram_CoolantTemperature FFF890A4 Ram_Coolant_Temperature FFF8D24C Ram_Distance_Traveled_since_DTCs_cleared FFF813EE Ram_Distance_Traveled_with_MIL_On FFF813EC Ram_EVAP_Commanded_Purge FFF8D288 Ram_E_AF_Learning_1_4byteExt_Percentage FFF8D254 Ram_Engine_Load_Absolute FFF8D2A0 Ram_Engine_Load_Calculated FFF8D248 Ram_Engine_Oil_Temperature FFF8D2DC Ram_Engine_Oil_Temperature_0 FFF87C74 Ram_Engine_Speed FFF89564 Ram_Engine_Speed_0 FFF8D25C Ram_Exhaust_VVT_Retard_Angle_Left_ FFF8BFCC Ram_Exhaust_VVT_Retard_Angle_Right_ FFF8BFC8 Ram_Fuel_Air_Commanded FFF8D2AC Ram_Fuel_Injector_1_Pulse_Width FFF887D8 Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF887F0 Ram_Fuel_Injector_2_Pulse_Width FFF887DC Ram_Fuel_Level FFF8D28C Ram_Fuel_Pressure_MPa FFF8936C Ram_Fuel_Pump_Duty FFF8B09C Ram_Fuel_Pump_Duty_0 FFF8BC20 Ram_Fuel_Rail_Pressure_direct_inject FFF8D27C Ram_Fuel_System_1_Status FFF8D2E2 Ram_Fuel_System_2_Status FFF8D2E3 Ram_Fuel_Trim_1_Short_Term FFF8D250 Ram_Fuel_Type FFF8D2E6 Ram_Fueling_Mode? FFF88FA8 Ram_Fueling_Mode??? FFF8BC2F Ram_High_Low_Load_0_L_1_H FFF8A060 Ram_Idle_Switch FFF8B4AE Ram_Ignition_Total_Timing FFF8ACF4 Ram_Intake_Air_Temperature FFF8D268 Ram_Intake_Air_Temperature_0 FFF87C64 Ram_Intake_Manifold_Pressure FFF8D258 Ram_Intake_OCV_Current_Left FFF891B4 Ram_Intake_OCV_Current_Right FFF891A8 Ram_Intake_OCV_Duty_Left FFF8C090 Ram_Intake_OCV_Duty_Right FFF8C09C Ram_Intake_Temp FFF890B4 Ram_Intake_VVT_Advance_Angle_Left FFF8BF84 Ram_Intake_VVT_Advance_Angle_Right FFF8BF80 Ram_Learning_1_Current_Range_A FFF8A6FC Ram_Map_Delta? FFF8A19C Ram_Mass_Airflow FFF89114 Ram_Mass_Airflow_0 FFF8D26C Ram_Number_of_warm_ups_since_DTCs_cleared FFF826CE Ram_Roughness_Monitor_Cylinder_1 FFF8CC11 Ram_Roughness_Monitor_Cylinder_2 FFF8CC12 Ram_Roughness_Monitor_Cylinder_3 FFF8CC13 Ram_Roughness_Monitor_Cylinder_4 FFF8CC14 Ram_Run_Time_Since_Engine_Start FFF84DB4 Ram_SI_Drive_Mode_I3_S1_SSharp2_ FFF88999 Ram_Throttle_Opening_Commanded FFF8D2CC Ram_Throttle_Position FFF8D270 Ram_Throttle_Position_B FFF8D2C0 Ram_Throttle_Position_relative FFF8D2B4 Ram_Time_Run_with_MIL_On FFF813F0 Ram_Timing_Advance FFF8D264 Ram_Transient_Threshold_Testunk FFF8923C Ram_Vehicle_Speed FFF8D260 Ram_Vehicle_Speed_0 FFF893C4 |
| Tags |
| ecuflash, tactrix, taxtrix, tuning |
| ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
| Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
| Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
