Old 04-07-2012, 02:38 PM   #1
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Fuel Additives
I know this may be a noob question, but I was wondering if fuel additives do anything and is it worth it?
ArKiTeCkT is offline   Reply With Quote
Old 04-07-2012, 04:07 PM   #2
ahausheer
Re-member
Drives: Toyota camry
Of course this is debatable but I have seen no research other than that done by the additive companies that suggests they are ''worth it''. If you have an old carbureted engine that was poorly taken care of then they could help clean stuff out but in modern engines and with modern fuel standards they don't do much if anything. The additives designed to increase the octane rating will foul plugs pretty good, usually turning them orange, test it yourself, the plugs foul in as little as a tank or two and the octane increase is negligible at best. I have used chevrons fuel additive a few times as it seems to be a quality product that wont do any damage, still have no idea if it actually did anything productive. I know importtuner.com tested a few additives with a dyno and found none of them were worth it. May want to search their site as well. Also on a personal note I properly cleaned my 1986 camry engine with seafoam, it got rid of all the gunk, but that gunk was helping fill in wear in the cylinder ( I think) and the car started burning significant oil immediately after I did this. Look at it this way, if they actually did anything most of the mags/reporters would have already proved it and all us car guys would be using them. If they really worked well it would not be debatable.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 04-07-2012, 04:37 PM   #3
ArKiTeCkT
ArKiTeCkT's Avatar
Thanks for your knowledge, I was planning to purchase a BRZ here in Canada and wanted to ensure that the car lasted more than 5 years at least.
Old 04-07-2012, 05:31 PM   #4
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Quality fuels like Shell V-Power have enough cleaning agents and are well tuned for direct injection. If you stick with quality fuels, you should have no need for additional additives.
Bristecom is offline   Reply With Quote
Old 04-07-2012, 06:05 PM   #5
Jordo!
Enjoy it, destroy it.
Jordo!'s Avatar
Drives: Datsun Racing Hen
The short answer is: NO.
Use top tier fuels and don't waste your time with octane boosters -- you will be lucky to get even a full point increase from any of them.
Jordo! is offline   Reply With Quote
Old 04-07-2012, 06:15 PM   #6
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Why does this thread reminded of the guy who put NOS energy drink in his gixxer and went global!
The Following User Says Thank You to RRnold For This Useful Post:
Turbowned (06-10-2012)
Old 04-07-2012, 09:09 PM   #7
Bristecom
Bristecom's Avatar
Originally Posted by Sleeperz View Post
Use synthetic oils like Mobil 1 to increase the engine life. One of Synthetic oils claim to fame, is it lubricates better when first starting a cold engine left sitting overnight which is when the most engine wear occurs.
He was talking about fuel not oil. :P
Old 04-08-2012, 10:30 AM   #8
Baldeagle
Drives: VW GLI 6MT
Wouldn’t logic dictate that since top tier gas distributers add their own additives (ie: techron), that the fuel system, intake valves and cylinders would in fact get gunky if they were not “cleaned” regularly by these additives? If one were to claim additives were bad, then why buy top tier fuel since that is what they contain? If one were to agree that engines naturally get dirty and that top tier fuels with their additives are beneficial, wouldn’t that be an argument that other store-bought additives may in fact help an engine?
Baldeagle is offline   Reply With Quote
Old 04-08-2012, 11:31 AM   #9
ahausheer
Re-member
I doubt it's that simple. Obviously ''additives'' are extremely beneficial when comparing modern fuel with that from a few decades ago but the fact remains, there is only very limited evidence that off the shelf ''additives'' have benefits above and beyond the additives already in the fuel. Don't get me wrong I still use the occasional can of Techron because I reserve the right to be a hypocrite. I just dont think the additives in the occasional 12 oz can of anything can compare to the additives in thousands of gallons of modern fuel. I am not an expert and have no literature to support my thoughts so the debate will continue something along the lines of this:
Old 04-08-2012, 12:13 PM   #10
Dimman
Kuruma Otaku
Dimman's Avatar
Apparently octane boosters used to be pretty effective but not anymore. Environmental, health/safety or economic changes?
In Canada I'll be feeding mine 94 from Chevron.
Because titanium.
Old 04-08-2012, 06:19 PM   #11
serialk11r
Drives: '06 AM V8V Coupe
Octane boosters I've heard of all kill your cat or related emissions equipment or worse...
Old 04-08-2012, 06:26 PM   #12
Dimman
Kuruma Otaku
Dimman's Avatar
Could be why all the new ones are nerfed. They don't want to or aren't allowed to screw up emissions.
Because titanium.
Old 04-11-2012, 03:26 PM   #13
2jzge
Drives: Jeep
Helpful tip:
There was one time I ran out of gas (I had a malfunctioning level gauge in an old car due to fuel system modification) and the gas station that I stopped 40 yards away from was out of gas tanks. Instead of pushing my car to the pump I grabbed 3 bottles of Octane booster. It was just enough to get me to the pump. This is the only time I've used an octane booster.
In the SVT community octane boosters are used when VP racing fuels aren't on site at the strip. However I do not think its the boosters sold at gas stations.
2jzge is offline   Reply With Quote
Old 04-11-2012, 05:06 PM   #14
Sport-Tech
Sport-Tech's Avatar
Drives: TBD
May be a bad plan unless they guarantee no ethanol - see http://www.ft86club.com/forums/showthread.php?t=4925
Sport-Tech is offline   Reply With Quote
Fuel Filler is on the Right!! Guaruja Scion FR-S / Toyota 86 GT86 General Forum 43 04-01-2012 05:55 PM
Premium Fuel riceracer8888 Scion FR-S / Toyota 86 GT86 General Forum 64 12-16-2011 10:27 AM
Wrong Fuel Hawx AUSTRALIA 22 12-11-2011 06:08 PM
E85 Fuel? Siriusly.Andrew Scion FR-S / Toyota 86 GT86 General Forum 60 02-11-2010 05:00 PM
Flex Fuel? VenomRush Scion FR-S / Toyota 86 GT86 General Forum 12 01-15-2010 02:55 AM
