Old 05-30-2014, 01:58 PM   #4649
xxscaxx
Drives: 2013 SWP BRZ
Upgrade to 8.58 and see if the problem persists. Do you have the file, or still waiting? I ran .52 with no issues, I think it was 51 that had the codes popping up on people but I could be wrong.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Ethan (05-30-2014)
Old 05-30-2014, 07:54 PM   #4650
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I keep popping I think code P0301. 8.58 tune, 93 octane, intercooled, 70mm pulley.
Dustin is offline   Reply With Quote
Old 05-30-2014, 08:01 PM   #4651
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
I can make my car misfire on cylinder 2 if I get around 5k rpms and roll on to the throttle slowly. Same specs as you listed. Makes a really nasty almost tearing sound when it happens. Probably my coil pack being a piece of shit.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 05-30-2014, 08:50 PM   #4652
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
I can as well using a similar technique but I don't get any sound, just a flashing cel of P0303. I can also get it to flash it by not allowing full warm up and pushing it early.
I logged all 4 cylinder misfire counts and it happens actually in both 2&3 cylinders, even though it only throws P303 which is for #3.
Checked plugs, they looked good but replaced them anyway and swapped coils, neither had any noticeable effect if I induce as per above.
Now if I don't intentionally induce it and allow time to warm up before getting into it, I've had no issue.
Lawnik is offline   Reply With Quote
Old 05-30-2014, 09:00 PM   #4653
CK_Bladesmith
Drives: Raven FR-S
Same thing if mine isn't warmed up as well basically. If I go WOT it never happen, but if I try and hold the rpms up high around 5-7k it goes nuts and misfire like crazy causing a flashing cel as well. Mines only been on cylinder 2 so far.
Old 05-30-2014, 09:44 PM   #4654
Dustin
Twin Screw You
Dustin's Avatar
Exact same with mine to the letter. It's awful of I don't let it warm up first. WOT though it's awesome.
The Following User Says Thank You to Dustin For This Useful Post:
CK_Bladesmith (05-30-2014)
Old 05-31-2014, 01:29 AM   #4655
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I've heard Toyota have a TSI out on the coil packs. Soon as I have a copy I'll post.
Many stock cars are having coils replaced so this is not tune or F1 related.
Ryan86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
CK_Bladesmith (05-31-2014), Ethan (05-31-2014)
Old 05-31-2014, 09:16 AM   #4656
Ethan
Drives: Subaru BRZ
I have a 2013 BRZ and the 2014s apparently have a different part number for the coil pack. When I replaced the coil pack I just replaced it with the 2013 version and, as stated above got the same P0302 CEL a month later. So, are the people here with the coil pack problem in 2013 cars or 2014?
Ethan is offline   Reply With Quote
Old 05-31-2014, 09:24 AM   #4657
xjohnx
Grip>Slip
xjohnx's Avatar
I'm assuming most are 2013's, then again, most of the 2013's didn't start exhibiting coil pack issues in the first year either.
Old 05-31-2014, 09:44 AM   #4658
ZionsWrath
Thanks
ZionsWrath's Avatar
I get 20-30 ml in the crank case can every 5K, the other can collects minimal but it has added up over time.
I just finished my custom dual install with Shorai battery. Dropped 28 lbs over my previous install using the standard dual Radium bracket plus custom adapter and OEM battery.
You have any details on your custom adapter? I am interested in getting both the battery and catch can in the future.
Old 06-01-2014, 11:55 AM   #4659
Dustin
Twin Screw You
Dustin's Avatar
Originally Posted by xjohnx View Post
do you still have the plastic innovate pipe? could you do some tests/datalogs of IAT's at the MAF to see how much the nameless pipe helps?
This mornings drive to work with the Nameless intake pipe, not coated. Peak IAT temp was 58 C which is 136 F with the average being in the low to mid 30's C which is around the 90 F mark during highway driving. Outside temp was between 70-75 F. I'll do a drive tomorrow or the next day with the Innovate intake pipe to see if there is much of a difference.
xjohnx (06-01-2014)
Old 06-01-2014, 12:03 PM   #4660
Ethan
Drives: Subaru BRZ
I installed Delicious Tuning's 8.58 tune and its really nice. Very smooth.
Old 06-01-2014, 04:29 PM   #4661
Lawnik
Lawnik's Avatar
Basically, I bought the FT86speedfactory lightweight battery kit then made a new tie down piece that incorporates two Radium catch can mounts.
When I purchased the dual cans from Radium I had them send their universal dual mount, I provided the dual mount and the FT86speedfactory tie down to a aluminum fab shop and asked them to make one flat piece incorporating both.
This is what they made me. I had it powder coated and put the sticker Radium provided.
I could email you the design drawing if you send me your email.
The Following User Says Thank You to Lawnik For This Useful Post:
Boxer486 (06-04-2014)
Old 06-01-2014, 11:52 PM   #4662
Ryan86
Road Warrior
Ryan86's Avatar
Very neat, great job..
The Following User Says Thank You to Ryan86 For This Useful Post:
Lawnik (06-02-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
