Old 06-01-2014, 12:02 AM   #1
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Need more power vortech questions
Ok so I have the regular v3 tuner vortech kit running the 3.125 pulley at 11 psi. 295 whp on a mustang dyno. My questions is what are my options to making more power without installing a turbo or switching to e85 which we don't have in my area.
Rocket.BRZ is offline   Reply With Quote
Old 06-01-2014, 01:48 AM   #2
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Without e85 or the use of some form of meth injection than not many. 295whp on a mustang dyno isn't too bad at all. Now I am assuming this as you have supporting mods as well as the tuner kit (exhaust, headers and so on)
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 06-01-2014, 02:10 AM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
You may not have E85 but what about race gas?
Old 06-01-2014, 07:26 AM   #4
AJPG
Drives: 22RE, FA20, 4G63
I also have the vortech and the 3.125 pulley, borla eq header and exhaust, with supporting mods for cooling. Use Sunoco 100 map 4, 50:50 with 100:93 map2, map 1 for 93. For the price (10.40 gal) you get from 30-50 whp, completely dependent on your tune/tuner. If use the 50:50 results are similar but cheaper.
So next step is over spinning with 100 and hope for the best (100whp more and happy engine) but be prepared for new engine with forget internals!
If you don't have race gas in your area, over spinning on stoke internal would... Most likely... Well if you do it, tell me what happen, I may have an idea but no evidence
AJPG is offline   Reply With Quote
Old 06-01-2014, 01:58 PM   #5
Rocket.BRZ
I'm not really looking at overspinning the blower. I'm wondering if the v2 upgrade is capable for more boost. I have been talking with my shop about doing a custom twin charge setup. It would be the first of its kind.
Old 06-01-2014, 02:26 PM   #6
Frs300
Frs300's Avatar
Drives: Pile of junk
Gazoo and i believe hks have both done this already
Frs300 is offline   Reply With Quote
Old 06-01-2014, 02:37 PM   #7
Rocket.BRZ
Ok first of its kind on a consumer level
Old 06-01-2014, 09:43 PM   #8
AJPG
The v2 have the same compressor as the v3... Change the internals of the tranny side of the sc for H/D. I maybe wrong but as far I know have the same ratio.
As for the oil feed part, it takes the contaminated engine oil (normal wear) to the pristine sc oil... And can't compare the monolec with any engine oil on the market...
Custom twin charge! I also desire more boost from 2k, but and there is always a "butt" I buy a centrifugal sc. Was an early vortech adopter, no regrets as it meat the criteria I was looking...
Maybe the Phantom is the easiest, economical way to do your custom set up. Just an idea, I'm not in that boat
Old 06-04-2014, 11:02 AM   #9
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
doing the v2 upgrade will not create more boost. the upgrade is H/D bearings and then oil lines are attached to hook up to your engine.
but you can spin it faster then the v3
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-13-2014, 07:58 PM   #10
AJPG
Completely agree.
What temps are you seen on the sc now? Same as engine oil. 210-240?
Old 06-13-2014, 08:01 PM   #11
AJPG
Why not attach the sc to a small oil pump and separate oil cooler (also could be small).
vortech
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech SC + Vishnu OFT300 power package Garrett@Openflash Forced Induction 22 03-15-2016 12:04 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Wax Sealant Pad Questions / Care Questions l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-25-2014 11:19 AM
