Old 06-01-2014, 04:09 PM   #29
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
the H/D bearings for the v2 upgrade are rated at 55,000
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
The Following User Says Thank You to draggin_az For This Useful Post:
marcoaferrer (06-01-2014)
Old 06-01-2014, 05:30 PM   #30
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
The pulley you would need to reach the max rpm would be 2.75
marcoaferrer is offline   Reply With Quote
Old 06-01-2014, 07:09 PM   #31
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Doesn't seem like much of a difference between the 3.125 in terms of power.
Rocket.BRZ is offline   Reply With Quote
Old 06-01-2014, 07:43 PM   #32
marcoaferrer
Yep. What's your power goal. You might want to look into turbo if your looking for anything over 370 whp
Old 06-01-2014, 11:29 PM   #33
Rocket.BRZ
How much power do you think i can get with upgrading the blower and going down to the 2.75 If I make 295 whp now on the 3.125 ?
Old 06-02-2014, 09:25 AM   #34
marcoaferrer
Dont know really it depends at what point youll start to see knock. Plus the 2.75 pulley wont give you much more boost than the 2.87. Efficiency starts to drop off pretty bad with anything smaller than the 2.87.
Old 06-02-2014, 11:51 AM   #35
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
The v2 I run is just nicer in that it doesn't get as hot as the v3 under severe abuse at the track in 110f temps
Right why am I tracking it when it's so hot?
Nothing better to do
I don't recommend going smaller than 2.87 on v2 for track use if u want reliability
Trying to go smaller is not smart for track, but fine for a dd, IMHO
Air is not the limiting factor for power at that limit
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
misooscar (06-04-2014)
Old 06-02-2014, 06:34 PM   #36
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
What typical whp levels and boost are people getting with the 2.87 and 3.125 pulleys on pump gas?
Someone should also do a DIY video on how to change pulleys.
Tye300 is offline   Reply With Quote
Old 06-02-2014, 06:41 PM   #37
marcoaferrer
If no ones done a video by next weekend I'll put one together. I'm swapping to 3.125 in two weeks time.
Old 06-02-2014, 06:43 PM   #38
Tye300
Tye300's Avatar
Thanks bro! Will be waiting for it!
The Following User Says Thank You to Tye300 For This Useful Post:
marcoaferrer (06-02-2014)
Old 06-02-2014, 07:05 PM   #39
DJCarbine
Thupercharged
DJCarbine's Avatar
Hardest part about the swap is changing the belt, and that is just time consuming. PM me if you have any questions!
Also, inspect your pulley carefully. Mine had a few minor dings in the rib area that I filed down with a jewelers file, as I feared that the rough edges may just contribute to belt wear/failure
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 06-02-2014, 07:24 PM   #40
marcoaferrer
yeah i figured the belt swap was going to be a pain in the d*ck
lol the pulley shouldnt be too hard. Ive done it once already. The previous owner of the kit had the 3.125 on there when he sold it to me but I didnt have supporting mods to be able to run it.
I need to find a good strap wrench lol
Old 06-02-2014, 07:27 PM   #41
marcoaferrer
@Tye300 i just realized i mispelled your screen name on the main post. Sry about that man lol. I fixed it and added a link to your install
The Following User Says Thank You to marcoaferrer For This Useful Post:
Tye300 (06-03-2014)
Old 06-02-2014, 08:25 PM   #42
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have a good strap on you can use, and I'm local... LMK...
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 11:45 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 01:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
