Old 06-05-2014, 11:41 PM   #1
Norcalmav23
Drives: SWP Limited manual BRZ
Question Ecutek debacle from required recall
Long week, long story. Not sure how many of you are in the same boat...
In order to get my car registration renewed I had to get recall #WQC39 taken care of. It involves a dreaded ecu reflash. I am full Visconti tuned stage 2.
To allow the recall flash to happen, I flash back to stock... they do their job and service the recall... as soon as I get the car back, to avoid CEL and my car having major issues, I attempt to flash back to my Visconti provided stage 2 tune. HOWEVER, the dealership wrote over/voided/ate? my Ecutek license so I am now unable to flash my stage 2 map back onto the ecu, it simply says that there is no license present (I attached a screen shot). Given that I put serious miles per day on my Brz, this past week hasn't been too much fun having to clear CEL's and such. I contacted Visconti and he promptly told me what to do... email over a copy of the recall being serviced, which I did within an hour. Upon following up a few days later it sounds like I am actually waiting on Ecutek to supply an additional license. Any idea how long this should take? Anyone else ever go through this?
The beautiful weather is upon us in Nor Cal, and I am missing my somewhat powerful (don't laugh), stage 2 brz . Hopefully the Ecutek Gods will smile upon me soon and bless with me with another license to flash my neutered car with.
Name:  Ecutek No Licenses Present in ECU upload.jpg
- Clear Bra - 35% tint - Fa20 club intake - Rev Works header - Perrin OP - 3 inch FP - Resonated CB - Perrin LW crank pulley - Fortune Auto 500 V4 coil overs... pinky sized gap - Full CS knock off poly lip kit - JDM clear side markers - RPF1 18x8 - 35 offset - square 225-18-40 - Perrin shifter bushing - KartBoy positive shift kit - Hawk HPS pads - SS Lines - Visconti e85 tuned
Norcalmav23 is offline   Reply With Quote
Old 06-05-2014, 11:44 PM   #2
pmccut
Drives: Blue Subarus
To allow the recall flash to happen, I flash back to stock... they do their job and service the recall... as soon as I get the car back, to avoid CEL and my car having major issues, I attempt to flash back to my Visconti provided stage 2 tune. HOWEVER, the dealership wrote over/voided/ate? my Ecutek license so I am now unable to flash my stage 2 map back onto the ecu it simply says that there is no license present (I attached a screen shot). Given that I put serious miles per day on my Brz, this past week hasn't been too much fun having to clear CEL's and such. I contacted Visconti and he promptly told me what to do... email over a copy of the recall being serviced, which I did within an hour. Upon following up a few days later it sounds like I am actually waiting on Ecutek to supply an additional license. Any idea how long this should take? Anyone else ever go through this?
Attachment 81055
I had something similar happen with the licensing. While flashing ecutek threw an error and the flash aborted mid way, car was a sitting brick. Msg'd Visconti (tune was just sent over from him minutes before), and he had a license update for me in minutes. @EcuTek should be able to take care of this near immediately..
'13 GBS BRZ 6MT | FBM 9:1 w/ GTX3076R| FBM oil cooler + catch-can + radiator + SPAL fans| Rays 57xtreme / PSS | Perrin 2.5" FP | Invidia 2.5" OP | Perrin 3" CBE | RCE T2s | Exedy Stg1
'15 STI LE | Cobb Stg1
pmccut is offline   Reply With Quote
The Following 2 Users Say Thank You to pmccut For This Useful Post:
charged86 (06-16-2014), Norcalmav23 (06-05-2014)
Old 06-05-2014, 11:48 PM   #3
jflogerzi
jflogerzi's Avatar
this guy is still tuning twins WTF??!!
The Following User Says Thank You to jflogerzi For This Useful Post:
draggin_az (06-06-2014)
Old 06-05-2014, 11:50 PM   #4
Norcalmav23
I was one of his original pre orders 2 years ago... Simply looking for support
Old 06-05-2014, 11:52 PM   #5
JerryMichaels7
Drives: Whiteout FRS
his tunes didn't burn the car down his poorly designed product did, the guy isn't stupid when it comes to the tuning side
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
The Following User Says Thank You to JerryMichaels7 For This Useful Post:
wparsons (06-06-2014)
Old 06-06-2014, 12:41 AM   #6
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Hope we can see some solid customer service from EcuTek on this. I'm considering them and definitely interested to see what they do here...
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following User Says Thank You to Cjymiller For This Useful Post:
Norcalmav23 (06-06-2014)
Old 06-06-2014, 01:05 AM   #7
mkivsoopra
This happened to me a while back. I think it took about 2 days for them to issue a new license through Visconti. You should be hearing back soon. If not, remind Visconti.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
Old 06-06-2014, 01:27 AM   #8
Tromatic
Screw that. Wanting to protect your work is one thing but leaving your car dead to do so is fucked up.
Old 06-06-2014, 01:33 AM   #9
steve99
Drives: FT86
This is not a problem with the tuner, its just the way Ecutek licencing works. Ecutek needs to see the licence info embedded in the rom in the car, it embedded in an unused part of the rom . If you or the dealer write a new rom to the car not using ecutek then you have written over your ecutek licence and you have the problem the OP has.
This can also happen if you get a failed write with ecutek and you dont use the recovery mode.
Brz
Old 06-06-2014, 02:30 AM   #10
86drift
86drift's Avatar
Drives: Toyota 86 GT
I lost my EcuTek licence when I flashed with BRZEdit. Back then I didn't realise how their licencing worked.
The Australian EcuTek dealer wasn't interested in helping me out.
86drift is offline   Reply With Quote
Old 06-06-2014, 04:00 AM   #11
nelsmar
I've dealt with this before. Just call john. As much if a **** he can be he will take Carew of you. Just actually call and explain what happened. Exutek just needs to verify before they send a license as it's easy to "false" so it can take upwards of a week but usually just a day or two.
My flickr - Canibeat
Local magazine scout
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Norcalmav23 (06-06-2014), wparsons (06-06-2014)
Old 06-06-2014, 10:16 AM   #12
DJCarbine
Thupercharged
DJCarbine's Avatar
From what I read, the car has a factory tune on it and runs/drives.
::edit
seems the other guys were not so lucky
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-06-2014, 10:30 AM   #13
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I lost my EcuTek license many many times in my process of figuring out that my laptop was just incapable of completing a reflash and before they fixed EcuTek to not consume a license until after the reflash was successfully completed. The process was always to e-mail Visconti with my EcuTek log file (the file that has a copy of all the info that gets printed in the right side of the image above). Then he would have to contact EcuTek to have them put a license back on my dongle ID and then you connect to the EcuTek servers and download the new license file and apply it to your dongle and flash away.
Old 06-06-2014, 09:34 PM   #14
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Keep your receipt whenever a dealer flashes your car. It is frequent enough and EcuTek will always reinstate the license if you have some documentation. Unfortunately there's some that try to game the system, so there has to be some diligence. Ultimately if you provide a receipt and a log file that shows a certain vin having a license, then not; we know it was an overwrite and it is a non-issue to reinstate.
Xero-Limit is offline   Reply With Quote
TSB / Recall Sigh-on-Rice Issues | Warranty | Recalls / TSB 390 09-11-2023 01:24 PM
brake recall? ric342 Issues | Warranty | Recalls / TSB 76 11-25-2012 08:42 AM
Recall I think so!!!! RWD-boxer Issues | Warranty | Recalls / TSB 16 10-07-2012 11:39 AM
FRS recall? totally Issues | Warranty | Recalls / TSB 8 08-30-2012 01:01 AM
Recall! already earthsscum BRZ First-Gen (2012+) — General Topics 1 06-07-2012 08:00 PM
