Reverse Burnouts
Drives: 2013 Argento FRS
oil leak, drivers side, front of engine
Tried searching but nothing came up.
Car currently has about 50k miles. Bought 5/28/12 . Was checking the oil levels during a routine check and noticed an oil leak on the front of the engine. Engine was pretty dirty so i cleaned off the area. Seems less than a 1/4 of a quart has leaked from my engine. I was posting in case anyone has come across this problem yet. So i could start narrowing down the problem Coolant has no traces of oil. Oil was nearing the end of its life and is due for a change in the morning. Also i have had no previous record of engine burning oil so the quantaty of oil lost is definatly from the unknown origin or the leak. No oil dripping where i park the car. How i drive my car: i drive briskly, with more attention to handling than speed. I pretty much mean i like to go around corner just to feel the g forces. I may hit redline a couple times during my commute but usually just while emtering a freeway to get up to the speed of traffic from the service streets. Most of my road carving i dont exceed 5k rpms on the back roads.
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#2 |
Drives: infiniti g37x
#3 |
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
http://www.ft86club.com/forums/showt...78#post1617278
I had oil leaking from the bottom of the passenger side timing chain cover. |
#4 | |
Drives: t
got the same leak.. comes from the timing chain area between the head/ cam carrier.. engine has got to come out to repair.. you can try your luck with it covered under warranty.. I was told they dont cover it unless its a leak in your driveway or visible.. |
#5 | |
Drives: '13 FRS - STX
It seems like there have been a handful of instances with the sealant between the block and the covers (cam & timing chain) not holding, see link in a previous post. All you can really do is take it to the dealer and hope they're feeling generous, you're still under the 60k mile powertrain warranty, it shouldn't be leaking but I'm sure they'll do their best to avoid the work. Edit: That is if you can show there's a leak, by your description all you've found is some oil. Burning/loosing <1/4 of a quart over 7,500 miles may not be a cause for concern, we don't know yet since you're probably in the top 5% of high mileage cars. |
#6 | |
Reverse Burnouts
this is a rough outline of where i saw oil on the engine block before i cleaned it yesterday ![]() another picture for reference ![]() EDIT: also maybe my oil filter is leaking and going down the drain. will see if i continue to see the leak after i do my oil change and put a new filter on there
#7 |
Drives: white premium brz M/T
I have the same leak right now!!!
It's not a major leak but I'm starting to get paranoid
#8 | |
Reverse Burnouts
How many miles since the last oil change?
#9 |
Yes I use OEM oil filter. I have 4k mile since last oil change. Going to do oil change after 1k mile...I'll upload a pic of mine in few mins
#10 |
![]() ![]() Is yours like this CarbonBlue? My car has no problems so far...I redline everytime I drive, and I'm boosted as well
#11 | |
Reverse Burnouts
I wouldn't rule out that the oil leak we have is unrelated just yet do you ever smell burning oil? i don't I don't think it leaks enough to form droplets that find its way to the exhaust manifold.
#12 |
Drives: 2013 GBS BRZ Limited
Clean engine well.
Add this ![]() http://www.oreillyauto.com/site/c/de...2323&ppt=C0014 Take pictures and go to the dealer. |
#13 | |
Reverse Burnouts
sunday i think ill try this , cleaning the engine in tight spaces is a pain though. no room to see what my hands are doing :/
#14 | |
I don't have warranty since I am FI'ed, so I don't know what to do -.- maybe take it apart I suppose...
| Water Leak inside passenger side floorboard | AtlasMick | Issues | Warranty | Recalls / TSB | 30 | 03-28-2019 04:43 PM |
| New Body Parts from WORKS | WORKS | Exterior Parts - The Rest | 2 | 06-13-2014 06:58 PM |
| Tranny fluid or engine oil leak? | G.I.Choe | Issues | Warranty | Recalls / TSB | 1 | 05-28-2014 06:53 AM |
| Small Oil Leak under center of engine? | brillo | Issues | Warranty | Recalls / TSB | 6 | 11-09-2013 09:52 PM |
| Wanted: drivers side front fender | Yruyur | Miscellaneous | 0 | 11-26-2012 09:30 PM |
