Old 06-07-2014, 03:28 PM   #1429
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by gmsii View Post
what i mean is slip the clutch if you need to....its better than spinning out
there is nothing more sensitive to rear wheel lock up than a motorcycle during aggressive downshifting and braking....before slipper clutches became standard in racing motorcycles, in addition to matching engine speed, the rider needed to have good enough clutch control to slip the clutch to drag the engine rpm up to higher transmission speeds when necessary
it may be a bit hard to explain what I am actually dealing with most of the time I have to be on the maintenance throttle very quickly and there is a slim line between keeping the car steady or causing a lift off oversteer at those speeds ..
Like you mentioned those transitions may be somewhat easier with sportbikes, I used to own two of them (Gixxer 600 and Ninja 1000, and totaled both of them within 8 months, long story lol) and slipper clutches were great help ..but as you can imagine fast in - fast out requires some serious "man berries" on motorcycle and maybe some serious experience with trail braking technique which I never experienced on a motorcycle
I will try getting a lighter flywheel as you suggested and am hoping that it will help me at track days..
glamcem is offline   Reply With Quote
Old 06-07-2014, 06:58 PM   #1430
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I just wanted to say, if you haven't clamped your evap hoses do it now. I just did on my car and now my AFR's are where they need to be. They were running way lean and now so much better. The evap hoses slipped off with a pinky finger. I don't know how they correlate to my tune but now I'm running exactly where I should be when open and closed loop. No more air blowing sound when under boost too.
This should be step one before the SC goes on because it's a pain to do after the fact.
post_break is offline   Reply With Quote
Old 06-07-2014, 07:56 PM   #1431
NCItaly
Drives: 2013 BRZ Limited
So, after a failed hour of searches, I ask you guys this: where is a good place to tap in a boost gauge? I'm using Torque App right now and it kind of sucks because i get vacuum until like 5000rpm on WOT. I bought a cheap gauge (don't care too much about accuracy, more so just the presence of boost near correct levels) but i don't know where to run the tube to. any suggestions?
NCItaly is offline   Reply With Quote
Old 06-07-2014, 08:29 PM   #1432
post_break
post_break's Avatar
I teed off the brake booster.
Old 06-07-2014, 08:34 PM   #1433
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
I'm getting a code p0507 idle air control system rpm higher than expected, my rpms at idle are 1300-1000 sometimes higher, I clamp.the 3 hoses under the intake manifold any a idea what else could be? Maybe I missed a hose? Or maybe is something else?
Sent from my SGH-M919 using Tapatalk
Taino-BRZ is offline   Reply With Quote
Old 06-07-2014, 08:36 PM   #1434
NCItaly
yup, usually caused by a vacuum leak. gotta find it. thats the same code i got when i blew off my EVAP hose
Old 06-07-2014, 08:37 PM   #1435
NCItaly
what kind of readings are you getting?
Old 06-07-2014, 08:38 PM   #1436
post_break
post_break's Avatar
Around 10 psi I think. I don't really watch it much. More interested in AFR.
Old 06-07-2014, 08:41 PM   #1437
NCItaly
what about vacuum?
Old 06-07-2014, 08:43 PM   #1438
post_break
post_break's Avatar
what about vacuum?
That's like negative 10-15.
Old 06-07-2014, 09:10 PM   #1439
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Mine never goes less than -10
zoth is offline   Reply With Quote
Old 06-07-2014, 09:23 PM   #1440
NCItaly
at what RPM do you start seeing 0 and boost?
Old 06-07-2014, 09:27 PM   #1441
captain_jack
captain_jack's Avatar
When mine was installed i was seeing boost at 2k, well according to @nelsmar when we were on the dyno.
sent from your mom
Old 06-07-2014, 09:51 PM   #1442
zoth
zoth's Avatar
Between 2K & 2.5k, but it really depends on how you drive I think. Like on 6th gear until you floor it and let reach boost. But oh boy it's so easy to reach over 100 mph... I need better tires.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
