Old 05-31-2014, 11:35 PM   #1
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Corner Balancing
Hey guys so I just finished installing my KW V3 coilovers and I used the Raceseng camber plates for the front. Also I did a alignment on the car.
My question is for daily use and as a car I use to go everywhere is it important to get the car corner balanced or is this something thats more of a track setup thing.
ExxelDistributions is offline   Reply With Quote
Old 06-01-2014, 03:00 AM   #2
fz6r
Drives: 13 10 series FRS
I wonder this as well
fz6r is offline   Reply With Quote
Old 06-01-2014, 04:09 AM   #3
Dezoris
Dezoris's Avatar
Two schools of thought, the point of individually adjustable dampers and ride height is to be able to get cross balance 50/50 and to have ability to setup car per instance/track.
Real world is most people dont use any of it and just want a quick drop.
So the real question is what is a proper setup worth to you namely after spending a few thousand on parts?
Is a cross balance needed for street? No but why half as* it when you have already invested so much into it not to finish the last detail?
Old 06-01-2014, 09:40 AM   #4
wparsons
wparsons's Avatar
^^ This!
Why did you spend lots more on V3's over V1's (or ST), and buy one of the most expensive camber plate options for something that's purely daily driven and you won't be taking advantage of the adjustment options?
If you're not tracking it autocrossing it, I would also get rid of the camber plates and run the OEM upper mounts. They're quieter, last longer and don't require maintenance like the spherical bearings will. The KW struts are slotted, so you have some camber adjustment with them as well.
If you plan to make use of the adjustments and extra camber you can get from the plates, then get the car corner balanced.
flickr
SkAsphalt (06-02-2014)
Old 06-01-2014, 03:01 PM   #5
ExxelDistributions
Thanks for the input guys. I do hear noise from the camber plates after driving it for one day. I agree with spending that much money and rather just have it corner balanced to have the setting correct.
I do plan on tracking it once in awhile. So i guess I will get it done to be adjusted perfectly.
Thanks for the info guys.
Old 06-01-2014, 03:16 PM   #6
CSG Mike
CSG Mike's Avatar
You spent a lot of money already. While you may not notice a great corner balance, you certainly will notice if the corner balance is off.
Get your ride height where you want it first. Then, get it corner balanced. The shop you choose should be able to keep it pretty close to your ride height.
You're in LA; I highly recommend West End Alignment. Ask for Chris or Darin, and let them know you were referred over by me.
http://www.yelp.com/biz/west-end-alignment-gardena
ExxelDistributions (06-01-2014), wparsons (06-01-2014)
Old 06-01-2014, 03:52 PM   #7
ExxelDistributions
Thanks for the help! So you recommend I adjust my coilovers to the height I want and then have them corner balance and align the car?
Old 06-01-2014, 08:44 PM   #8
CSG Mike
CSG Mike's Avatar
Yes. If you need the dampers dialed in after you get the corner balance and alignment, then we can do that for you
Old 06-01-2014, 11:39 PM   #9
JDMSushi
JDMSushi's Avatar
Drives: JDM86
CB is a huge overkill for a car not dedicated to track.
JDMSushi is offline   Reply With Quote
The Following User Says Thank You to JDMSushi For This Useful Post:
Old 06-02-2014, 12:38 AM   #10
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Well to be fair, everything he did regarding the suspension was considering CSG and RCE say the stock set up for "once in a while" tracking is already damn good....
The Following User Says Thank You to SkAsphalt For This Useful Post:
wparsons (06-02-2014)
Old 06-02-2014, 12:42 AM   #11
CSG Mike
CSG Mike's Avatar
You won't say that if you swerve during an emergency maneuver and the car doesn't respond the way you want/expect it to...
Jive Turkey (06-02-2014)
Old 06-02-2014, 01:07 AM   #12
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
My car is corner balanced and it feels sublime!
Left front to right rear is 50.08%
Right front to left rear is 49.92%
worth the cost!
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
kiichiro (06-02-2014)
Old 06-02-2014, 02:34 AM   #13
ExxelDistributions
Maybe I can just make the drive and come by you for corner balancing, alignment and dampers adjusted by you if you do all 3?
The Following User Says Thank You to ExxelDistributions For This Useful Post:
CSG Mike (06-02-2014)
Old 06-02-2014, 02:37 AM   #14
ExxelDistributions
I won't doubt them being wrong. But I don't like wheel gap at all and want to lower it. I know everyone is going to say why did you go with kw v3 then when you could have bought $1000 coil overs. The answer to that is I like to pay the price for the quality stuff.
Free wheel mounting and balancing at R/T Tuning! R/T Tuning Wheels and Tires 1 01-07-2014 01:33 PM
Question about balancing/alignment on new wheels The_Societan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-23-2013 10:42 PM
Wheel Balancing Weights Black Tire Tracking / Autocross / HPDE / Drifting 4 06-13-2013 05:51 PM
Corner Balancing Gen Southern California 5 11-13-2012 06:42 PM
Where to find black wheel balancing weights?? 86_ZN6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 11-09-2012 11:48 PM
