View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 05-31-2014, 12:36 PM   #4145
Mooseknuckle44
Mooseknuckle44's Avatar
Originally Posted by Vis101 View Post
I've been using Quick Trip gas for the past couple tanks and had a lower cricket issue. Filled up with Shell two days ago and the crickets are viscous.
Sent from my HTCONE using Tapatalk
Been using QT gas since the day l got my car. Took around 3500 miles for the crickets to show up. Swapped HPFP and 3500 miles later they came back again. I truly believe it doesn't matter which gas you use, as long as it has ethanol in it our cars will sound like a bait shop.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 05-31-2014, 01:01 PM   #4146
andrew20195
Drives: 2013 Subaru BRZ
That sounds disgusting.
andrew20195 is offline   Reply With Quote
The Following 2 Users Say Thank You to andrew20195 For This Useful Post:
Annahra (05-31-2014), extrashaky (05-31-2014)
Old 06-03-2014, 01:13 PM   #4147
Blood
Drives: 2018 STI
Anyone have access to the Subaru TSBs? It looks like 09-54-12R, the TSB for the fuel pump, was updated on April 15th, 2014. http://techinfo.subaru.com/static/whatsNew.html -- scroll down to the bottom. Can't view it without a subscription.
Blood is offline   Reply With Quote
Old 06-06-2014, 03:51 AM   #4148
86main
Drives: Scion FRS
I bought a deatsch fuel pump, and I told my dealership to install it for free since you guys cant seem to fix the problem with multiple factory fuel pump replacement. They eventually agreed, and well I'm happy. Should have done this earlier. Totally gone.
Had it for close to a month, close to 500 miles with the new fuel pump.
86main is offline   Reply With Quote
Old 06-06-2014, 08:47 AM   #4149
andrew20195
Where do you see a Deatchwerks high pressure fuel pump? It's not listed on their site.
nunonuna (06-06-2014), strat61caster (06-06-2014)
Old 06-06-2014, 08:58 AM   #4150
nunonuna
nunonuna's Avatar
^ +1
nunonuna is offline   Reply With Quote
Old 06-06-2014, 09:07 AM   #4151
FR-S Matt
That's a fuel pump, not a HPFP like the one that chirps. It's not the same pump and that one goes into the fuel tank.
Trust me, if there was an aftermarket fuel pump known to fix the chirping issue, they would be the richest vendor on here. Here is info on the pump he put in which does nothing in regards to the chirping.
DW65C series, 265lph compact fuel pump (in-tank) without mounting clips w/ Install Kit for 2012+ Scion FR-S
Introducing the first high flow, compact, 65mm pump.
Compact 65mm body for OE fitment
Flows 265 liters per hour (70 gallons per hour)
Available with and without mounting clips
Ethanol compatible
3-year no-fault warranty
Quiet and reliable turbine impeller
The only thing he did was waste money for nothing, unless he's really boosting high.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Old 06-06-2014, 09:23 AM   #4152
Mooseknuckle44
Update on the 2 cycle ashless oil fix. Very hesitant to do this, but I finally bit the bullet.
I started off with less than everyone here recommends @ 1.5 oz in a VERY empty tank. I filled almost 12 gallons into my tank plus the 1.5 oz of oil.
No chirps for the first 100 miles but now they're back intermittently. Kinda like someone opening and closing the door really quickly on a closet full of crickets.
Next I'll be trying 1.75 oz for a FULL fuel up.
I'm using a medical catheter syringe to measure and administer the oil to the tank.
I put the oil in first btw, then all 12 gallons. I figured this would mix up the oil best.
Also, this was first tank was after running thru a FULL tank of 90 octane ethanol free gas.
I'll update on the oil amount change as soon as I get there. Not my DD so it may take a few weeks.
Old 06-06-2014, 05:58 PM   #4153
andrew20195
Yep. I was politely calling BS on his post.
Old 06-06-2014, 06:44 PM   #4154
FR-S Matt
Lol, I'm correcting it promptly before people waste money due to misinformation. This forum would blow up if a true chirp fix existed without workarounds.
I'm on tank #2 with the Lucas upper cylinder cleaner and I put it in last this time. Still don't have an opinion about it yet. Needs more testing.
Old 06-06-2014, 10:44 PM   #4155
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
I had my fuel pump replaced under warranty a couple months ago and haven't had a single cricket since.
AyJay is offline   Reply With Quote
Old 06-06-2014, 10:46 PM   #4156
Mooseknuckle44
You will. My 2nd pump made it about 3,500 miles before they came back. Back with a vengeance l might add.
Old 06-06-2014, 11:22 PM   #4157
Tromatic
Klotz Uplon works very well on crickets, at least for me. Not as good as E-free gas, but close. Oddly, since I think water content in the fuel has something to do with it, I've yet to have crickets while running E85.
When I do have crickets, I just pretend it's the supercharger.
Old 06-07-2014, 12:00 AM   #4158
AyJay
AyJay's Avatar
That's what i keep reading on here ... so far so good though. Couldn't be happier with my FR-S at this point.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
