Old 06-04-2014, 11:29 PM   #1373
gmsii
gmsii's Avatar
Originally Posted by gmsii View Post
more specifically....which blower (c30 or c38) and pulley (std or highboost) do you have?
very nice....if you plan on using e85 regularly you should get the high boost pulley upgrade....you'll be blown away by the results
gmsii is offline   Reply With Quote
The Following User Says Thank You to gmsii For This Useful Post:
zoth (06-04-2014)
Old 06-04-2014, 11:45 PM   #1374
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Good to know, but for now I'll be playing it safe for now. With the high boost pulley will @KraftWerks still honor the 2 year warranty on the Rotrex blower.
zoth is offline   Reply With Quote
Old 06-04-2014, 11:50 PM   #1375
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by zoth View Post
@digital_assassin quick update on Corn Juice. 1st Flex- E-Tune file from Moto-East. Display reads E82.
The power is nice, and I know it is a first E-tune version but the fueling seems a little all over the place or maybe it is just how your software logs? Just use to seeing more stable Air Fuel Ratios under boost.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
zoth (06-05-2014)
Old 06-05-2014, 12:02 AM   #1376
captain_jack
captain_jack's Avatar
Cheers,
William Knose
Thats what i was thinking, the afr seemed to bounce all over. Nice power though for sure.
sent from your mom
Old 06-05-2014, 12:16 AM   #1377
zoth
zoth's Avatar
Cheers,
William Knose
@moto-mike said he will work on the AFR.
Old 06-05-2014, 02:06 AM   #1378
gmsii
gmsii's Avatar
the 2year warranty won't be affected...the standard pulley under spins the rotrex because we didn't want to make too much boost especially for those enthusiasts that can only get crappy 91 gas ...the high boost pulley actually utilizes the full capacity of the rotrex and is a great option for those who have easy access to higher octane fuels
As for 'safe' ...it's all about the tuning...we have 'safely' run c38 blowers on 91 octane...with 91 we couldn't run much timing so power output was limited ...but on 95 or e85 the 38 is an absolute beast
You should consider trying a KW e85 tune....it is already scaled to run perfectly with the std setup or the highboost setup...you won't need to retune when u upgrade to the highboost pulley
Old 06-05-2014, 07:29 AM   #1379
TmP
TmP's Avatar
Drives: A bunch of 'em...
http://www.rgvpca.org/
Wish I could drive down there. I'm just "Scared Sh!tless" to go down. lol
Mkay... so these aren't at an actual race track then?
Pass. haha
Honestly, it's not as bad down here as you may think.
And one of the track days would totally be worth the drive.
You can make it down here in like 2 hours and a track day is ALL day...
The amount of seat time you get for the money is ridiculous.
Dude, entry fee is like 40 bucks! lol
And turnout is low, not like in the states where you have to wait for hours to drive 5 minutes.
Just sayin'.
I'm not Mexican either if that wasn't obvious until now.
TmP is offline   Reply With Quote
Old 06-05-2014, 08:37 AM   #1380
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Cheers,
William Knose
As you know that depends on how the sensor is calibrated. Anything below 12.5 is not worth much with the OEM sensor. There's also some advantages to optimizing the VVT for overlap which will show leaner as well.
Xero-Limit is offline   Reply With Quote
Old 06-05-2014, 02:17 PM   #1381
DeliciousTuning
Great point to bring up on the front wideband O2 sensor. You are correct it does not read below 12.5 on the stock calibration, so this was the reason why we have spent some time re-calibrating all our tunes to read the OEM front wideband down to about 11.2 (based on a Motec PLM sensor). This gives us more room to custom tune vehicles remotely while keeping the costs down for the end customers. Of course if customer want to, they are more than welcome to add them into our tunes as an additional source for A/F readings.
Cheers,
William Knose
Taino-BRZ (06-05-2014)
Old 06-05-2014, 02:49 PM   #1382
Taino-BRZ
Taino-BRZ's Avatar
Drives: Subaru BRZ-SWP
Tried the delicious tuning tune yesterday on 91 and wow, very smooth I'm near empty tank so I'll be trying e 50 transition map and the e85 map later this week along with some dyno charts. Overall the tune seems very well designed very linear power and good top end. Great customer service as well by @DeliciousTuning.
Sent from my SGH-M919 using Tapatalk
Taino-BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Taino-BRZ For This Useful Post:
86SPEED (06-06-2014), DeliciousTuning (06-05-2014)
Old 06-05-2014, 02:52 PM   #1383
TmP
TmP's Avatar
How does this work with delicious.
Can they tune my car past what the KW map can do even if I don't have access to a dyno?
Old 06-05-2014, 03:13 PM   #1384
Taino-BRZ
Taino-BRZ's Avatar
Yes, go to their website and select the map you want and all the features you want like launch control, flat foot shifting, auto blip, traction control, select the type of gas and you can ad e85 for a little $$ if you have the tune from kw you don't need the cable or license. Just the tune. They are off the shelf maps but you get one free revision and they would fix or improve anything they can after you send the logs.
Old 06-05-2014, 03:18 PM   #1385
TmP
TmP's Avatar
Ok... So how can that wok if I don't need a cable?
How do I flash the car? You lost me there...
Old 06-05-2014, 03:26 PM   #1386
captain_jack
No you already have a cable and a license so it's just a tune with options your buying. You need a cable but you already have that.
may the schwartz be with you....
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
