Old 06-07-2014, 10:53 PM   #1457
gramicci101
Off Topic
I consider a neutral car one where you can dictate whether you under or oversteer, at will with steering or weight transfers, and can be throttle steered.
The couple of times I've driven a neutral car were a lot of fun, but I kept getting caught out by trailing throttle oversteer. I may not be the best driver. You learn fast though!
Old 06-07-2014, 11:26 PM   #1458
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by gramicci101 View Post
Very basically, when going around a corner, if you roll in more throttle the car will go wider. If you roll off the throttle the car will tuck in tighter to the corner.
What Mike is specifically referring to is when you're at the limit of adhesion and the tires are considering stepping out on you. If you jump on the throttle, you break traction and go for a spin. If you let off the throttle, you regain traction but the car loses speed. If you're very delicate and smooth with the throttle, you can edge just past the limit and barely start to slip. Your tires still have enough traction to put power down, but they're also protesting loudly and have lost enough traction that the car has only just started to rotate. At this point you're steering with the throttle. A little more throttle, you lose a little more traction, the rear end steps out a little more, and you go wider. A little less throttle, the tires regain a little traction, the rear end comes back into line, weight transfers forward, and you tuck into the corner. At this point, steering input is almost less important than throttle input. Your steering wheel has set the line you want, and your throttle adjusts your position on that line.
You can feel this when you take long curving on-ramps, with larger throttle inputs. Let off the throttle, weight rolls forward, there's more weight on the front (turned) wheels, and you take the corner tighter. Roll on the throttle, and you'll swing out wider. It's an interesting thing to get the feel of.
This is exactly how I was taught to corner. When I hit the stripes on corner exit by using throttle, I got praise. Corner 2 at Thunderhill was great for this.
Old 06-07-2014, 11:30 PM   #1459
RFB
RFB's Avatar
Drives: FRS
If there's no tendency to under or oversteer, then you still have tire grip left. Enter the corner faster and/or give the car more gas mid-corner, and power out earlier.
Throttle steer? You need a near-neutral car to do it. You literally... press on the gas more until your car starts rotating mid corner, and you control that rotation with the gas pedal.
Having an aftermarket LSD makes this throttle steer window substantially larger.
Thanx - that makes more sense.
CERBERUS
RFB is offline   Reply With Quote
Old 06-07-2014, 11:33 PM   #1460
RFB
RFB's Avatar
Drives: FRS
You're tuning the car for oversteer by reducing rear tire grip. Instead, you want to increase front end grip. How you do this varies.
Again thanx, will try slightly tail happy on Monday.. and more front grip as well.
CEREBRUS
Old 06-07-2014, 11:33 PM   #1461
EAGLE5
Dismember
EAGLE5's Avatar
Originally Posted by orthojoe View Post
No way. Your alignment must have been screwed up or the tires were screwed up to wear out OEM tires on 11k street miles.
Could be. I am thinking of getting the crash bolts and some front camber for my first track outing and then the shop can check the alignment. Wear was consistent across all tires, and the car tracks straight. I do live on a canyon road.
Old 06-08-2014, 12:48 AM   #1462
dp1
driving smoother faster
Drives: Sold
Also check your alignment, specifically toe
dp1 is offline   Reply With Quote
Old 06-08-2014, 12:30 PM   #1463
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
We have a lot of near hair pins an roughly 120 degree turns in Gresham. I've noticed myself feathering the throttle after the apex making my car turn with minimal counter steer but the tires are braking looses and re gripping as I throttle. It seems to be cutting down my times on back roads. I can't call it drifting at all cause I never kick it out much but it's constantly fighting between rear slide and rear grip. Is this throttle steer? I literally hardley have to adjust the wheel at all, it's all In my gas pedal. Or is it time for new tires? Lol
FRSfan111 is offline   Reply With Quote
Old 06-08-2014, 05:13 PM   #1464
ZionsWrath
Thanks
ZionsWrath's Avatar
If you go to a track day and it rains, how do you stay dry in the paddock? What rain gear to bring
Old 06-08-2014, 09:54 PM   #1465
FRSfan111
Shoes for sure! Nothing worse then having slippery shoes when trying to push the limits. I always bring a good wind braker and umbrella or collapsible overhang.
Old 06-09-2014, 06:04 PM   #1466
CSG Mike
CSG Mike's Avatar
It's technically something in between a throttle steer and power-over. You're power-overing, and then maintaining rotation with throttle modulation.
You're actually borderline drifting...
Old 06-09-2014, 06:18 PM   #1467
CSG Mike
CSG Mike's Avatar
This sounds ghetto, but I take a ton of trash bags to put everything in.
If it's going to be raining, I pack light.
Old 06-09-2014, 07:19 PM   #1468
RFB
RFB's Avatar
Drives: FRS
CEREBRUS
Did a full day at Mosport Gran Prix track today. Front tires one or two pounds less than the rear.
Didn't bother trying anything else. 150 KM/H (90 MPH) smoothly around corners, full control with easy throttle steering, minimal squeal, NO oversteer NO understeer.
When behind them, I kept pace with GTR, Supercharged Lotus Elise, etc. on corners.
Good enough for me.
CERBERUS
Old 06-09-2014, 07:36 PM   #1469
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Good enough for me.
CERBERUS
How fast at turn-in to T4, and what did you do with the throttle between turn-in and the apex?
dradernh is offline   Reply With Quote
Old 06-10-2014, 12:12 AM   #1470
RFB
RFB's Avatar
Drives: FRS
How fast ? Are you kiddin ? Off camber before Moss corner comin up ?
You think I was lookin at the speedo ?
The throttle ? I was jerkin me right toes up and down as needed and watchin apex line for entry and exit.
Had blisters on my hand from the round handlebars at the end of the day !
CERBERUS
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
