Old 06-03-2014, 02:08 PM   #715
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by inositle View Post
Got mine in on Friday, installed it and most everything is working well. Forgot to wire up the amp power line on Pin #9 but luckily remembered people talking about that a few pages ago. My current problem is that there's almost no space for apps; also, I was trying to install Co-Pilot (20-something MB according to Play Store) and it said I didn't have enough space even though it looks like I had a few 100MB available.
I saw a few pages ago that there was talk of a firmware update that would resize the app partition potentially. Is this the case? Any solution to get more app space?
Thanks!
EDIT: I was able to install via side loading. Another question I have... is there a known way to replace the CaFi home screen? If not, is there a way to reprogram what app the GPS button & "CarNavi" GUI button open? Also, when I push the Radio button when I'm in another app, it typically switches to the next "mode" (e.g., FM1 -> FM2 -> FM3 -> AM1...). Any way to disable this? I just want to push radio & switch stations.
I too don't like how the Radio button changes to the next preset list even when in another app. The solution for me was, originally, to slide the top bar down and select radio that way, but now that I have LMT launcher installed I use that for just about everything, including switching between radio and other apps, it's so fluid to swipe from the bottom and up in whatever direction your desired app is in the pie. Another thing with the Radio is it's the only app I found that isn't affected by Viper EQ (Pandora and Poweramp work great with it), I think I may have found a solution to it that involves changing something in the build.prop (something about low power audio), I'll update once I try it out.
Oh! and one more update, about Pandora crashes. I cleared the cache, data, and reinstalled Pandora, after which I think I realized what makes Pandora crash. If you install Pandora and move it to the external SD it will start to crash, if you move it back to internal it will still crash. You need a clean install of Pandora and NEVER move it from the internal storage, if it does start crashing a lot, clear the cache and data and reinstall if necessary. Pandora has been cooperating much better since.
Deathalo is offline   Reply With Quote
Old 06-03-2014, 05:58 PM   #716
SPT Legacy
Drives: 2014 Lightning Red BRZ
Except the HD radio connector...had some trouble with the bezel going in all the way, the bottom right corner sticks out some.
Originally Posted by milhouse View Post
It plugs right in. I have a BRZ w/ nav and apart from the rear camera, the harness plugs right in.
SPT Legacy is offline   Reply With Quote
Old 06-03-2014, 07:04 PM   #717
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Originally Posted by Deathalo View Post
I can't remember exactly what that one is for but you're going to have at least one stock harness hanging there, at least if you don't have the AUX port adapter hooked up. None of that affects USB functionality though, USB is the easiest thing to hook up on this unit, if it's not working I'd contact them because your unit might have an issue.
That's what I thought. No biggie since the unit seems to be working all fine minus the USB problem. I sent them a email. Hopefully I don't have to ship it back to China..Shipping isn't cheap lol. Yeah USB seemed rather easy, but it wasn't working so I figured I'd ask here. All of you guys are very informative!
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 06-04-2014, 02:31 AM   #718
Orisai
Drives: Hyundai ix45
Once rooted, you'll need a text editor. I recommend Build.prop editor from the same developers as BusyBox. Once you have installed BPE, open the app, then edit the following lines:
– “lpa.decode=true” to “lpa.decode=false”
– “tunnel.decode=true” to “tunnel.decode=false”
– “lpa.use-stagefright=true” to “lpa.use-stagefright=false”
Once done, save the changes and restart your headunit.
These will unlock the full potential of the Android audio decoder by disabling the powersaving mode since it doesn't make sense on a car headunit.
Orisai is offline   Reply With Quote
The Following User Says Thank You to Orisai For This Useful Post:
Deathalo (06-04-2014)
Old 06-04-2014, 03:35 PM   #719
enjoi23
enjoi23's Avatar
Drives: FRS
I contacted the manufacturer with this issue and they suggested a factory reset. I've done it and it didn't fix my issue, but they said it's known to fix other problems with the unit. Just throwing that out there in case anyone else has had issues
Old 06-04-2014, 05:34 PM   #720
DC2R
Drives: 2014 Scion FR-S
I've factory reset a few times to fix issues lol.
Btw talked to will and he says they are working on extending the app partition
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
The Following 3 Users Say Thank You to DC2R For This Useful Post:
Deathalo (06-04-2014), enjoi23 (06-04-2014), Prog (06-05-2014)
Old 06-04-2014, 08:58 PM   #721
Deathalo
I went into the build.prop to change those lines, but they weren't there, I added them and put them as false but nothing changed. I realize that the Radio's built in EQ still works, so that's probably blocking Viper somehow (kinda like Poweramp did before turning it off in the settings), it's ok though, since every other app works with Viper; Slacker, Pandora, TuneIn, Poweramp, so the radio I can live with using the regular EQ.
Question for everyone else, has anyone gotten their google contacts to sync? Particularly with Google Now (Google Search), when I try and call someone it asks to say the contact name, but can't find any, and if I try and choose manually I can open the contacts app and there are none listed. Even though contacts are checked as synced in settings. Also, google now doesn't seem to find any apps in Tablet search, just contacts and "apps" but I can't choose specific apps I want it to search in, like I can on my phone. Any help with this would be appreciated, I'd like to use voice search in poweramp and the like. Oh and I tried using another app like contacts+ to sync my google account contacts, but it can't find them either.
Old 06-05-2014, 05:25 AM   #722
psyke
Drives: Toyota GT86
Has anyone yet tested if an external USB Sound Card is working?
Does the device have USB On-the-go?
psyke is offline   Reply With Quote
Old 06-05-2014, 07:00 AM   #723
DC2R
USB on the go is to connect full size USB to micro USB. What are you trying to accomplish?
Old 06-05-2014, 01:37 PM   #724
morphius88
R0GUE
morphius88's Avatar
Drives: 2013 Whiteout Scion FR-S
Got my unit yesterday. 2 weeks went by before they shipped it out. I guess they have many orders. Anyways, got everything installed thanks to Shifter and others for their posts in this thread. Helped alot.
My question/problem:
I read there was an update out and I was unable to find it on their site, so I found it here. How do I know my unit isnt updated already since it was shipped out after the update came out?
Heres a pic of what mine is running:
Also, yesterday I paired my phone with the device thru bluetooth and the music played fine. Today I turn it on and its skipping. I tried restarting the app, as well as restarting the unit (not resetting). Any ideas?
morphius88 is offline   Reply With Quote
Old 06-05-2014, 03:20 PM   #725
DC2R
I try to only use Bluetooth for calls and run everything off the headunit-I mean that's the whole point right? That being said I have been streaming audible the last two days from phone with no issues. perhaps you have interference. Bluetooth and Wi-Fi both use same spectrum so perhaps they are colliding-like I said not an issue on my install....btw I have phone mounted right next to had unit so reception is optimal
Old 06-05-2014, 03:54 PM   #726
morphius88
R0GUE
morphius88's Avatar
Idk. I did have WiFi on on the unit but it wasn't connected to anything. Just played music off the ad card without any issues so its possibly my phone is not liking it. I do recall similar skipping on another after market unit in someone else's car.. so it can be my phones problem.
Sent from planet Mars using HTC One
Old 06-05-2014, 04:14 PM   #727
enjoi23
enjoi23's Avatar
Drives: FRS
I'd recommend just using a USB drive or something similar for music. Nothing's wrong with the unit for it to be skipping like that, it's the phone signal. There's probably interference somehow. That happened with me on my old unit as well. New unit, same phone, same problem.
Old 06-05-2014, 04:17 PM   #728
enjoi23
enjoi23's Avatar
Drives: FRS
Also I'm completely wire illiterate. How do we hook up that amp wire to the stock harness? I try pushing it in but it doesn't fit lol. Can anyone take a picture of what it looks like?
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
