Old 06-09-2014, 09:29 AM   #6091
Robftss
Drives: VW
Here's a log of a 4th gear pull. Looks like max boost is 4.07psi. Does this look about normal?
http://datazap.me/u/raven1231/esc-4t...og=0&data=1-12
http://img.tapatalk.com/d/13/10/01/re2yqygu.jpg
Blue line (OP, post 1).... your boost plot is slightly better.
Robftss is offline   Reply With Quote
Old 06-09-2014, 10:03 AM   #6092
raven1231
Originally Posted by Sojhinn View Post
Did you upgrade to the 1.5 yet?
No, I should be getting it today or tomorrow hopefully. It says the estimated delivery is today but who knows. I plan to test all the batteries when they are out. I just know it feels a lot different then before, there's no push back in the seat feeling. The voltage does drop however and the compressor spools so the controller is fine.
Old 06-09-2014, 10:04 AM   #6093
raven1231
hmmm so do you think it could be a bad dump pack?
Old 06-09-2014, 10:09 AM   #6094
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Full throttle Electric Supercharger Build Thread
I would pull out the batteries today. Test each one individually and make sure they are producing approximately 12.8 volts. Also double check your connections and make sure they are not reversed.
Installed Mods:
Old 06-09-2014, 10:11 AM   #6095
fenton
Originally Posted by Fear View Post
this is not an ESC vs FT with same amoutn in mods...
This is ESC, TUNE, Header, EXHUAST...
Never mind i suppose. Sorry for jacking the thread guys.
thank you for your time.
I see what you mean. This is a video of a stage 2 FRS (intake and full exhaust from the header back) running Ecutek.
The Black FRS is running the ESC with no tune and no other modifications(stock exhaust).
[ame="https://www.youtube.com/watch?v=AeS1UffqyoU"]2 - YouTube[/ame]
fenton is offline   Reply With Quote
The Following 2 Users Say Thank You to fenton For This Useful Post:
DAEMANO (06-09-2014), Gums (06-09-2014)
Old 06-09-2014, 10:23 AM   #6096
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by TM View Post
FWIW, Rob has tracked many cars for many years and used to be a BMW driving school instructor at a local road course. He said that a track usable FI is minimum $5-6k on any car.
"Track-usable" is not the same as a purpose-built FI kit. Of course, it can still be used on the track, but has it's limits and is less than ideal.
Battery and cooling mods will add to the cost and complexity of the kit. Conversion tray - $210, aux charger - $300-400, vented hood - $750, etc. That's why a traditional FI kit is still the best route to go for track environments.
I'm not saying that the ESC won't eventually be upgraded to a point that would make it be a great option for track usage. Technology is driven by wants and needs. And it moves at an incredibly fast pace.
But as for now, I'm having a blast with the extra boost in power on the streets. On the tracks, I'm still working on improving myself before performance, and I still have a long way to go.
Thanks for keeping it real. I applaud the efforts of those here who have tracked it and modified their cars to help the system put up with track abuse. This is an excellent option for street cars and it makes great torque numbers which are extremely rewarding for its owners considering their overall investment in time and money.
On most tracks a car will be in the upper rpm range most of the time.
Case in point
[ame="https://www.youtube.com/watch?v=cPfyFwqURBM"]Subaru BRZ at Road Atlanta with Peachstate PCA, June 2014 - YouTube[/ame]
The ESC apparently works on track if you cool the controller properly and add extra batteries. It may even last a full 20 minute session with lots of WOT in the hands of an experienced driver. But the fact is that the boost tapers off greatly and for the majority of of the WOT events on track you will be out of the ESC's efficiency range, which is down low where you get the 5psi and the surge of torque. I understand that every PSI counts and the power increase is there even to redline with 1 to 1.5 PSI. Is it worth it, for a pure track application to have that little boost in the upper RPM ranges? The ESC cost totals in a little over 1/2 the total cost of a full-time supercharger which builds boost/power/torque progressively and you're making 7 to 9 PSI to redline. For me when I consider both and assume the ESC has full support for track applications and the controller overheating issues are resolved, I am inclined to keep saving for full-time FI.
I am NOT trying to start another debate between part-time and full-time FI. I just want to lay out the facts of both for pure track usage. For me I have to consider that I will be using any FI kit on track frequently and I would want the performance benefits to be usable in the upper rpm range instead of the lower. The ESC just doesn't make sense for a track application and I'm not sure any modifications to the system could change that. The voltage would need to be much higher, the compressor spin much faster to get more high-rpm boost, the controller heat management demands increase, the battery capacity increases... which would blow the cost out of proportion to where it no longer makes sense. It's making much better sense to me now that this is a street-only option.
That said, I'll continue to help development of the ESC for track applications in any way I can without actually buying one. Please feel free to reference any of the raw track footage linked in the OP of my build thread for rough (audible) WOT data. At Road Atlanta, my home track, I'm WOT quite a lot through a 1:50 hot lap. I'd say around 60 seconds per lap. I don't have any supplemental data but I know that my oil temps stabilize around 230F on track and my coolant temps hover around 200-210F on track as well. The engine bay gets hot for sure.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
DAEMANO (06-09-2014), Target70 (06-09-2014), TM (06-09-2014)
Old 06-09-2014, 10:30 AM   #6097
raven1231
Connections are fine as they haven't changed since I have had the ESC. I will however test them and update you guys. Thanks
Old 06-09-2014, 10:46 AM   #6098
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by shif7i7down View Post
Did I ever say that the esc would win against a"decently tune(custom tune)" avo kit? I said that the numbers are comparable if not better then the stage one kit that avo offers., there's really no need to come in here with your chest pumped and all gang buster out bro, I'm merely comparing a stock avo Stage one tune vs an esc stock tune. With that said,for the price difference i will still pick the esc.
Some of us are Aren't looking to make 9,000hp just a good DD that will get me through the day is just fine.
Nah man, no chest pumped, no gang busters, I'm not a "bro", and no need for you to be defensive. If your ESC makes you happy, then that's all that matters. Kumbaya.
Old 06-09-2014, 11:56 AM   #6099
shif7i7down
Erected Member
Drives: frs
Wasnt being defensive, just reiterating what i posted.
No harm no foul ,
shif7i7down is offline   Reply With Quote
Old 06-09-2014, 12:38 PM   #6100
shif7i7down
Erected Member
Drives: frs
Originally Posted by robwbright View Post
No, I haven't. But others have. My lack of skill and/or tires doesn't change the fact that it can be done.
Hey rob, seem like others are having a hard time believing my claims of 5.8sec 0 ~60 , so I'll do a few runs tonight and record it with a GoPro to legitimize my claims
With a gtech of course, as to the accuracy of gtech people will have to contact the manufacture if they disagree with the claims of +/- .01
The Following 2 Users Say Thank You to shif7i7down For This Useful Post:
DAEMANO (06-09-2014), robwbright (06-09-2014)
Old 06-09-2014, 12:40 PM   #6101
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Come on.. it is all about the launch. I can totally see 5.8 if you can get it to hook and run.
Luckrider is offline   Reply With Quote
Old 06-09-2014, 12:51 PM   #6102
shif7i7down
Erected Member
Drives: frs
I agree, but there are others that don't, I'll do roughly 3 runs from a dig at different rpm also. Maybe it'll help others with their launch. Not that i am a pro, but it might be of some use to others
The Following User Says Thank You to shif7i7down For This Useful Post:
Khyron686 (06-09-2014)
Old 06-09-2014, 12:55 PM   #6103
Luckrider
Luckrider's Avatar
I learned the hardway this weekend at the Stafford Motor Speedway that controlled wheelspin can pull harder that grip with poor surface conditions.
The Following User Says Thank You to Luckrider For This Useful Post:
shif7i7down (06-09-2014)
Old 06-09-2014, 12:58 PM   #6104
JD86
Drives: 2013 Toyota 86 GT
Closes stock dyno # vs fi # that i could find to compare
compare.
Vs
Shif7i7down
-100% stock car with phantom esc
[img=http://s14.postimg.org/enzdp54ht/CAM00443.jpg]
So yeah, DAEMANO is correct that the esc is comparable to our even better then other stage 1 fi kits. Even vs turbo kits
Edit; all claims are subjective to my own personal perspective, no ill intent to mislead or downplay other kits.
Also,this is just end user dyno vs end user dyno. I'm sure the manufactures dyno would look allot better :p
Haha thanks for dragging me into this one.... But a correction for you, my "stage 1" kit was never dialed in correctly before I upgraded. Something that popped up after that dyno was the fact that my wastegate actuator wasn't functioning correctly. So that dyno is actually only on 3.5psi of boost. That and an overly restrictive exhaust were why the numbers were so low.
All it took was to replace the wastegate actuator and I went to 245hp. With boost control and a half decent tune it then went up to 270hp. Now well beyond that.
But best of luck comparing a turbo to an electric supercharger.
JD86 is offline   Reply With Quote
The Following 2 Users Say Thank You to JD86 For This Useful Post:
bfrank1972 (06-09-2014), DAEMANO (06-09-2014)
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
