View Poll Results: What do you think of the 2015 Series Blue BRZ?
I like it, everything looks great. 214 40.07%
Meh, its just ok. 269 50.37%
Looks like rice; I hate it. 51 9.55%
Voters: 534. You may not vote on this poll
Old 06-08-2014, 12:56 AM   #295
Poodles
Drives: 2015 Series.Blue
Early reports are showing the new Mustang is going to be quite a bit lighter and much better handling now that they've ditched the live axle and gone IRS. It's also been tuned a bit for the European market that notoriously hates big unrefined American cars that wallow through corners.
We gotta wait until they're out in the wild to determine anything though.
Old 06-08-2014, 01:01 AM   #296
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Newer reports say it is actually heavier than the pervious model.
Old 06-08-2014, 01:35 AM   #297
Poodles
Yeah, I saw that, but then Ford said otherwise when contacted. Who knows at this point
I do have to admit, it's quite nice looking apart from the odd front end, but it's still a Mustang...
Old 06-08-2014, 02:53 AM   #298
FiRStsc10n
Canadian FR-S Member
FiRStsc10n's Avatar
Drives: FR-S '10 Series'
They called it the Aozora Edition in Canada
FiRStsc10n is offline   Reply With Quote
Old 06-08-2014, 01:20 PM   #299
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
Ford would be pumping that all over if it lost weight. It will be the same or, likely, heavier than the '14. The car grew in every direction, gained IRS, and content. It will tip the scales at 3650lbs on the lightest versions, IMO.
Quentin is offline   Reply With Quote
Old 06-08-2014, 01:59 PM   #300
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
I hope this doesn't not become a Ford Mustang thread. There's a place for that....i'm just putting it out there. I don't mean to spoil the party...
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 06-08-2014, 02:52 PM   #301
BRZ NA
Drives: WR blue
Not even STI calipers? not worth it
BRZ NA is offline   Reply With Quote
Old 06-08-2014, 04:43 PM   #302
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
This new WR Blue might be the same found on the 2015 WRX STI. I read on a Subaru forum that this new blue is 3-stage whereas the pre-2015 blue is 2-stage (but still thin as paint easily chipped off the 2015 STI owner's door). If true, then a bit more premium and maybe a bit harder to color match.
Old WRB paint code: 02C
New WRB paint code: K7X
Took these pics a month ago without even realizing the blues were different:
The Following User Says Thank You to switchlanez For This Useful Post:
Choco (02-24-2015)
Old 06-08-2014, 05:27 PM   #303
x1UP
One & Done (AOZORA)
x1UP's Avatar
That is a sick rear-window. How much and where did you get that, may I ask?
It just looks great.
The Following User Says Thank You to x1UP For This Useful Post:
switchlanez (06-08-2014)
Old 06-08-2014, 05:37 PM   #304
switchlanez
Thanks, it was under $1000 after shipping from Japan and at my door about 11 days after I ordered: http://www.japanparts.com/db/partsli...maker=&VOLKEY=
Old 06-08-2014, 06:28 PM   #305
Poodles
Oh so hard to tell from pics because of the different body shapes, but it looks like it might be slightly darker.
Old 06-08-2014, 07:04 PM   #306
GNS
Drives: .
Originally Posted by Michael Blue View Post
Other than price, I just don't see the Mustang as a legitimate comparison here.
You have the uberlight twins with near perfect handling balance, then you have a heavy, softly-sprung domestic with more power and crappy build quality.
But..If you are seriously shopping the two, you just might be happier with the Mustang. Especially if you think the world revolves around smoking the tires at each stoplight.
Just not my thing. At all.
Be careful when making assumptions about a car that hasn't been released yet, let alone thoroughly tested by reviewers and owners. The new Mustang gains IRS and a new front suspension setup, and was supposed to have also dropped some weight (new reports out of Steeda and elsewhere SPECULATE that it might have gained weight).
It won't handle as good as an FR-S or BRZ, but whether it is a softly-sprung dumpmestic fat bloated pig is as yet to be determined.
GNS is offline   Reply With Quote
Old 06-08-2014, 07:36 PM   #307
x1UP
One & Done (AOZORA)
x1UP's Avatar
Nice! How was installing it on your BRZ? Did it take long?
Old 06-08-2014, 08:41 PM   #308
switchlanez
Installation isn't hard at all. Should take 30 minutes or less if you ditch the templates and directly mark onto the window where to place the brackets using the mounting holes on the louvers as guides (which I ended up doing).
Scion 10 series parts SpidrWeb Scion FR-S / Toyota 86 GT86 General Forum 188 12-24-2015 08:37 AM
(10-SERIES) Any way to disable blue LED on emblems? R4PT0R-X Cosmetic Modification (Interior/Exterior/Lighting) 0 05-27-2014 10:46 PM
2015 Subaru WRX Sti LeeMaster Other Vehicles & General Automotive Discussions 162 04-21-2014 02:11 PM
Series 10 parts in the gta info logoris CANADA 15 09-11-2013 12:12 PM
