#43 |
Drives: '14 FRS
So far all I have is RCE Yellows, and Im looking to get some wheels and tires, Also Im not an expert on suspension at all but was just wondering...
I have been looking into RPF1's, I know they are super common but they are really light and look decent dont know whats better, 17x8 with michelin PSS, or 18x8 with PSS?? 245 tires??
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
#44 | |
Drives: 13 BRZ Limited WRB
I'm going to assume since I bought Tarmac 0's with the optional 350lb springs, and lowered as you see below that I have NOT f'd up my track handling characteristics vs stock.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#45 |
Drives: Turbo BRZ & Supercharged E90 M3
checklist complete! lolllllllll
For rolling around on the street it doesn't make a difference. Track set up, yeah I totally ruined it.
#46 |
That Guy
Drives: 2013 asphalt FRS MT
So what would be a good tire choice for RCE yellows on stock damper? And RCE blacks on Konis or Bilsteins?
#47 |
Drives: 2005 Toyota Camry
Funny... I violate both #1 and #2 (staggered, 18" multi-piece wheels) and the car rides/drives fine on LA streets.
-alex |
#48 |
Drives: Asphalt FR-S
#49 |
Turbo 86
Drives: GT86
10 - 1 = 0
real math |
#50 | |
#51 |
Drives: BRZ Limited
Yeah I have said for years if you have to change the offset on your wheels to get them to fit, they're too damned wide.
I prefer to run the same offset as the stock wheel whenever possible. The suspension designer specified it that way for a reason, I figure he knows what he's doing. That's my grumpy old man opinion and I'm sticking with it. |
#52 | |
Drives: BRZ Limited
I'm thinking maybe I should go with the 7.5" wheel. |
#53 |
@Racecomp Engineering
I want to get rid of the tucked look. I am running 17x7.5 Rota Torques with PSS's in 225/45/17's. I am going to be adding the eibach Pro springs (1inch drop). My wheels have stock offset of 48. I want to bring them out to remove the tucked look. Getting new wheels is not an option so spacers with extend wheel studs are my only option. I have 20mm and 15mm spacers. Bad or good idea? To much? If so whats the max that's still safe on the track. |
#54 |
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Pic is a little irrelevant to my question. The pic mainly focuses on neg effects of slamming the car (which I never asked about; I didn't inquire about slamming dis whip yo)
#55 |
aeiou
Drives: WRB BRZ
RCE and CSG in the same thread!!! :fap:
I plan to go 1.5" lower front + rear. Post above reminds me... what do you guys recommend as far as roll center correction? I know you guys don't recommend staggered setups, but what about spacers in the rear with a square setup? Specifically, this style: |
#56 | |
It's the opposite. Too wide; and it's safer/easier to use closer to stock offsets to make them fit. And, the narrower the wheel, it's safer and easier to use lower offsets to make them fit. A 9" would actually fit better with a closer to stock offset (ie: +44et) than a "changed offset" ..because it won't poke as much and also it won't rub on the outer fender (but, it may rub on stock lower spring perches). So does this mean they're not too damned wide like you said? Probably not; but that is subjective. "Fit" is relative and subjective...and many actually see that stock wheels don't exactly "fit" in the first place, because they are too sunk in. So, many change the offset and get wheel spacers to make them flush or get new wheels that aren't as sunk in. So.. since stock wheels don't "fit" and many change the offset..does this mean they're too wide? Not at all..they're pretty skinny and narrow. It's all subjective
| BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) | runny_yolk | Electronics | Audio | NAV | Infotainment | 120 | 01-29-2021 06:18 PM |
| step 1 :buy frs in phx, step 2: drive to pikes peak | haymaker | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 15 | 08-21-2012 10:44 AM |
| [StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:38 AM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
