Old 06-04-2014, 05:44 PM   #1
FirestormFRS
DIY-Scratch & Dent
Note to all you professional paint and body guys I know there is probably some easier/better way. I took this on due to the $48hr labor and 100% mark up on supplies.
Riding to work one morning and a muffler clamp flew from under the car in front of me, skiddered across the concrete and flew up. The clamp mangled my right front fender. Body shop quotes $460-$602 to repair. I decided to tackle it myself.
1. Sand, Fill, Prime the three nasty dents and scratches. I used 240 grit to get the scratches. Used self etching primer on the one due to it being to the metal. Used glazing putty to fill the voids.
2. Shot the entire area with filler/primer combo. Sanded with 400 then wet sanded with 1000.
3. Shot three coats of base coat. I used touch up direct matched to the car. I tried scratch wizards and it didn't match. Wasn't even close. Yes this was shot with a rattle can.
4. Removed the vent garnish and used a gray scotchbrite pad to scuff the entire fender. I know you can blend clear but you can't with rattle cans and it's easier this way. I did use the crease at the bottom as a stop point.
5. Important part. I used SprayMax 2k rattle can clearcoat. Don't use the cheap stuff. The clear is $28 a can but it's two part epoxy clear and will go on better and stand up better.
6. Wet sanded with 1200, then 1500, then 3k to remove the orange peel and got it as smooth as I could. Match was perfect and red is supposed to be difficult to blend. Maybe I got lucky.
7. Used Meguires ultimate compound and hexlogic orange pad with DA polisher to take out the sand marks. Then polished with Mequires ultimate polish and hexlogic green pad to polish.
Could a body shop do it better. Absolutely. Could I have done better. Sure. I learned a lot in the process and saved a lot of money doing it myself. Total cost $125 with paint, clear, primer, sandpaper, and chemicals.
FirestormFRS is offline   Reply With Quote
The Following 9 Users Say Thank You to FirestormFRS For This Useful Post:
aakash (06-14-2014), CK_Bladesmith (06-10-2014), DAEMANO (08-04-2014), draggin_az (06-16-2014), H1C (05-17-2019), P@ul (07-10-2014), SkAsphalt (06-04-2014), SpeedyJay (06-13-2014), SuperTom (09-23-2018)
Old 06-04-2014, 05:49 PM   #2
vividracing
vividracing's Avatar
Looks good. Someday, I'll grow some balls and tackle paint myself.
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
FirestormFRS (06-16-2014)
Old 06-04-2014, 05:52 PM   #3
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
We prob need better daylight after pics to prove "perfect" match.
Old 06-04-2014, 06:02 PM   #4
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Daylight or not, I applaud your massive balls. Well done sir!
Subaru STI :
The Following 3 Users Say Thank You to Kimsey47 For This Useful Post:
draggin_az (06-16-2014), FirestormFRS (06-16-2014), SkAsphalt (06-04-2014)
Old 06-04-2014, 07:43 PM   #5
ScorpionOzzy
Drives: Scion FR-S
well done! I definitely wouldn't have the guts to do this stuff, but props to you .
ScorpionOzzy is offline   Reply With Quote
The Following User Says Thank You to ScorpionOzzy For This Useful Post:
Old 06-13-2014, 05:50 AM   #6
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
will sanding remove dents?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-13-2014, 06:03 AM   #7
Yrr
Yrr's Avatar
Drives: Toyota GT86
Great job!
Yrr is offline   Reply With Quote
The Following User Says Thank You to Yrr For This Useful Post:
Old 06-13-2014, 06:17 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
no you need to fill them or pop them out. sand the dent so the filler bonds better
Old 06-13-2014, 10:09 AM   #9
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
dude....nice work.
The Following User Says Thank You to SloS14 For This Useful Post:
Dent :( Will paintless dent removal be able to get this out? Greg_Di CANADA 22 09-01-2013 12:22 AM
I got a slight scratch dent... SPEEDGOD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-26-2013 12:37 PM
dent / scratch repair encity5 NY / NJ / CT / PA 1 12-12-2012 10:09 PM
Scratch/Dent Bespoke Unit $340 Shipped Hanakuso Audio/Visual, Electronics, Infotainment, NAV 1 11-05-2012 06:20 PM
Scratch + dent on rear quarter panel - fix or no? rawbz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 10 08-26-2012 12:50 PM
