#15 | |
Rear shock yes use ours. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | was385 (06-04-2014) |
#16 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
If you plan to compete in STX you may want to consider skipping 225s and going straight to 245s or 255s with a 9" wide wheel to maximize your chances.
I run B8s with RCE Yellows and I am also quite happy, but I also run different tires and wheels and a lot more camber as well. |
| The Following 3 Users Say Thank You to BRZZZZZZZZZZ For This Useful Post: |
#17 | |
Drives: MT WRB BRZ Limited, 2007 911s
Gotta stress this. My club has a bunch of different STX twins. Most of us are on RCE yellows/stock dampers and 245 ZIIs but one is on B8s, springs, and 225 ZIIs and has been quite a bit behind in times. I think to some extent he's just limited by tire size. |
| The Following User Says Thank You to was385 For This Useful Post: | BRZZZZZZZZZZ (06-04-2014) |
#18 |
Car Nut
This is kinda my experience as well, I am just finishing my 225s on 16x7 TE37s and I just can't get the same lateral grip levels as the guys with similar suspension setups and 245s. As such I have some 17x9s with 255 Z11s on order.
#19 | |
Drives: 2013 Whiteout Scion FR-S 6MT
#20 | |
#21 | |
![]() - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | husker741 (06-04-2014) |
#22 |
Thanks! I haven't really looked much into because it's further down the road (again, I hope the stock struts hold up awhile), but I'm just trying to see my options. I know some people have had issues with their Konis, and I know Bilstein is great and used by Toyota in other applications. I also like that they serve as an entire strut, not just an insert.
| The Following 2 Users Say Thank You to husker741 For This Useful Post: | Apoc (06-04-2014), Racecomp Engineering (06-04-2014) |
#23 |
Car Nut
Raceseng cascam plates and SPC rear LCAs. It rides fairly well but our roads here are crap and I couldn't take it everyday so I no longer daily drive it, and drive a beater everyday instead.
#24 | |
Off Topic
With that said, drivetrain bushings are an easy kill. Whiteline transmission insert, diff collar inserts, and rear subframe inserts will do a great job of keeping things from flopping around. |
#25 | ||||
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
I do not have a huge amount of discretionary income to throw around so the mods are very slow and steady. I will likely need new tires long before I can afford both wheels and tires, hence going to 225 on stock wheels. Sent from my SM-G900V using Tapatalk
#26 |
Do you need top plates for just springs and the B8's or will camber bolts do just fine? And then SPC LCAs for the rear.
#27 |
#28 | ||
Serial Cone Killer
| Suspension Review: Eibach Pro-Kit Lowering Springs | DarrenDriven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 136 | 10-09-2020 06:26 PM |
| BRZ DRIVEN FULL REVIEW (lowering springs pics too) | Racecomp Engineering | BRZ First-Gen (2012+) — General Topics | 99 | 12-14-2019 05:14 PM |
| Suspension Review: Eibach Sportline Lowering Springs | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 07-23-2019 09:59 PM |
| RCE Springs from Tarmac Zero - 280# NEW | jack43 | Brakes, Suspension, Chassis | 0 | 03-22-2014 02:41 PM |
| CG 35mm Lowering Springs Review (PICS) | Tylub | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 05-29-2013 04:54 PM |
