Old 05-25-2014, 05:28 PM   #113
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Hey Vgi - yes, sorry, did not have the time to test yet.
Sent from my iPad using Tapatalk HD
Td-d is offline   Reply With Quote
Old 06-07-2014, 03:31 PM   #114
Chicken Patty
Drives: 2013 Scion FRS Premium
Sup fellas, so I got the open source setup working. Now I notice that in Rom Raider I see no values so that I can log Knock, or any sort of KCA values? Am I missing something here? Thanks in advance.
Chicken Patty is offline   Reply With Quote
Old 06-07-2014, 04:07 PM   #115
steve99
Drives: FT86
Romraider logging does not work yet
logging is direct to SD card in tactrix adapter see first post
Old 06-07-2014, 04:18 PM   #116
Chicken Patty
Thanks, I somehow missed all that. Got what I needed, I read the ROM and assumed I was done. I'll give all this a shot and revert, thanks bud.
Old 06-07-2014, 05:10 PM   #117
Td-d
Not strictly correct - there is a beta version of RR that logs the standard ODB parameters already.
All the extended params require SD card logging.
Old 06-07-2014, 08:32 PM   #118
Chicken Patty
That's what I thought because that's the version I tried and it does log a few things but not everything I need. Which is why I asked since I didn't see any parameters for knock. I'm going to give the SD card logging a shot tonight and I'll report back.
Old 06-07-2014, 10:29 PM   #119
Chicken Patty
Quick question guys. Got it all setup but not working. Which "logcfg" would I need to use if my ROM ID is ZA1JA00C? I keep reading through the end of that first post but maybe I'm just missing something.
Old 06-07-2014, 10:53 PM   #120
steve99
Drives: FT86
Use either of the first two C logcfg files donr use the bo1c stuff it wont work
is your sd card foratted fat 32
make sure logcfg.txt is in root directory
you should get blue led flashing when you plug tactrix to obd port if not it not reading file
if you get logcfg.out it read logcfg.txt if you not getting a logXXX.csv then its not understanding your logcfg.txt file, look in logcfg.out for clues or it not reading obd port correctly ignition musy be fully on
Old 06-07-2014, 11:04 PM   #121
Chicken Patty
Yes, I formatted it to FAT32. Let me try one of those files, I don't believe I was using any of those.
Old 06-07-2014, 11:15 PM   #122
Chicken Patty
Tried both of the first C files with no luck. Just keeps doing the rainbow cycle, the OP2 that is. I know for a fact the logcfg file is in the root of the SD card. So can't think of what else can be off?
I just plug the cable in, car off. Put the log cfg file in, crank the car. Press the rear defogger and nothing. When I disconnect it and connect it again i get the logout.txt file. Any ideas?
Old 06-07-2014, 11:21 PM   #123
steve99
Drives: FT86
The tactrix must not be connected to computer for this logging to work . connect it to obd port only, take log, remove then connect to pc to read.
comment out any triggers they are not reliable, with no triggers it will just run any time engine is on
Old 06-07-2014, 11:24 PM   #124
Chicken Patty
Hmmm. Okay, didn't think being connected could have conflicted. ... and I'll go try it soon. THANK YOU!!!
Old 06-07-2014, 11:29 PM   #125
steve99
Drives: FT86
remove or comment out any triggers they are unreliable, it will then just log any time engine is on,
once you get that working then try triggers, i dont use them more trouble than they are worth
Old 06-07-2014, 11:43 PM   #126
Chicken Patty
I'm about to go out and try it. I'll remove the triggers and go from there. Give me a few and I'll report back.
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
