Old 06-04-2014, 05:27 PM   #29
gramicci101
Off Topic
I would imagine it has something to do with increased scrub radius and stress on related components.
edit Apparently I'd be wrong though.
Old 06-04-2014, 05:28 PM   #30
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I already said besides aero or additional bearing load though.
That isn't too low an offset either. More flush if anything. It's not like it's poking out 5" like a parachute lol...maybe only a few mm's at most.
Isn't saying it'll hurt aero kinda exaggerating?
Wouldn't flush be better than sunk, aero-wise? ..since there's no void/deadspace in the sunk wheelbase that'll result in air flow disturbance.
fooddude is offline   Reply With Quote
The Following User Says Thank You to fooddude For This Useful Post:
Scrappydoo (04-01-2017)
Old 06-04-2014, 05:33 PM   #31
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
7. Tire choice
Really stiff springs with all season or OEM tires can reduce grip as you'll be quickly/easily overloading the tire. Match your spring rates to your tire choice.
Running sticky tires on soft OEM springs is a problem too, but you will still gain grip from the tire. It'll just feel sloppy and move around a lot.
So what exactly is too sticky of a tire? Are Pilot Super Sports too sticky or are we talking like R comps?
rapidcars is offline   Reply With Quote
The Following User Says Thank You to rapidcars For This Useful Post:
Pseud0logik (06-04-2014)
Old 06-04-2014, 05:34 PM   #32
s2d4
s2d4's Avatar
14.5mm then you got to put tyres on it, looks like you'll be doing stance to get it to fit.
Old 06-04-2014, 05:37 PM   #33
fooddude
Ah, yes...scrub radius will def be affected. Idk if negatively though..perhaps.
Stress on parts..ya, I already mentioned extra load on wheel bearings.
Old 06-04-2014, 05:40 PM   #34
fooddude
14.5 is nothing.
Idk what "stance" is..but I think you're referring to the slammed car look?
"Stance showcar fitment" ...Not necessarily though..all that's needed is -2to-3 front camber to make it look/fit perfectly ..which you'd already be doing anyways if you'd be tracking the car.
Old 06-04-2014, 05:40 PM   #35
gramicci101
Off Topic
Steering parts, too. Now instead of twisting the wheel in place, the steering system is trying to swing it in an arc. Add on some awesome 140 tread wear tires and that's a lot more traction it has to overcome to swing the wheel around.
The Following User Says Thank You to gramicci101 For This Useful Post:
fooddude (06-04-2014)
Old 06-04-2014, 05:43 PM   #36
s2d4
s2d4's Avatar
14.5 is nothing.
Sure, just do it.
Old 06-04-2014, 05:47 PM   #37
fooddude
Ok...so we've pointed out some cons..
...but what about the pros? (I'm sure there's some pros...unless we truly are all pessimistic/cynical in here haha )
...wider width..better cornering ..better stability, right?
chas3wba0 (06-05-2014)
Old 06-04-2014, 05:50 PM   #38
Davey
Drives: BRZ Limited
I'm interested in doing 17's but I can't decide if I want to go with a 7.5 or an 8" rim.
With the 17x8 I can run a 215/45R17 (stock size) or a 245/45R17 and be really close to stock diameter, or even a 235/40R17 (a bit shorter) or 225/45R17 (taller). That's a great range of tire sizes, so the 17x8 seems attractive. Especially for the 245's.
I would probably do 215's for now and go from there, as my car is and will remain stock power levels for some time. I think some Michelin PSS in the stock size on some nice light 17's would be the trick.
Now we get to the questions...
1. I have heard that running a tire on its max rim width give better turn-in but is less predictable. That's what I'd be doing, running the 215 on the 17x8. How squirrely would this be?
2. Running 245/45R17 (Let's say PSS again) with otherwise stock suspension on a +45 or +48 wheel, what are the chances of it rubbing?
I guess I'm thinking, sticky 215's would be plenty for now, but I don't want to regret 17x7.5" rims if the 8's would be more or less the same.
Davey is offline   Reply With Quote
The Following User Says Thank You to Davey For This Useful Post:
mitosis (06-05-2014)
Old 06-04-2014, 05:50 PM   #39
gramicci101
Off Topic
Well, I just received 20/25mm spacers for my OEM wheels, so I'll find out. Then too, I don't track my car; I bought spacers to push the wheels out so they don't look sunken in.
ansibe (02-11-2016)
Old 06-04-2014, 05:54 PM   #40
RedBRZ80
Drives: 2013 Red BRZ
This message can't be overstated. Great post!!--
And btw.. My RCE tarmac2s are awesome!!
RedBRZ80 is offline   Reply With Quote
The Following User Says Thank You to RedBRZ80 For This Useful Post:
Racecomp Engineering (06-04-2014)
Old 06-04-2014, 06:17 PM   #41
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
So you are saying that i shouldn't put 22in Chromies on?
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
The Following 3 Users Say Thank You to fuddbutter For This Useful Post:
boost86 (09-09-2014), BRZZZZZZZZZZ (06-05-2014), funwheeldrive (03-15-2017)
Old 06-04-2014, 06:29 PM   #42
It depends. Generally I say pick tire compound first, then everything else falls in place.
Pilot Super Sports are a great sticky summer tire that does well for most people. On stock suspension it'll be fine...more camber and maybe a little more roll resistance would make me "happy" with them but still good.
With R-compounds you'll definitely want firmer springs, probably coilovers.
And on the flipside, very firm coilovers with the OEM tires is going to lose grip easily.
- Andy
Pseud0logik (06-04-2014), rapidcars (06-05-2014)
BRZ Limited Backup Camera Step by Step (WARNING long post, many pictures) runny_yolk Electronics | Audio | NAV | Infotainment 120 01-29-2021 06:18 PM
step 1 :buy frs in phx, step 2: drive to pikes peak haymaker FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 08-21-2012 10:44 AM
[StreetFX] License Plate LED light upgrade, and DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:38 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
