Old 06-03-2014, 04:07 AM   #743
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
What is the base line for stock car on this dyno?
Mars2 is offline   Reply With Quote
Old 06-03-2014, 04:22 AM   #744
nelsmar
Somewhere around 145-160HP. I need to get more stock cars on there!
A few comparisons:
A friend took his E85 innovate car to this dyno and did 240WHP, did 263WHP on a dynojet
KW & JRSC make 250-265WHP on this dyno (91 octane)
The last JDL turbo car I had on there put down 280WHP on 91 octane (pretty decent IMO).
The dyno typically reads 8-12% lower than a dynojet. So basically the numbers above are pretty damn good. @Ninjin's car always seemed to perform a tad above others but I have also retuned it a number of times and it has been dialed in pretty well.
Honestly I have been wondering about the TRD intake helping or not. The duct seemed to have possibly helped up top, mid seemed around the same if not maybe a hair less. However @Ninjin said it felt more responsive which was more important to him. It did add some turbulence at around half throttle that I had to work around but other than that it really wasn't as bad as I was expecting.
I have driven the car a number of times on the street before but we never did any E85 dynos until recently, before dynoing on E85 I have to say his car really pulls. It really feels on par with an innovate on 91 even before dialing in the E85.
My flickr - Canibeat
Local magazine scout
Old 06-03-2014, 04:28 AM   #745
nelsmar
those number are amazing.
do you think the HKS intake duct and the TRD intake are helping a lot to get those number's.
I have same JDL uel then Miltek header to back box with E85.
I also have Crawford BPB.
Do you think I can expect similar number?
May be a bit more in 5000-6500 rpm area and a bit less after that due to crawford BPB.
I cant say exactly where you will line up. @Ninjin's car seems to put down more than the average car, but also has had more time on the dyno than probably any car I've ever put on the dyno. The BPB will give you a slight bump in the mid range but it will fall off on the top end right around where the peak efficiency of the JDL header is. So it really depends on the driving style. I think the BPB might match a tad better with the JDL EL header as it does really well in the torque dip.
My girlfriend has a JDL UEL header, OP, FP, and BPB and it is up ~27%HP gain on 91 octane over her stock plot (all within similar weather conditions even) though her top end does fall off quite a bit. I tend to shift around 7k as it feels like it falls off a lot. But the mid range is great on hers!
Old 06-03-2014, 04:54 AM   #746
Mars2
do you make flexfuel tune that could match that when on E85. I have moto east flexfuel kit.
Old 06-03-2014, 12:13 PM   #747
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by transition View Post
Any response here on this JDL? Overpipe rubs the crossmember in hard turns. Is this normal?
Sorry didnt see this. Ill shoot you a PM an get some details
JDLAutoDesign is offline   Reply With Quote
Old 06-03-2014, 08:26 PM   #748
Churg
Churg's Avatar
Drives: 2014 WRB BRZ
Extremely excited for my UEL headers to come in. I initially wasn't going to get it coated, but I'm glad I decided to get the Titanium coating. Hopefully in the next two weeks I'll have my headers! JDL, I can't thank you enough for the customer service that you guys have provided. I can't wait to do more business with you guys in the future!
Churg is offline   Reply With Quote
Old 06-04-2014, 02:20 AM   #749
blindfold
Drives: brz
would this equal length header fit the hks supercharger kit? Since kraftwerks is somewhat similar I am a bit concerned before I finalize my order. Thanks
blindfold is offline   Reply With Quote
Old 06-04-2014, 03:52 AM   #750
nelsmar
Does the HKS kit have a flywheel extension? That part is too close on the kraftwerks kit.
Old 06-06-2014, 05:24 PM   #751
Jericon
Drives: 2013 WR Blue BRZ Ltd
Originally Posted by JDLAutoDesign View Post
Waiting to line up a local car as our car is down. We use a Magna flow resonator and muffler so there is no shame on it sounding bad we just need to get a car in
I'll gladly offer my car to throw it on to get some clips. Considering buying one and I, too, want to hear it.
I've got the UEL, OP and Frontpipe now.
Jericon is offline   Reply With Quote
The Following User Says Thank You to Jericon For This Useful Post:
HatchetBurial (06-06-2014)
Old 06-06-2014, 08:28 PM   #752
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Last year Dave came by with his JDL equipped car and we were disappointed we couldn't run the cam timings we wanted due to the crappy stock exhaust that was in there. This year he came back, this time with a proper full exhaust. Here's the stock vs tuned + JDL header w/2.5" exhaust. Still very quiet, but this is exactly what we're used to seeing with this header. EL or not, that collector design and primary size are damn near optimal. 93 octane. 5000 rpm point at the same HP as before so you know it isn't shifted higher. Lower if anything. Flattest torque curve of any header we tested, and still makes great power up top.
Xero-Limit is offline   Reply With Quote
The Following 7 Users Say Thank You to Xero-Limit For This Useful Post:
akahenry (06-07-2014), enjoyminutemaid (06-12-2014), HatchetBurial (06-06-2014), JDLAutoDesign (06-06-2014), mkivsoopra (06-11-2014), mxsled (06-07-2014), nelsmar (06-06-2014)
Old 06-06-2014, 10:01 PM   #753
HatchetBurial
HatchetBurial's Avatar
Drives: Subaru BRZ SWP Limited MT
We need to get a dual exit on this man's car, asap!
HatchetBurial is offline   Reply With Quote
The Following 2 Users Say Thank You to HatchetBurial For This Useful Post:
blackhawkdown (06-08-2014), Jericon (06-06-2014)
Old 06-06-2014, 10:59 PM   #754
Wepeel
Drives: '13 BRZ Ltd
What are the specifics of the exhaust?
Wepeel is offline   Reply With Quote
Old 06-06-2014, 11:14 PM   #755
Xero-Limit
Xero-Limit's Avatar
Honestly can't remember. He may chime in.
Old 06-08-2014, 10:15 AM   #756
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
I'm into single tip exhaust but the exhaust tip of the jdl turned me off from a potential buy.
Sent from my GT-N5110 using Tapatalk
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 10:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 12:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 07:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 08:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
