Old 05-30-2014, 02:36 PM   #1513
brillo
Drives: 2013 Firestorm FR-S
how will the stock sways react to stiffer bushings? would that be noticable?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 05-30-2014, 05:56 PM   #1514
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
So as per everyone's suggestions I went with the oem crash bolts and now have -1.2* camber on both front wheels. On the street it is very close to stock with slightly less oversteer than a fully stock suspension. I'll be testing it out in autocross very soon and will have my final thoughts after that.
Sent from my SM-G900V using Tapatalk
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-30-2014, 11:09 PM   #1515
brillo
Also I'm curious, assuming I put ~5,000mi and 4 hpde events a year on the car, how long will the stock control arm bushings last? Trying to figure out when to replace to keep the car from feeling sloppy.
Old 05-31-2014, 03:07 PM   #1516
knipple
Drives: 2013 Ultramarine Scion FR-S
How would you go about selecting springs for autocross use with a 1/2" to 1" drop? (i.e. spring rate and free length)
P.S I asked this question earlier in the thread and the only response was a recommended spring rate, which is not an answer to the question.
knipple is offline   Reply With Quote
Old 05-31-2014, 04:04 PM   #1517
Turkish
Serial Cone Killer
Turkish's Avatar
Me personally, I would decide on what handling characteristics I want: ride height, oversteer/understeer, ride harshness, etc. Those decisions will then help you determine what kind of spring rates you will want. As far as giving you more specific advice, I'll leave that to the experts: @CSG Mike, @Racecomp Engineering.
... his name is...
C'THULHU
Old 05-31-2014, 05:20 PM   #1518
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Some Qs about Ohlins R&T vs RCE T2 (if both had the same spring rates on them..let's say, if both had 7k all around or 8k all around):
- I know they are diff (single vs dual adj)..but which is more aggressively valved?
- Which has the overall better quality in general (external build, internals, valving, etc.)
- If the T2 were setup similar to the R&T, as if it was single adj, which would be better for track and which has more aggressive performance?
- Which is better for high performance driving and track?
My sights are set on RCE T2 and will save for them...but also wondering if I should save a bit more and splurge on the Ohlins..and if they'd be worth the extra cost, saving for and getting them over the T2's.
fooddude is offline   Reply With Quote
Old 06-01-2014, 03:10 PM   #1519
CSG Mike
CSG Mike's Avatar
What class are you running? What mods are you limited to? What dampers are you on? Sways? Tires?
Old 06-01-2014, 03:11 PM   #1520
CSG Mike
CSG Mike's Avatar
- Please define Aggressively
- While KW is no slouch in the quality arena, I'd put Ohlins a notch higher
- R&T
- T2
What is your ultimate goal?
Old 06-01-2014, 03:37 PM   #1521
fooddude
- R&T
- T2
Thanks.
"Aggressively" - which has damping that can handle more spring rate OTS? ..also, which has the better and more advanced shim/piston/internal/valving design and engineering?
Goal? ..mainly a DD with lots of canyon fun with a sporty/porsche/ferrari/supercar/racecar/F1/GT1-like handing (jk lol.. but if you think about it..it seems like almost everyone's tracked twin is a DD and it's everyone's same goal to make it handle like a GT1 racecar lol) with hopefully regular/bi-monthly track days in the future, when money permits, and also perhaps room to progress/improve at the track as time goes by. No serious track competition - just hpde, fun, learning and time trials perhaps.
Old 06-01-2014, 06:13 PM   #1522
knipple
Class- STX
Suspension is currently stock, looking at getting the Motion Control Single Adjustable.
Stock Swaybars front and rear
Tires- BF Goodrich G-Force Rival 255/40/17
Old 06-01-2014, 06:19 PM   #1523
Turkish
Serial Cone Killer
Turkish's Avatar
Do you DD your BRZ/FR-S and with that said, how is treadwear?
Sorry for the :threadjack:
... his name is...
C'THULHU
Old 06-01-2014, 06:26 PM   #1524
knipple
Yes, I do DD my FR-S with those tires (mounted on Enkei RPF-1 17 X 9 et +35 wheels), I've had them on for approximately one year and 15,000 miles. I will be lucky to make the end of the year without changing tires. This is with approximately 2 to 3 autocrosses a month between March and November.
The Following User Says Thank You to knipple For This Useful Post:
Turkish (06-01-2014)
Old 06-01-2014, 08:46 PM   #1525
CSG Mike
CSG Mike's Avatar
Class- STX
If you're going off the shelf, you should get springs matched to the dampers. If you're serious about AutoX, then pick your spring rates, and then valve the dampers to match the springs.
Old 06-01-2014, 08:46 PM   #1526
CSG Mike
CSG Mike's Avatar
Thanks.
Both can handle more spring than OTS; the nod to engineering goes to Ohlins. I don't know the exact range since we haven't done enough testing to determine, but I'd guess a +100 is viable for both, perhaps more.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
