Old 06-05-2014, 02:14 PM   #813
GeekB
Drives: 2013 BRZ Limited
Originally Posted by protpibe View Post
What was the shop using to try and tune it? Are they running ECUTEK?
Also, does the exhaust have any sort of adjustment on the hangers? I know the Perrin I run has hanger locks to be able to adjust the position of the exhaust.
edit: Also, that code means that it was running too lean, I'm guessing it may be a problem with the install. Have you tested for boost or vacuum leaks?
Yeah it was EcuTek.
I'm using the stock hangers. They couldn't really adjust it much, it seemed pretty fixed.
The shop will be doing a boost test on Saturday. They told me there was a small header gasket leak but it shouldn't affect the tune. They're gonna be changing the gasket out with the one Paul sends down so hopefully everything will be good.
GeekB is offline   Reply With Quote
Old 06-05-2014, 02:30 PM   #814
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
The perrin exhaust comes with these to hold the exhaust in place
May be worthwhile to invest in some if it's just a matter of adjustment
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 06-05-2014, 06:00 PM   #815
GeekB
How do those work exactly? Here's what my exhaust looks like right now with the left part sticking out.
Old 06-05-2014, 11:06 PM   #816
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Finally got a video of the exhaust from the back end of the car. Hope you guys enjoy. It's a little quiet for some reason so turn up the speakers, she SCREAMS!
[ame="https://www.youtube.com/watch?v=5SNXsoOKLS0"]Toyota GT86 AVO Turbo Kit with FT86SpeedFactory Catback Exhaust - YouTube[/ame]
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
The Following User Says Thank You to nataku For This Useful Post:
JustBoostin (06-07-2014)
Old 06-06-2014, 07:50 PM   #817
Jcl
Drives: 2014 BRZ
What oil coolers are you guys running? Perrin? Full blown? Any modifications if any to the kits that come with?
Jcl is offline   Reply With Quote
Old 06-06-2014, 08:12 PM   #818
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Play with exhaust bushings. Had a similar issue when I did mine. Messed with the bushings and bamm their perfect.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
Old 06-07-2014, 12:01 PM   #819
protpibe
protpibe's Avatar
Put down just under 270 at the wheels today @ 10psi on 94 octane
Sent from my HTC One using Tapatalk
Old 06-07-2014, 12:25 PM   #820
onzippy
Drives: 2014 FRS
WooHOO! Thought you might have canceled because of the manifold issue. Is this with the leak or without?
That torque curve looks like a table. Nice and flat.
I don't know how you ever bring yourself to go putt putting around at 7 psi anymore
Don't forget the dyno thread ....
http://www.ft86club.com/forums/showthread.php?t=42290
onzippy is offline   Reply With Quote
Old 06-07-2014, 12:28 PM   #821
protpibe
protpibe's Avatar
That's with the leak. I'm guessing it would pick up a bit more power, but who knows.
The guy who ran the dyno actually commented about the torque curve and how flat it was
Old 06-07-2014, 04:01 PM   #822
qtwre
Drives: White FR-S
That is creepy flat. Not sure I've ever seen one like that. Good stuff.
qtwre is offline   Reply With Quote
Old 06-09-2014, 02:21 PM   #823
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Nice - what gears are those in? 6MT or AT?
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
Old 06-09-2014, 02:32 PM   #824
protpibe
protpibe's Avatar
Yeah i was surprised how flat it was too. Was thinking maybe my clutch is slipping ? no idea
Bob, its an MT in 4th
Old 06-09-2014, 02:36 PM   #825
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
Actually that is a possibility. Would also explain the slightly low hp and really low tq for 10 psi. Should be around 280whp and 230-240 tq at 10psi
brz2013 is offline   Reply With Quote
Old 06-09-2014, 03:08 PM   #826
protpibe
protpibe's Avatar
Any idea what the stock clutch can handle for torque?
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
