Old 06-04-2014, 11:55 PM   #4691
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Originally Posted by DeliciousTuning View Post
There is a very specific scenario (hiccup/missfire) we are seeing with a few select customers. You will need this configuration and meet these certain scenarios for this aspect to happen. (This does not affect 75mm pulley setups)
Parts on the vehicle
1. Innovate Supercharge with Intercooler
2. 70mm Pulley on The Supercharger
3. Flex Fuel Tune on the vehicle
4. Currently at about an E20-E30 mix (so mainly fuel but still some ethanol)
Logs in from vehicle
1. Car warmed up to about 80-90 degree Celsius
2. Intake temps around 15-25 degrees Celsius
3. Engine RPM around 5000 RPM
4. Engine Load around 0.75-0.85 (around 0 vacuum, so no boost 12-13 PSI, )
From what we are seeing, there is a hiccup/missfire that occurs in this scenario and I have a good idea of what it is. I will be verifying this over the next week (hopefully over the weekend) by installing a 70mm pulley on my personal vehicle which has the Innovate Kit of course. This way we can accurately reproduce this exact scenario and can run these exact conditions.
Running above 12-13 PSI with Direct Injection
I know there has been some problems that EcuTeK tuners around the world have been running into with respect to running PI/DI above 12-13 PSI. We did speak to EcuTeK about this a bit as we are tackling this from a completely different approach. It was a good conversation to understand the problems other tuners are running into and we did offer some hints into what we are doing to bypass these problems.
From what we have seen, most all tuners are either using a split PI/DI ratios to obtain optimal A/F ratios or pure PI approach. With the PI/DI approach at some point this is not scale-able, about 12-13 PSI. Now the pure PI approach is to just run pure PI (no DI at all under boost) and you can scale as needed but then you lose the ability to use DI effectively.
Now we (Delicious Tuning) have developed a technique with EcuTeK RaceROM that allows us to take full advantage of benefits of DI while being 100% scale-able. The OEM Manufacturers have spent millions if not billions of dollars developing these systems to improve their vehicles so we make sure to use them to their full potential. Even the new Subaru WRX comes with DI and DI only, and many manufacturers are following suit. Bye bye port injection, so you better get on board...
Here are just some of the reasons we use DI so extensively and some of the advantages of our tunes because of our in own house technique.
1. Cooler engine temperatures
2. Improved fuel economy
3. Tip-In knock elimination
4. Better, crisper throttle response
5. Smoother power delivery
6. More power with less total injector
As we have been doing for quite some time now we run our DI system to its full potential first and foremost and then add in PI as needed. This is much different approach and I believe something that only Delicious Tuning offers currently and something we are working with our lawyers on for an official Copyright.
As for running boost past 12-13 PSI with our technique described briefly above we have no problems running well above 12-13 PSI as we are 100% scale-able to 20+ PSI with no problems. Everyone is more than welcome to check out dyno charts in the MA Performance, Full Blown, FA20Club, JDL, Greddy, AVO, PTuning Turbo kits for more info on what we have accomplished.
Now with respect to stock injectors on this kit. We have not had a problem running completely stock injectors and fuel pumps on the Innovate Kits with 70mm pulley and intercooler. In fact with our DI->PI Technique (stock injectors) we can run turbo cars on E85 to about 360whp on a dynojet, so with that in mind there is plenty of room for the Innovate Kit to make power with stock injectors and room to spare. Hint hint...
Finally...
Hope that answers some questions, explains how our system works compared to others and answers concerns everyone might be having. Basically if you stay out of this particular range (stated above) you will not find yourself having any problems. It is definitely a unique situation we are working on as soon as we get a 70mm pulley on my personal vehicle.
Cheers,
William Knose
My car runs only on 93 octane and has the hiccups happening. If needed I can send you some logs in the morning?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 06-05-2014, 12:12 AM   #4692
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
X2.......been having the issue since my first flash which was the 8.58 tune. Thought it was all vacuum related. Fixed the one and only vacuum leak I could find. Still have the sputtering. Been dealing with it for a month now.
Dustin is offline   Reply With Quote
Old 06-05-2014, 12:16 AM   #4693
CK_Bladesmith
Drives: Raven FR-S
Yeah I thought my bypass valve in the back of the charger wasn't functioning properly, but it works just fine. I'm not very worried about the sputtering, it's just an inconvenience.
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
Dustin (06-05-2014)
Old 06-05-2014, 12:17 AM   #4694
Dustin
Twin Screw You
Dustin's Avatar
Same here. Looking forward to what Bill comes up with.
The Following User Says Thank You to Dustin For This Useful Post:
CK_Bladesmith (06-05-2014)
Old 06-05-2014, 12:23 AM   #4695
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Definitely seems to be related to non-ethanol or very low ethanol tunes from what we have seen at very low loads and it definitely does not happen on the 75mm pulley as I tried my hardest to get it to happen tonight with no luck
Well we will be working on it as soon as we get the pulley on the car. Just stay out of the range for the time being (under low loads), otherwise just floor it.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
CK_Bladesmith (06-05-2014), Ethan (06-06-2014)
Old 06-05-2014, 12:26 AM   #4696
CK_Bladesmith
Drives: Raven FR-S
Cheers,
William Knose
Exactly what I do Bill, although that's probably why my fuel mileage sucks like it does :P. I'll swap to the 75mm pulley and see what happens tomorrow, just for my own curiosity. Appreciate everything Bill.
mikalem (06-05-2014)
Old 06-05-2014, 12:31 AM   #4697
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Cheers,
William Knose
Can second - not sure I made it clear in the emails to you Bill but I never saw the behavior under WOT with that range, and didn't see it at all with the higher E content WOT or not. Waiting to see what results you get with the 70mm in your own testing and thanks for responding in so much detail.
mikalem is offline   Reply With Quote
Old 06-05-2014, 12:34 AM   #4698
TemeCal
Drives: 86
Innovate (Sprintex) Supercharger Owners Topic
This is all very interesting. Knock on wood, this has been the best tune for me by far. No sputtering, no CELs, ultra smooth and my IAM and knock correction looks great. Hope it all works out for you guys!
Edit: just realized this has more to do with those running flex fuel. I'm running on 91
TemeCal is offline   Reply With Quote
The Following 2 Users Say Thank You to TemeCal For This Useful Post:
CK_Bladesmith (06-05-2014), DeliciousTuning (06-05-2014)
Old 06-05-2014, 12:47 AM   #4699
Dustin
Twin Screw You
Dustin's Avatar
I might change to the 75mm pulley as well to see how it does.
Old 06-05-2014, 03:55 AM   #4700
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not at all, after a decent in depth chat with Cosworth's head engineer last week he informed me that a lot of the manufacturers that were "DI only" are now reverting back to dual systems as the PI has it's benefits.
I certainly hope that you're not running 100% DI for most of the time as it's common knowledge that running DI only will mean that the valves etc end up with a build up of deposits over time.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2014, 10:01 AM   #4701
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Any thoughts @jamesm? I love the idea of copyrighting a tuning technique within EcuTek.
sw20kosh (06-05-2014)
Old 06-05-2014, 11:56 AM   #4702
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Not sure what copyright would mean in this case. A patent for using di? Weird stuff.
Old 06-05-2014, 01:50 PM   #4703
DeliciousTuning
A great comment and first understanding why the intake valves have carbon build is important. Usually a carbon build up on back side of the intake valves is due to a couple things, first and foremost the engine breathers return oil and exhaust fumes through the intake track to the back side of the intake valves. The other scenario is when the exhaust and intake valves overlap a small amount of exhaust gases will find there way to the back side of the intake valves.
With that in mind once manufacturers find a cheap and economical way to clean the air from the engine breathers to the intake track (while being legal to various governing boards) this will take care of most of the problem of carbon build up on the intake valves. Porsche's have incorporated their own air/oil separator into their higher end vehicles to combat this problem. They have a lot fewer problems with carbon build up compared to say Audi which has a lot more carbon build up problems.
Now adding in port direction is definitely a great way of cleaning up the back side of the intake valves in the mean time but pretty sure manufacturers are looking for cheaper ways of producing their vehicles (the reason they used DI only). I assume it will just be a matter of time before it happens. Who know what it will take for it to happen though.
Now with respect to our tunes we do use DI heavily in our tunes but we also use quite a bit of PI, which will of course combat the carbon build up issue. Looking at a log from one of our tunes will show as much.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Kodename47 (06-05-2014)
Old 06-05-2014, 08:07 PM   #4704
jamesm
It's impossible to copyright a technique of any kind in the US. Specifically, ideas and techniques cannot be copyrighted but the expression of them can. So, you can copyright a written description of a technique, but this does nothing at all to prohibit others from employing it.
Of course everyone knows my personal opinion on things like this... so no need to reiterate. Suffice to say, regardless of whether you think it's right or wrong, it can't be done. You'd need a patent, and prior art would prevent that as well.
The Following 4 Users Say Thank You to jamesm For This Useful Post:
s2d4 (06-05-2014), sw20kosh (06-05-2014), Toyota86.ir (02-25-2016), Xero-Limit (06-05-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
