Old 06-03-2014, 08:10 PM   #225
OrbitalEllipses
Drives: Attitude
Beefy? I thought that's what the first B in BBK stood for. Beefy Brake Kit.
*Burger patty not included.
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
chanomatik (06-03-2014), civicdrivr (06-04-2014)
Old 06-04-2014, 04:27 AM   #226
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thought i'd share what I found in my local hardware store recently. I haven't used it yet, but got it anyway as it may come in handy.
This should be a perfect solution to anyone who's having difficulty removing the stubborn allen bolts on the caliper when trying to swap bleeders around.
Fizz is offline   Reply With Quote
Old 06-04-2014, 06:45 PM   #227
grostoine
Drives: Subaru BRZ
Wanted to have some advised for those who made powdercoat their brembo caliper! Did you split your calipers in two?
grostoine is offline   Reply With Quote
Old 06-04-2014, 11:00 PM   #228
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Ironsquid View Post
Had to cancel for this weekend. Have to wait for another event. We finally got our last rotor delivered, and some needed suspension parts. Just not enough time to get everything dialed in with seat time before this weekend.
Lesson learned, don't change too much right before a track event.
Damn, I'll be at Sebring Saturday. Driving the beater for one session than the race car beater. BRZ Garage Queen stays in the garage where it "belongs".
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-06-2014, 08:57 AM   #229
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
I would not do this. Once these brakes are cast and brought together they form a nice cohesion together. If you have to rebuild them it's at least recommended to recombined the same two halves again.
I have a couple friends that bought reman'd brembos and they don't fit right because the reman company doesn't re-use the same halves.
Ironsquid is offline   Reply With Quote
Old 06-06-2014, 09:00 AM   #230
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I tried removing mine, the real problem is they used permanent locktite from the factory. This locktite is harder than the soft metal used for the allen bolt.
I tried on 4 different allen bolts, using heat, pb blaster, etc. The metal is too soft and the locktite is too hard.
So I ended up bleeding the brakes with everything flipped upside down, then flipping it back to normal. Pain in the butt, but better than drilling out allen bolts.
Old 06-06-2014, 09:06 AM   #231
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
If all goes as planned, I'll have these on the front in the next couple weeks
Old 06-06-2014, 09:21 AM   #232
grostoine
Drives: Subaru BRZ
I only have one set and i've double chek, you can't put two halves that wasn't with each others... There is one pair for the right, one for the left. I'm not worried about that.
I wanted some advise regarding the o-ring between the two halves...
Old 06-06-2014, 10:16 AM   #233
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
If you're going to split them why not replace it? Thats like taking a timing belt off and then reusing it. Works already done, maybe $1-$2 to replace
Old 06-09-2014, 07:46 PM   #234
RB Performance Brakes
RB Performance Brakes's Avatar
Drives: BRZ/FRS
For those of you planning on retro fitting or already have the STi Brembo calipers.
RacingBrake offers Front Light Weight Two Piece Rotors for Subaru STi’s (2004-2012)
That will work with your FRS/BRZ STi Caliper swap.
(Hats have both 5x100 + 5x114.3 bolt pattern)
FT86Forums member receive free shipping to the lower 48 states using coupon code FT86-SHIP
Reference Photo
RacingBrake Rotors feature 3 patented designs
  • Center Mount – Hat mounts onto the surface of the rotor ring, balancing stress load and improving cooling by allowing air flow to enter from both the inboard and outboard side of the rotor
  • Convergent Vane – Provides efficient air flow and temperature across the disc surface
  • Open Slot – Advantage of both drilled and slotted, optimizes the friction between pad and disc
Street and Track brake pads are also available for your STi Calipers.
To learn more about us,
Visit our website at
www.RacingBrake.com
RB Performance Brakes is offline   Reply With Quote
The Following User Says Thank You to RB Performance Brakes For This Useful Post:
chanomatik (06-09-2014)
Old 06-11-2014, 03:26 AM   #235
Hachiroku14
Drives: 2014 BRZ World Rally Blue
Hachiroku14 is offline   Reply With Quote
The Following 8 Users Say Thank You to Hachiroku14 For This Useful Post:
Andreas83 (06-11-2014), BRZZZZZZZZZZ (06-11-2014), chanomatik (06-11-2014), microbionic (06-11-2014), mokinbird87 (06-11-2014), Nsot (06-11-2014), P86RAVES (06-11-2014), SkAsphalt (07-16-2014)
Old 06-11-2014, 04:10 AM   #236
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Nice work. Mine's going in this weekend
What were your initial impressions when you took it for a drive after the installation?
Old 06-11-2014, 05:56 AM   #237
Hachiroku14
very good initial bite even on cold. never faded through a couple of spirited drives. and better pedal feel also with the SS lines.
PS. make sure to properly bed them pads. most especially the cool down phase.
The Following 2 Users Say Thank You to Hachiroku14 For This Useful Post:
chanomatik (06-11-2014), P86RAVES (06-11-2014)
Old 06-11-2014, 08:17 AM   #238
P86RAVES
Drives: 08 WRB WRX STi / NA Miata
Would you say it feels like the pedal has a more linear feel throughout braking?
P86RAVES is offline   Reply With Quote
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
